Old 09-19-2005, 05:41 PM   #1
rickertee
rickertee is on a distinguished road
Question DTC P0172 Fuel Trim System Rich Bank 1
Does such a thing exist where can I find info that defines all the possible problems and how to eliminate item by item working down the list for DTC P0172?
Add to rickertee's Reputation
Rate the quality of this post and help rickertee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rickertee is offline   Reply With Quote
Old 09-19-2005, 06:40 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: DTC P0172 Fuel Trim System Rich Bank 1
It'll cost you $25, but www.alldata.com probably has the most complete on-line info.
for P0172
POSSIBLE CAUSES
The following are malfunctions that could cause a rich condition:
* Fuel pressure too high. Perform fuel pressure test.
* Leaking fuel injector(s). - Perform pressure leakdown test.
* Vacuum leak around the MAP sensor grommet.
* Oxygen sensor contamination.
* Restricted exhaust or air intake.
NOTE: If the front oxygen reading voltage is above 600 mv and the rear HO2S is above 600 mv all the time, the O2 sensors are probably not at fault.
Add to BarnOwl's Reputation
Old 09-19-2005, 09:09 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
Yes. Saturn Service Manuals have this information in them. each code is listed along with a diagnostic chart with steps to follow to resolve the issue.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 09-21-2005, 01:50 PM   #4
rickertee
Thanks for the info, I also have excessive blow-by coming out of the valve cover when the PVC is taken out, idles rough too. The Saturn folks think it does not need rings (previuos advice from local mechs) but I should but Mobil 1 and see if that cleans it up. The SC2 sat for 6 months while I was in the Middle East, my wife drove it around the block once a week.
Any advice?
Old 09-30-2005, 02:04 PM   #5
rickertee
Would appreciate any guidance, tried Mobil 1, still same problem. Do I need to change the rings?
Old 10-01-2005, 01:10 AM   #6
stanleyr
stanleyr is on a distinguished road
stanleyr's Avatar
1992 SL2
2003 ION-3 Sedan
The rough idle would be from the excessive blow by from the PCV system into your intake. You may have to drive it for some time for Mobil1 to have a chance to clean it all up - about 1000 miles total. Try to make all your trips as long as possible each time you drive - 20-30 miles minimum would be good.
You changed the filter when you changed the oil? Make sure you are going with a high quality oil filter - at least as good as possible with full-flow types. Look for posts in this category and the S-Saturn category for oil filters and see what works and what doesn't.
If you are successful at stopping it, change the oil and the filter again at that time. Even if it is before 3000 miles.
If after all this it still hasn't cured the problem, you should consider a crankcase flush or a top end clean out or both. Lots of posts that cover this too...
Good luck to you.
Add to stanleyr's Reputation
Rate the quality of this post and help stanleyr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stanleyr is offline   Reply With Quote
Another P0172 rich fuel alordofchaos S-Series Tech 14 09-15-2009 01:30 PM
DTC P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1 ivymotorsports S-Series Tech 1 04-26-2009 12:29 AM
P0172 rich code ecraw L-Series Tech 4 07-16-2008 05:30 PM
96 SL2 runnig rich P0172 mulder1fx S-Series Tech 9 05-07-2007 09:37 AM
running rich but not in my bank book Sattyinsnow S-Series Tech 19 04-27-2003 01:02 PM
