Old 12-17-2005, 03:05 AM   #1
zzyx7
zzyx7 is on a distinguished road
Default intake manifold cleaning
Hey guys,
I'm curious, how do you go about cleaning your intake manifold? I took my throttle body off a long time ago and saw that the manifold had a layer of black oily crud all over the inside. Do you just spray carb cleaner in through the throttle body? Should I do it while my engine is running or off? Thanks =D
Add to zzyx7's Reputation
Rate the quality of this post and help zzyx7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zzyx7 is offline   Reply With Quote
Old 12-17-2005, 08:23 AM   #2
amazinghl
Default Re: intake manifold cleaning
Last time, I just took the TB off and clean it while the engine is off.
Be warned, the car will take a long time to get start afterward.
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
Old 12-17-2005, 08:27 AM   #3
jambra1
jambra1 is a jewel in the roughjambra1 is a jewel in the roughjambra1 is a jewel in the roughjambra1 is a jewel in the rough
Some addtional thoughts about cleaning the manifold:
http://www.saturnfans.com/forums/showthread.php?t=1466
http://www.saturnfans.com/forums/showthread.php?t=367
Speaking of carbon buildup, you may want to pull your EGR and clean it while you're in the mood. You can use the carb cleaner or TB cleaner on it.
http://www.saturnfans.com/forums/showthread.php?t=60814
http://www.saturnfans.com/forums/showthread.php?t=48349
Add to jambra1's Reputation
Rate the quality of this post and help jambra1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jambra1 is offline   Reply With Quote
Old 12-17-2005, 03:21 PM   #4
Derekleu
Derekleu is on a distinguished road
1999 SL
Whatever you do, do not spray an entire can in the intake manifold, or through the throttle body (with it still attached), while the engine is off.
Trust me, I learned the hard way, do a search for "I think I just killed my saturn."
Mine was extremely dirty, so I gunked up my IAS and sent loads of carbon down into my cylinders and oil.
Take of the throttle body and clean that, stay away from the intake manifold.
(Or if you do it right, teach me how to do it)
1999 SL SOHC 138k
Add to Derekleu's Reputation
Rate the quality of this post and help Derekleu reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Derekleu is offline   Reply With Quote
Old 12-17-2005, 05:55 PM   #5
JS593
JS593 is on a distinguished road
JS593's Avatar
1992 SL1
If i wanted to clean my intake header, i would just go to a junkyard first, get one that is used of course. Spray some Carb cleaner all over it, let is sit for an hour, and run hot water through it, do it a couple times to loosen the carbon... make sure its fully dry and swap over the cleaned header.
92 SL1 SOHC TBI
Custom intake
Alpine deck, speakers, amp
JBL Sub
Ultimate amp
Volometer gauge mounted in dash
Magnaflow exhaust
....DEAD.... Car towed away Jan 18 2007. RIP
Add to JS593's Reputation
Rate the quality of this post and help JS593 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JS593 is offline   Reply With Quote
Old 12-17-2005, 10:34 PM   #6
zzyx7
Thanks everyone for the responses!
Can I spray the carb cleaner while the engine is running? Derek, I remember reading your post. I'm afraid that if I leave my engine off and spray it, I might flood it or just wash tons of gunk into my cylinders all at once even if I only do half a can.
Old 12-18-2005, 09:54 AM   #7
Bill-kaz-jr
Bill-kaz-jr is on a distinguished road
It will stall if you are not careful. Be judicious with the spray.
Bill
Add to Bill-kaz-jr's Reputation
Rate the quality of this post and help Bill-kaz-jr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bill-kaz-jr is offline   Reply With Quote
Old 12-18-2005, 10:23 AM   #8
BarnOwl
BarnOwl's Avatar
I like dumping a couple cans of seafoam into the manifold through the PCV valve hose with the engine running and fully warmed up. Not only does it clean out the manifold, you get lots of really cool smoke.
Add to BarnOwl's Reputation
Old 12-18-2005, 10:28 AM   #9
Derekleu
1999 SL
My lesson was:
You clean the Throttle Body, not the intake manifold.
You remove the throttle body so the gunk on it lands on the asphalt by your feet, not inside your cylinders and oil.
You don't clean the intake manifold by just spraying it because it will send loads and loads of carbon deposits into what used to be your clean engine, causing all flavors of hell, including your EGR valve and passthrough getting clogged and severe rough start and running issues.
I agree with JS593 as far as cleaning the intake manifold, if you wanna do it, take it off first.
One thing I have heard of that I have not yet tried is the steam clean, where you actually pour water into the intake of a hot, running engine.
1999 SL SOHC 138k
Old 12-18-2005, 11:02 AM   #10
JS593
JS593's Avatar
1992 SL1
Originally Posted by Derekleu
My lesson was:
Steam clean can work, but i would not recommend it, too much chance of hydrolocking the cylinders. If your really looking to tune your car down the line, you can always do a port and polish and new headers. At least you know you set aside the possibliltiy of a really nasty looking header.
92 SL1 SOHC TBI
Custom intake
JBL Sub
Ultimate amp
Magnaflow exhaust
cleaning EGR intake manifold passages twcinnh S-Series Tech 12 02-28-2014 11:03 AM
Intake Manifold Cleaning josh_arby Vue Tech 7 07-21-2009 12:00 PM
Intake manifold cleaning jdcart S-Series Tech 3 10-16-2006 02:26 AM
oil usage - intake manifold cleaning robert_lahaver S-Series Tech 10 05-20-2006 07:37 AM
cleaning intake manifold colindr S-Series Tech 7 11-15-2005 10:52 AM
