Old 02-25-2006, 06:52 PM   #1
Dingo Warrior
Dingo Warrior is on a distinguished road
1994 SC1
Default 1994 Saturn SC1 EGR valve malfunction trouble code
I noticed recently that my "check engine soon" light has been coming on intermittently. I am getting the code that means there is something wrong with the egr system. What would be the best thing to do in this situation? I've been hearing a whistling sound for a while now...I have suspected it to be a vaccum leak....would it have anything to do with this trouble code?
Add to Dingo Warrior's Reputation
Rate the quality of this post and help Dingo Warrior reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dingo Warrior is offline   Reply With Quote
Old 02-26-2006, 01:29 PM   #2
johnt671
johnt671 is on a distinguished road
Default Re: 1994 Saturn SC1 EGR valve malfunction trouble code
If you have a vacuum leak in the EGR system it will cause the SES light to come on as the system won't function properly. If I remember correctly, the Haynes book states that it could be the EGR valve, EGR solenoid, or map sensor . Check your vacuum lines since you have a whistling noise, then make sure the wires and connectors are goo/tight. If that doesnt stop the SES light you could do what I did and go to a junkyard and buy the possible bad parts, and replace them one at a time until you stop the light and then replace the junkyard part with a new one. I got the part for 15 bucks and found the EGR solenoid was my problem.
Almost left out cleaning the EGR valve before the junkyard trip.
Add to johnt671's Reputation
Rate the quality of this post and help johnt671 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnt671 is offline   Reply With Quote
Old 02-26-2006, 01:31 PM   #3
eljefino
eljefino's Avatar
1995 SW1
I'm assuming you have the non-california vacuum powered EGR valve. Your year was transitional.
If so I agree with Johnt.
Add to eljefino's Reputation
93 SC1 EGR valve trouble number9 S-Series Tech 7 03-01-2009 02:47 PM
SC2 OBD II trouble code P1406 EGR valve Pintle pos circuit dsbike S-Series Tech 7 05-22-2008 02:45 PM
Trouble Code P0401 EGR Satman53 S-Series Tech 2 05-21-2008 05:59 AM
trouble code 42 1994 SL2 bud L-Series Tech 1 05-21-2007 10:32 PM
EGR valve on a SL1 1994 Jinjo S-Series General 6 03-25-2006 01:42 PM
