Old 03-21-2006, 12:10 AM   #1
RDKamikaze
RDKamikaze is on a distinguished road
RDKamikaze's Avatar
2002 SC1
Question How do I replace the rear struts on my 2002 SC1?
I need to know right now (before tomorrow) on how to replace my rear struts on my 2002 SC1. Thank you all so much for your help!
Add to RDKamikaze's Reputation
Rate the quality of this post and help RDKamikaze reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RDKamikaze is offline   Reply With Quote
Old 03-21-2006, 02:59 AM   #2
wolfman
wolfman's Avatar
Default Re: NEED NOW!! How do I replace the rear struts on my 2002 SC1?
Take it to Midas or Mieneke....opps its already tomorrow....sorry too late.
If you don't have or have access to a COIL SPRING COMPRESSOR do not attempt it.
I will assume you have MINIMAL mechanical knowledge and give you just this:
You'll need to remove the rear pacakge tray to access the bolts (3 each side) that secure the top strut mounts to the car. To do this FOLD DOWN THE REAR SEAT BACKS, to reveal the fastners behind them. There are also two more plastic ones in the flat portion of the tray. Once you have teh fastners removed, the tray can be flexed enough by pulling up on the center, bowing it, and them pulling it toward you.
The rest is just like replacing the struts on any car.
Add to wolfman's Reputation
Old 03-21-2006, 08:35 AM   #3
RDKamikaze
RDKamikaze's Avatar
2002 SC1
Default Re: How do I replace the rear struts on my 2002 SC1?
Thanks, that's all I needed to know and I was thinking that as I looked at my car some more last night. I'm doing this for my auto project today, so I have access to all the stuff and I know how and all that. Thank you for confirming my guess!
Old 03-21-2006, 08:37 AM   #4
amazinghl
Don't forget you'll need an wheel alignment afterward.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 03-21-2006, 08:57 AM   #5
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
I...
I, for one, would like to see how it could be done at all without a spring compressor. It would have to be only slightly easier than changing the spark plugs through the exhaust pipe.
Old 03-21-2006, 10:18 AM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
Rear springs can be done without a compressor, its the fronts that under a lot of tension.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 03-21-2006, 11:49 AM   #7
After doing the rears? Do they have camber adjustment like the fronts? Sorry, I never looked.
BTW, one thing I've done (on my Colt) was to remove the assemblies, as Wolfman described, then take them, with the new struts, to a local under-car shop. For $10-ish, they'll transfer the spring, cap, etc. to the new struts. (I'm lucky, there's a Car-X, local version of Midas/Meineke, two blocks from home.)
'Course, you can always borrow a spring compressor from Autozone, et al.; just be aware that you're dealing with a WHOLE LOT of stored potential energy when you compress that spring, and use appropriate caution.
Add to madpogue's Reputation
Old 03-21-2006, 01:11 PM   #8
Low Saturn
Low Saturn's Avatar
2000 SC2
Camber, caster, toe in and toe out all can be adjusted in the rear as well. Make sure to get that allignment.
Mike
-2000 Saturn SC2
Old 03-21-2006, 01:19 PM   #9
Caster? On wheels that don't steer?
I assume camber is set by the knuckle-to-strut bolts, like up front. How is toe set? Just curious. I know, RTFM....
Old 03-21-2006, 01:58 PM   #10
amazinghl
On some lowering springs, you don't need a sping compressor.
But most stock springs you will need one.
00 Insight 72mpg
Old 03-21-2006, 02:00 PM   #11
Low Saturn
Low Saturn's Avatar
2000 SC2
Its set the same way as the fronts. By elongating the top three mounting holes.
This is adjusted fromt the center of the rear crossmember.
Mike
-2000 Saturn SC2
Old 03-21-2006, 02:33 PM   #12
DTDSasquatch
DTDSasquatch is on a distinguished road
1997 SW2
I have a friend that allegedly did this by removing the center nut off the strut shaft while the strut was still in the car. I have to question this method though, because it would still be extremely difficult to remove the lower bolts without the strut going flying out the bottom.
I didn't.
Internet message boards: The demise of the English language.
Add to DTDSasquatch's Reputation
Rate the quality of this post and help DTDSasquatch reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DTDSasquatch is offline   Reply With Quote
Old 03-21-2006, 03:19 PM   #13
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
If you have a local harbor freight handy...
http://www.harborfreight.com/cpi/cta...temnumber=3980
Add to alleninpa's Reputation
Old 03-21-2006, 03:45 PM   #14
SaturnTech
SaturnTech is on a distinguished road
SaturnTech's Avatar
Unless you only value your life at $12...leave that POS at Harbor Freight. Strut Spring compressors are NOT the place to go saving money on a tool. Either rent a good quality one or have the job done by a professional. When a strut spring compressor breaks (and they do) the spring has deadly force behind it. This is NOT an area to go experimenting. I use shop quality strut spring compressors at the dealership when I do struts and even then I'm still nervous that it will malfunction or break and maim me or worse when it comes apart. Leave that tool at Harbor Freight if $12 is all you have to spend on a strut spring compressor.
Add to SaturnTech's Reputation
Rate the quality of this post and help SaturnTech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTech is offline   Reply With Quote
Old 03-21-2006, 04:09 PM   #15
DTDSasquatch
1997 SW2
I have that exact one back home for use with VW springs, and it works quite well. I've actually found that you can't use heavier-duty spring compressors on some springs, because they won't fit between the coils.
You'd be a retard to use those cheap ones on truck/SUV springs, but I don't think there would be any issues at all with springs on small cars.
Old 03-21-2006, 04:14 PM   #16
SaturnTech
SaturnTech's Avatar
And when I Worked for a VW dealer we changed out the springs with compressor at all. They can be compressed by hand. You'd be surprised how much tension and energy is in a front spring on a car...it's enough to kill someone. If you're comfortable putting your life in the hands of a $12 tool, be my guest. I buy stuff from Harbor Freight all the time, the quality of their hand tools is non existant. I wouldn't even joke about using that tool on a set of strut springs, but to each their own.
Old 03-21-2006, 04:25 PM   #17
DTDSasquatch
1997 SW2
Mine were "heavy-duty" springs, which I later replaced with H&R springs using the same compressor. I also used it to install SVT Focus springs on my dad's ZX5.
There's nothing wrong with those spring compressors for small car springs.
Old 03-21-2006, 05:16 PM   #18
alleninpa
alleninpa's Avatar
2009 AURA XR
1999 SL1
I have a set too.
Amazing how the $15 rotors are ok, but $12 spring compressors are not.
If you look around, I'm sure you can purchase the same spring compressors for $40, if it makes you feel better.
Old 03-21-2006, 05:18 PM   #19
VEGAS_SATURN
VEGAS_SATURN is on a distinguished road
VEGAS_SATURN's Avatar
1997 SW2
How much will I pay to have someone change my struts???
I have 4 KYBs sitting in my garage. Not sure I want to attempt it myself.
1997 SW2
Performance: Short Ram, Magnaflow, SPS Wires
Sound: Alpine and Rockford Fosgate, Sirius Radio
Upcoming: KYB Struts are in the garage. Sound dampener is on the way.
Add to VEGAS_SATURN's Reputation
Rate the quality of this post and help VEGAS_SATURN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VEGAS_SATURN is offline   Reply With Quote
Old 03-21-2006, 06:03 PM   #20
RDKamikaze
RDKamikaze's Avatar
2002 SC1
We have those spring compressors for auto shop on cars, and some very nice heavy duty ones for trucks/SUV's. The cheap ones work great, you'd have to be a retard to kill yourself with them lol. Anyways, thanks for the tips guys and all that, these new struts are so much better!
2002 SC1 rear drum brake noise, need help please long post ahardb0dy S-Series Tech 34 04-23-2018 02:16 PM
How do you remove / replace hub bearings on Saturn SC1 2002? travisj027 S-Series Tech 2 12-25-2008 07:37 PM
About to replace my struts.. mr tibbs S-Series General 5 08-12-2007 10:40 PM
2002 SL - how to replace rear turn signal? plurabelle L-Series Tech 1 01-25-2006 10:33 PM
Should I replace my struts VTHokie00SL2 S-Series Tech 14 07-30-2002 12:29 PM
