Old 02-28-2006, 12:40 PM   #1
dmacias666
dmacias666 is on a distinguished road
2000 SL2
Dizzy Fan turns on too late
I have a 2000 SL2 that I purchased from the original owner. He had rewired the radiator fan to stay on all the time, so I had the dealer mechanic set it back to factory specs. Only now I know why the previous owner made the change. The fan does not turn on in time to cool off the engine. The temp indicator goes to the half way point before the fan goes on. I had the mechanic at the dealer check it out, but he found nothing wrong. One of the crew told me to turn on the air condition when the engine heats up as it will trigger the fan to reach maximum rotation. This does work. The temp indicator does go down to a little above one quarter, but this is not a good fix. Especially in the winter when it is already cold.
Anyone else experience this problem?
Add to dmacias666's Reputation
Rate the quality of this post and help dmacias666 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dmacias666 is offline   Reply With Quote
Old 02-28-2006, 12:47 PM   #2
94sc295sl2
94sc295sl2 is on a distinguished road
94sc295sl2's Avatar
Location: spring hill tennessee (the motherland) sterling heights michigan native
1994 SL1
Default Re: Fan turns on too late
normal... saturn temp gauges go to the 3/4 mark before thefan kicks on.
remember that cars are built by robots built by human hands and are prone to failure.
Add to 94sc295sl2's Reputation
Rate the quality of this post and help 94sc295sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
94sc295sl2 is offline   Reply With Quote
Old 02-28-2006, 01:42 PM   #3
eljefino
eljefino's Avatar
1995 SW1
Add to eljefino's Reputation
Old 02-28-2006, 04:16 PM   #4
Sky King
Sky King's Avatar
Originally Posted by dmacias666
I The fan does not turn on in time to cool off the engine. The temp indicator goes to the half way point before the fan goes on.
This is absolutely fine. Actually it shoud get a bit closer to the red before the fan turns on.
I have read many threads concerning this. I do not understand why people get concerned when the temp gauge gets to half way. It is NOT hot or overheated untill it gets to the RED. Since the gauge does not have actual temps on it, you have no idea just how "HOT" or "COLD" a given gauge reading is. It is that way on purpose. All you need to know is whether or not it is TOO HOT or not. And if it isn't in the RED is isn't TOO hot.
Over the years Saturn has recalibrated the gauge to read lower even the temp is not different. They did this because people panic when they see the gauge reach the upper range. Like I said, even though the actual temp is no cooler, the gauge was recalibrated to READ cooler.
If you are interested in what those gauge positions actually mean, here is a cut and paste from another thread:
Normal running temp, just below 3/8 indication, 85 deg C - 185 deg F
3/8 indication 94 deg C - 201 deg F
1/2 indication 101 deg C - 214 deg F
Fan came on at just below 5/8 105 deg C - 221 deg F
Fan went off at 97 deg C - 206 deg F
I allowed the engine to run long enough to go through 2 fan on/off cycles to verify the on/off temps. I then turned the Air Cond on to force fan on. I allowed the AC to run a minute or so then turned it off. The fan continued to run untill the coolant temp was below 85 deg C, 185 deg F.
This is from two different DOHCs. A 99 SC-2 and a 95 SL-2
Also if you have a OEM thermostat, it is a 195 degree thermostat. And you can see from the above data, that the thermostat isn't even going to open before the gauge is close to the 3/8 deflection and half is only 2 degrees above the NORMAL boiling point for plain water. With coolant and the system pressurized as it should be, the boiling point is higher.
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-28-2006, 05:16 PM   #5
acr2001
acr2001 is on a distinguished road
As everyone else said, its perfectly NORMAL!
And as far as turning the A/C on - you only have to turn it on for a few seconds - that will cause the fan to turn on and run for a few minutes but it is NOT necessary!
- 1993 SL1 Auto 100,000+ miles
Add to acr2001's Reputation
Rate the quality of this post and help acr2001 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acr2001 is offline   Reply With Quote
Old 02-28-2006, 05:40 PM   #6
dmacias666
2000 SL2
Happy Re: Fan turns on too late
I'll take your word that it is normal, all of you. However, the first time the temp gauge went to the half way point I drove straight to the dealer. While the car was parked, and off, it leaked coolent on the ground. Enough to alarm one of the techs. As I said, eventually I was told that the fan was working yet it still makes me nervous as it never goes much higher than one quarter when I am driving on the freeway. With my previous Olds I notices the same thing. When the fan was burned out it still would not go above one quarter while on the freeway. I assume that for both one quarter is the normal temp.
David
Old 03-01-2006, 12:06 AM   #7
If you had coolant coming out of the surge tank (assuming form there from under the rad cap) then you do need to get the cooalnt temp sensor replaced.
The coolant gauge reading at half is normal. The only thing is that the coolant sensor sends this info to the PCM and then to the gauge. If the sensor is bad it will send the bad reading to the PCM and gauge.
Add to ssicarman's Reputation
Old 03-01-2006, 12:46 AM   #8
acr2001
If your leaking coolant when the vehicle gets up to the highest normal temp (a bit over half way on that gauge) then you should probably look at the coolant tank cap - its probably not sealing properly and preventing the system from pressurizing which would result in the coolant boiling over.
Old 03-01-2006, 06:29 AM   #9
Sky King
Sky King's Avatar
David
First let me say again, your temp gauge is not marked in actual degrees. What an Oldsmobile gauge means and what a Saturn gauge means will be different. The engineers have determined what they feel to be too hot. For two different cars, that will most likely be different. But instead of putting the actual temp there they just put a RED area. Regardless of what that really is, it is hot for THAT car. Without actual temps on the gauge, the gauge is ONLY a relative indicator. No matter how HOT the red area is, 212 degrees or 500 degrees it doesn't matter, red is hot.
Now for a little physics. Pure water boils at 212 degrees F. at sea level. If you put that same water in a sealed container and pressurize it, it has to get hotter before it boils. Add to that, anti-freeze/coolant. This mix also raises the boiling temp. You stated that coolant ran over. I would look at the resevoir cap. If the cap is leaking, the system can not pressurize. If it can't pressurize, it WILL boil at a temp lower than what it was designed to. That DOES NOT mean that the car has overheated.
If you noted the data in my previous post, you will see that the PCM did not even command the fan on untill 221 deg F, well over the normal boiling point but yet was NOT in the red.
Others have illuded that you need to change the ECTS. IF it is the resin tipped and IF it is cracked, you need to changea the ECTS. This can and will provide false informantion to the PCM.
Trying to compair the Olds, temp gauge with the Saturn is like compairing Apples and Oranges
Does the temp gauge EVER get into or REAL close to the red?
Does the fan come on before the temp gets to the red?
Do you get heat from theheater when selected"
Are you noticing recent auto salvage yardNormal running temp, just below 3/8 indication, 85 deg C - 185 deg F
Old 03-01-2006, 11:02 AM   #10
sl2collector
sl2collector is on a distinguished road
IMO, If you fan was running all the time until then, it prolly never been up to proper operating temp, and it is very likely you coolant system is just slighly overfilled, and when normal temp is reached, there is enough in the system to overflow, is it at the cold line when cold?or over or under the line?
Add to sl2collector's Reputation
Rate the quality of this post and help sl2collector reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sl2collector is offline   Reply With Quote
Old 03-01-2006, 03:23 PM   #11
Sky King
Sky King's Avatar
MAN I don't know what happened here . Sorry for the repeat. I didn't know this happened untill I came back and read it.
Old 03-06-2006, 06:38 PM   #12
dmacias666
2000 SL2
It is at the proper line now. The guy I purchased the SL2 from really screwed up this car in more ways than I can mention. It is possible that it was overfilled at the time I received it. Since then I have lived with the temp gauge go to the center line. It has not gome beyond that ever.
Old 03-06-2006, 06:46 PM   #13
Kevin94SL
Kevin94SL is on a distinguished road
Kevin94SL's Avatar
2006 ION-3 Sedan
1/2 is awesome. That's exactly where it should run. As others have stated, unless it hits the red, don't panic. All of us get the same reaction in these cars the first time we get them heated up.
For the first one we had, my Dad almost lost it (I still remember hearing HOLY #@!%... it's overheating... until the fan kicked on).
Kevin
Add to Kevin94SL's Reputation
Rate the quality of this post and help Kevin94SL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kevin94SL is offline   Reply With Quote
Old 03-07-2006, 10:30 AM   #14
Luke
Luke's Avatar
Default Perfect
>Fm Kevin <
Classically perfect, although most such guages will settle just to the left of center.(((> As does mine <)))
Add to Luke's Reputation
Luke is offline   Reply With Quote
Radiator fan coming on late 96 SC2 RobertGary1 S-Series Tech 3 01-10-2012 02:01 PM
Engine fan only turns on when AC is on ? Frank91 S-Series General 8 06-30-2007 08:04 AM
Engine fan only turns on when AC is on ? Frank91 L-Series General 2 06-29-2007 12:16 PM
A/C Fan Turns On When Car Is OFF ??? SafariMelissa S-Series Tech 2 07-22-2006 09:33 PM
late fan drizzlemiao S-Series General 4 03-28-2005 07:44 PM
