Old 08-14-2006, 11:23 AM   #1
tcptom
tcptom is on a distinguished road
Default 2003 Saturn VUE Remote Keyless Entry Stopped Working
Hello,
I have a 2003 Saturn VUE. The remote keyless entry (rke) stopped working about a week ago. I initially thought the battery was dead in my remote. I replaced the battery, which didn't help. I then tried the other key fob, which didn't help. I put the new battery in the second key fob, still no good. The battery meters good (3 volt).
All other accessories in the car seem to work fine (power locks, windows, radio, dome light, dash, etc)
Is there something I should be checking on the VUE side?
Thanks,
Tom
Add to tcptom's Reputation
Rate the quality of this post and help tcptom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tcptom is offline   Reply With Quote
Old 08-14-2006, 12:22 PM   #2
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Default Re: 2003 Saturn VUE Remote Keyless Entry Stopped Working
I also recently replaced the battery in one of my remotes. I didn't test the voltage on either battery- I'm only guessing it was a dead battery. The new battery hasn't fixed the non-working remote as well. I'm thinking that I'll have to reprogram the remote. I think I remember seeing something about that in my FSM. Have you checked the owner's manual?
Not a Saturn.
Add to Tom92SCm's Reputation
Old 08-14-2006, 01:30 PM   #3
tcptom
I have not checked the owner's manual, but I will tonight when I get home. Does anyone know where the RKE box is located on the 2003 VUE, and how to re-associate it with a key fob if there has been a problem of some sort?
Old 08-14-2006, 03:00 PM   #4
body-snatch-her
body-snatch-her is on a distinguished road
body-snatch-her's Avatar
I think you will just need to re-synch the fobs with the RKE. There are instructions on how to do it in the owner's manual. It's quite simple and you don't need to dig into any hardware to do it, but I don't recall the steps off hand. If that doesn't work then you will likely have to bring it all to a Saturn dealer and they can reprogram as required and as long as no further troubleshooting or repairs are required they should only maybe charge you like $20US for the effort.
"Together we WILL destroy the planet! (Evil Plot 2-B)"
Add to body-snatch-her's Reputation
Rate the quality of this post and help body-snatch-her reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
body-snatch-her is offline   Reply With Quote
Old 08-14-2006, 03:41 PM   #5
tcptom
Thanks body-snatch-her. I suppose I should RT*M this evening! I'll let you all know what the results are.
Old 08-14-2006, 05:04 PM   #6
fotovue
fotovue will become famous soon enough
fotovue's Avatar
2007 VUE Red Line
Unless something changed between models, a tech-II is required to reassociate the rke's with the vue. So a trip to the service department would be the prognosis. Some service department's will graciously program them for free, although they are supposed to charge you. They would also be able to give you some insight in to why the RKE's may have quit working in the first place.
2004 RL VUE AWD Black *R.I.P. 07/01/06* 65k
The 1st sold, 49th built
2007 RL VUE FWD Black *Born 01/26/07* 100k
mods: 4 wheel disc brakes, window tint, spoiler, blues and twos
Add to fotovue's Reputation
Rate the quality of this post and help fotovue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fotovue is offline   Reply With Quote
Old 08-14-2006, 10:37 PM   #7
tcptom
On pages 85-6 of my 2003 Saturn VUE handbook:
Synchronization is the method used to keep the transmiter of the vehicle communicating with the receiver of the vehicle. Synchronization may be required due to the security method used by the system. The transmitter does not send the same signal twice. The receiver will not accept a signal that has been sent to it more than once. This eliminates the possibility that the signal will be recorded and played back.
To manually syncrhonize your transmitter with your receiver, press and hold the "LOCK" and "UNLOCK" buttons on the transmitter at the same time for about 7 seconds while you are near your Saturn. The door locks will unlock or lock, depending on their starting position. If the door locks do not unlock or lock, see your Saturn retailer for service.
Unfortunately, this didn't do anything for me with either transmitter. I think fotovue and others may be correct that a trip to the Saturn service department is in order. I will post the results... Thanks to all.
Old 08-14-2006, 11:14 PM   #8
Most likley you will need to get your local Saturn to reprogram the fobs to the car. Perhaps reprogram the BCM. I have had a few where the fobs just seem to stop working/disappear from being recognized.
Add to ssicarman's Reputation
Old 08-16-2006, 02:00 PM   #9
tcptom
I took the VUE up to the dealer yesterday afternoon. The service manager reprogrammed the key fobs to re-associate them with the car. This did not work. He set up an appointment for me with a tech.
Went back this afternoon to have the tech look at the situation. He checked all the batteries and tried to reprogram the fobs as well. He discovered that there was no communication with the BCM. After re-flashing the programming of the BCM, the key fobs started working again. The dealer only charged me $70 USD for this, which felt nice and reasonable. Their only caution was that it is possible there is a larger problem with the BCM, so if the problem recurs it may be time for a new BCM.
We're back in keyless entry business.
(What a lazy American I am... Can't be bothered to put a key in my car door!)
Old 08-16-2006, 02:04 PM   #10
tcptom
Thanks again to all who helped, especially ssicarman, you hit the nail on the head with the BCM.
Old 08-16-2006, 02:04 PM   #11
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
I tried the "hold buttons for 7 seconds" last night on my remote after replacing the battery. I came to the conclusion that my lock/unlock buttons might be broken. I can use which ever button is on the left of the remote- but only if I push really hard and move my finger around to different positions on the button. I can't get the right button to work at all. The emergency button seems to work just fine.
Not a Saturn.
Old 08-16-2006, 08:44 PM   #12
Glad that you are up and running again.
Old 08-16-2006, 09:03 PM   #13
Try taking apart the fob (remote) and cleaning the contact buttons. The buttons/contacts can get dirty and foul things up.
Old 08-24-2006, 07:31 PM   #14
LuvMyVue04
LuvMyVue04 is on a distinguished road
2004 VUE 3.5L
Had trouble with my remotes on my 2004 Vue....
Changed batteries..nada.
Went to the dealer, tried to reprogram my remotes....nada.
Ended up replacing them, he reprogrammed them......Magic!!
I was told the lifespan of a remote is 2 years, if that's so...then I was past my life expectancy.
Hope this helps.
Add to LuvMyVue04's Reputation
Rate the quality of this post and help LuvMyVue04 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LuvMyVue04 is offline   Reply With Quote
Old 11-23-2006, 12:15 AM   #15
CPD
CPD is on a distinguished road
Follow-up: An electronic spray cleaner didn't work at all for me, but rubbing a pencil eraser on the circuit board contacts and the black carbon disk molded to the back of the button seal/boot did the trick.
Add to CPD's Reputation
Rate the quality of this post and help CPD reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CPD is offline   Reply With Quote
Old 09-14-2010, 11:48 AM   #16
zipgun77
zipgun77 is on a distinguished road
Yes!!! YES!!!! I have a 2002 SC1 and the keyless entry remote has been completely unresponsive for three days now... tried reprogramming ... rubbing the pencil eraser over the contacts inside the keyfob and over the back side of the battery totally fixed it!! Thank you!!!
Add to zipgun77's Reputation
Rate the quality of this post and help zipgun77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zipgun77 is offline   Reply With Quote
Remote Keyless Entry diosaaire S-Series Tech 7 04-14-2009 10:57 PM
Remote keyless entry not working kelbot Outlook General 9 03-19-2008 07:25 PM
2003 Vue stopped working scc4fun Vue General 12 02-19-2007 06:55 PM
Part Number for 2006 Vue Keyless Entry Remote mr_mike Vue General 5 09-25-2005 11:46 AM
Keyless Entry remote DaytonaSL2 S-Series General 15 12-22-2004 02:33 AM
