#1 | ||||
![]() Join Date: Aug 2005
How do you go about bleeding the clutch on a SL-2 with a DOHC?
#2 | ||||
You don't. It is a sealed system with no normal provision for bleeding the system. The ealy years had a small hex screw that some people have tried to bleed the system with but have not had long term success with as far as I know.
... A lousy day in paradise is still a day in paradise.
#3 | ||||
Then how do you get fluid in the system after changing the master or slave?
#4 | ||||
You purchase the clutch hydraulic system as an entire unit from the stealership.. er dealership. The clutch master cylinder and slaved cylinder come together. It is pre bled, pre filled. Its a plug and play unit.. just bolt it on and you're good to go.
... 1996 SC1 1995 SC2
#5 | ||||
arendsg you probably bought a master or slave cylinder from a parts store. Here's what it says on Autozone's web site:
CAUTION: O.E. SYSTEM IS VERY DIFFICULT TO BLEED; RECOMMENDED REPLACEMENT WITH PRE-BLED COMBINATION CLUTCH MASTER AND SLAVE ASSEMBLY. The thing is that the pre-bled assembly from Autozone is more expensive than the one from Saturn. ... There is nothing more frightening than ignorance in action.
#6 | ||||
depends on your area- all AZs and saturnstores are priced diff'ent.
one saturnfan says he can bleed 'em, I forget who though. I made an attempt or 2 on the bench, couldn't get it, but I had a good used one so I didn't try all that hard. ... for the first time in 8 years, I don't own a saturn.
#7 | |||||
![]() Join Date: Jan 2005
I have heard that the hex screw that existed on early slave cyls does not exist on the later models. But again, since I have not had a problem, I have not had the need to look.
#8 | |||||
#9 | |||||
![]() Join Date: Jun 2009
Bleed Sealed master/slave in-car with no mess! Worked great 8)
#10 | ||||
![]() Join Date: May 2009
Just because the new system comes with fluid in it already doesn't mean it doesn't have air in it. I had to bleed mine. Have one person tilt (aprx 40 degrees) the master (where the fluid is insterted) and one person press in the metal piece on the slave.
#11 | ||||
Tilt the master with the piece that connnects to the clutch pedal tilted down towards the ground.
#12 | ||||
![]() Join Date: Mar 2009
I've done 3 units so far, which wouldn't shift into gear at a stop because of lack of shift fork travel. Since the old fluid looked like crap I pumped it out and refilled it with full synthetic. You can hook up a Mity Vac to the resevoir and/or pump the slave cylinder. The Mity Vac comes in handy to get the air out of the master cylinder tho, that one you can hear the air when you pump it.
" Under normal usage, small anounts of air remaining will purge itself from the system." +1
#13 | ||||
I made a thread I suggested be put in the How-To section, but it got shot down for some reason.
#14 | ||||
A brand new system with air in it (before installation) is, by definition, defective, and should be exchanged.
| Thread Tools | |
| Display Modes | |
| clutch bleeding | mesared | Ion Tech | 6 | 06-04-2009 06:46 PM |
| clutch bleeding | RobertGary1 | S-Series Tech | 2 | 06-03-2009 12:48 PM |
| Clutch Bleeding? | Brock4u | Vue Tech | 0 | 04-16-2008 07:28 AM |
| bleeding clutch | 92sl24ya | S-Series Tech | 10 | 02-21-2004 06:46 AM |
| clutch bleeding | 94sc2boy | Miscellaneous Tech | 1 | 10-27-2000 10:01 PM |
