Old 10-30-2006, 09:45 PM   #1
unibrain
unibrain is on a distinguished road
Default 1994 Saturn SL1 Seatbelt Question
Hello, Im new.
I just recently bought a used 1994 Saturn SL1. But I've found the seatbelts to be quite interesting. They were the mechanical seatbelts that move along the headrail when you get in.
Now, my understanding is that seat belts are supposed to resist if you give it a sharp tug. However, when I did that with these seatbelts, they seem to give you more slack, and never resist. Shouldnt they resist? Or does it only resist when there's an actual accident?
Any info would help greatly.
Thanks!!
Add to unibrain's Reputation
Rate the quality of this post and help unibrain reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unibrain is offline   Reply With Quote
Old 10-31-2006, 01:25 AM   #2
SaturnManiac
SaturnManiac's Avatar
Default Re: 1994 Saturn SL1 Seatbelt Question
I don't have automatic seatbelts, but my seatbelts won't budge (they will lock up) if I slam my brakes on, or something of the such.
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-31-2006, 09:05 AM   #3
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
Sharp tug doesn't always work. It is usually sharp deceleration (hard braking etc) that causes them to lock. Try stopping hard next time you are parking, it doesn't take much (like 5mph to zero) and before the car has fully settled, try pulling the seat belt.
You can tell Linux is made by geeks.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
Old 10-31-2006, 09:14 AM   #4
Kevin94SL
Kevin94SL is on a distinguished road
Kevin94SL's Avatar
2006 ION-3 Sedan
There is actually a lock that swings forward under deceleration - it doesn't have anything to do with the force that the seatbelt is pulled with.
Kevin
Add to Kevin94SL's Reputation
Rate the quality of this post and help Kevin94SL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kevin94SL is offline   Reply With Quote
Old 10-31-2006, 08:32 PM   #5
unibrain
really? what if I was driving on ice (common in Calgary, Canada), and lost control? the seatbelt wont really kick in until I jam on the brakes?
Old 10-31-2006, 10:31 PM   #6
Uzzy
Uzzy's Avatar
2002 SC1
Yes, the motion of the car is what triggers the locks. If there is a force that would cause you to move foreward in the seat, it would lock the belts, it doesn't matter about the brakes, just motion. Hopefully yours keep working for a while, just don't put any drinks in that spot where the e-brake is, the module is under there, and spilled drinks are a major cause of module failure. The belts on my old one quit becuase the passenger side track was binding up, and blowing fuses. I probably could have fixed it with grease, or a new trakc, but all the parts cars were SLx's, not coupes
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 10-31-2006, 11:02 PM   #7
unibrain
hmm.. good info, thanks.
I guess Im used to cars with the typical seatbelt setup. Like, I have a 2000 civic, and while you're strapped in, whether the car is in motion or not, if you tug at the seat belt feed fast, it wont give you any more slack.
But when in this Saturn, it doesnt matter how hard or fast you tug at the feed, because it will continuously give you more slack! I havent tried doing the brake thing yet though.
But still, I woulda thought regardless if you were in motion or not (mechanically), that your seat belts should hold you in the seat in a secure fashion.
I've never owned a Saturn (let alone with this type of seat belt system before), so it was suprising to me!
Old 10-31-2006, 11:16 PM   #8
Uzzy
Uzzy's Avatar
2002 SC1
I think most GMs are like that after many complaints of them grabbing too soon, and too tight. And I hated that stupid auto belt system. You will too the first time you take a latch to the side of your head I never once did up the lap belt while driving either, and that's not good. Mine didn't have a lap belt light. (Well it did, but burned out long before I got it, and I didn't know). I have the habit of doing my seat belt up within a block or two fo my house (or wherever I'm leaving from) and it doesn't seem to matter how fast I pull it, but I can work the brake, and gas to make sure it doens't lock up on me at the stop sign at the end of my street.
Old 11-01-2006, 01:40 AM   #9
Then either it's an unusual design, or there's something wrong with it. The Saturn seat belt _is_ a "typical setup"; for decades, the usual design for retractable seat belts uses a pendulum lock. All the tugging in the world won't stop it. And as said, it doesn't require "jamming on the brakes". It's deceleration that makes the pendulum swing and lock the retractor.
Add to madpogue's Reputation
Old 11-01-2006, 09:43 AM   #10
RangerRover
1999 SW2
I recently swapped out the auto-seat belts in my 94 for the manual belts from a 95. Best upgrade to the car yet. Like uzzy said, the first time you hit your head on them you will curse them. Especially because I am a cue-ball and have disconnected the belt several times.. and always managed to bang the top of my bald head on the metal latch. Ouch.
Old 11-02-2006, 10:07 AM   #11
Jinjo
Jinjo is on a distinguished road
Jinjo's Avatar
2001 SL2
Well they become locked when needed and I can tell you for a fact that your a perfectly safe seatbelt wise when you get into accidents as I have experienced one with the motorized seat belts before and they locked good.
Add to Jinjo's Reputation
Rate the quality of this post and help Jinjo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jinjo is offline   Reply With Quote
Old 11-03-2006, 01:15 PM   #12
BarnOwl
BarnOwl's Avatar
You're misunderstanding. Jamming on the brakes is not what causes the belts to lock up. There is a pendulum in the latching system. As long as it's hanging pretty close to the vertical, the seat belts won't lock. However, sufficient acceleration (decceleration is acceleration in the reverse direction) in any direction will cause the pendulum to swing off the vertical and lock the belt.
So, in your example, you're sliding on the ice and jam on the brakes. Unless the brakes grab that ice pretty well, the belts probably won't lock up. Now, if you hit something, that pendulum will swing and lock the belts.
Add to BarnOwl's Reputation
Old 11-03-2006, 02:06 PM   #13
eljefino
eljefino's Avatar
1995 SW1
everybody's right. Yippie!
http://auto.howstuffworks.com/seatbelt3.htm
in addition to their description, there are belts that lock under both circumstances.
Add to eljefino's Reputation
Old 11-06-2006, 08:24 PM   #14
unibrain
awesome. thanks for the help folks.
I'm starting to understand how these seat belts work.
One thing strange though, I was going downhill at actually a pretty steep angle yesterday, and noticed that the seatbelt still wasnt gripping.. putting the pendulum theory into action, shouldnt the seatbelts grip?
Old 11-07-2006, 01:37 PM   #15
BarnOwl
BarnOwl's Avatar
Not really, I don't think I've ever seen a hill steep enough to do it. I have felt the belts lock up going around corners and stopping though. In fact, I ran around with a broken driver's side seat back for a couple months (curse Sixth Planet!!!). It was lots of fun hanging on to the wheel with the belt locked up going around a corner.
Saturn SL1 1994 AnthonyL S-Series General 3 10-05-2009 08:42 AM
saturn sl2 seatbelt question. ngtmre S-Series Tech 1 04-06-2008 10:40 PM
Seat Belt Question Seatbelt 1994 SW1 brettkramer S-Series Tech 3 07-30-2007 02:39 PM
1994 Saturn SL1 Gets really hot.... Dserge S-Series General 20 07-28-2007 09:35 PM
1994 Saturn SL1 saturn_h8r S-Series General 4 07-06-2004 11:25 AM
