Old 12-24-2005, 10:53 PM   #1
tgferg67global
tgferg67global will become famous soon enoughtgferg67global will become famous soon enough
tgferg67global's Avatar
Default Auto trans problems.. loose input shaft nut?
I have a 97 SC1 automatic with 130,000 miles, which has some trans problems. When cold the transmission will not engage into reverse unless I raise the rpm's and when hot it will not engage at all. This problem happened all at once, as there was not gradual increase of symptoms. The transmission has always shifted harder into reverse than into drive (reverse slam) but never seemed real bad (reverse slam).
Am I on the right track suspecting the input shaft nut?
How do you hold the input shaft from turning when installing the new nut "without" buying the $150 special tool?
Add to tgferg67global's Reputation
Rate the quality of this post and help tgferg67global reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tgferg67global is offline   Reply With Quote
Old 12-25-2005, 10:53 PM   #2
Scout238
Scout238 is on a distinguished road
1997 SL1
1996 SL1
Default Re: Auto trans problems.. loose input shaft nut?
Check your fluid.
Add to Scout238's Reputation
Rate the quality of this post and help Scout238 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Scout238 is offline   Reply With Quote
Old 12-26-2005, 11:36 AM   #3
BarnOwl
BarnOwl's Avatar
Before I dove into replacing the input shaft nut I'd try Wolfman's reverse slam cure. If that doesn't work, here's a link to info on dong the input shaft nut.
Add to BarnOwl's Reputation
Old 12-26-2005, 09:51 PM   #4
tgferg67global
It's the nut. I could amost turn it off by hand.
How does one tighten the nut without the special tool?
Old 12-27-2005, 01:03 AM   #5
Scout238
1997 SL1
1996 SL1
Some, including myself, have used a C-clamp to hold it in place. Being careful not to gouge anything, I used the handle and put it up on the suspension componets. Seemed to work fine for me. Make sure to get a new nut. Costs a dollar or so at the dealer.
Old 12-27-2005, 06:52 AM   #6
tgferg67global
Thanks for the tip. All back together now and the transmission shifts fine and I have reverse again.
I wanted to point out that the generation of Saturns from 97 and up can not gain enough clearance for the lower trans mount stud when the engine is jacked up. The A/T is jacked up as high as it can go and the casting is contacting the subframe and there is still not enough clearance for the lower mount stud to clear. I had to use a cutoff wheel on the lower mount stud to shorten it.
Old 12-27-2005, 08:34 AM   #7
BarnOwl
BarnOwl's Avatar
The transmission mount stud doesn't need to clear by jacking up the tranny. Jack up the tranny, take mount loose from the tranny, then you can tilt the mount and get it out. Here's a link to a video (Thanks Low Saturn!) that will give you the idea.
Old 12-27-2005, 09:54 AM   #8
Luke
Luke's Avatar
>Fm tgferg<
That was the very problem I had with my '95SL2; It was necessary for me to fully lift the engine & transmission straight up. That was the only way I could get out, and replace, the lower transmission mount.
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 12-27-2005, 12:45 PM   #9
tgferg67global
Photo of the clearance issue.
Old 12-27-2005, 01:06 PM   #10
Scout238
1997 SL1
1996 SL1
Ditto
Old 12-27-2005, 09:33 PM   #11
geartooth94
geartooth94's Avatar
swap to manual trans. that will fix your problems.
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 12-28-2005, 12:47 PM   #12
S3aturnR
S3aturnR's Avatar
1999 SL1
the tech manual told me to put the gearbox into 2 different gears simultaneously while torquing both the input and output shaft nuts. (easy to do when the unit is sitting on your workbench) they are single use items and come in the rebuild kit. oh, crap, you have the auto. i don't know if you can put it into 2 gears like the manual gearbox? got me, dude...
s3aturnr
Add to S3aturnR's Reputation
how to jam input shaft for input shaft nut replacement. anisbet S-Series Tech 2 04-20-2009 11:54 AM
What to look for with Input shaft Nut ? browntown3 S-Series Tech 1 03-15-2009 04:50 PM
"Input shaft nut" location on TAAT trans 2003MercMaraude S-Series Tech 2 06-19-2008 03:10 PM
Input nut shaft disc loose after torque tacinc1 S-Series Tech 0 03-12-2008 05:02 PM
auto trans input shaft nut GT's SC S-Series Tech 2 04-25-2007 10:10 AM
