Old 05-30-2005, 08:22 AM   #1
radioouman
radioouman is on a distinguished road
radioouman's Avatar
2002 L-Series 2.2L Sedan
Default VTI transmission fluid
My sister-in-law's 2003 VUE with the VTI has 15,000 miles and the transmission fluid is brown. She hasn't complained of any problems with it, but the fluid obviously needs to be changed.
Is there a filter available? Is there a drain plug on this tranny? Which fluid is best?
Any help would be appreciated.
Add to radioouman's Reputation
Rate the quality of this post and help radioouman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
radioouman is offline   Reply With Quote
Old 05-30-2005, 03:50 PM   #2
JPDucketts
JPDucketts is on a distinguished road
Default Re: VTI transmission fluid
the trans fluid for a VTi trans is green in color, not red like traditional tranny fluid(even the factory service manual is wrong). so don't let that throw you off. there is a drain plug on the trans. underneath of course. the fluid I would use is AC Delco DEX-CVT fluid
Add to JPDucketts's Reputation
Rate the quality of this post and help JPDucketts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JPDucketts is offline   Reply With Quote
Old 05-30-2005, 07:52 PM   #3
Quote from the service manual:
Important: The normal use color for DEX-CVT fluid is green or light brown. Fluid may also turn dark brown from normal use, and does not always indicate contamination. Fluid that is very dark or black and has a burnt odor usually indicates contamination or over-heating.
Where is it that you have gotten to the fluid to check the colour? There are some very specific fluid fill and level checking procceures needed for this trans. If not doen correctly you can get the incorrect fluid level. Also you need to use the correct fluid to fill the trans. There are two types right now, the original and a newer one that is used following work on the trans. If you have never had anything done on the trans the original flui d should be used but if you have had it serviced than you most likely need the newer fluid.
Add to ssicarman's Reputation
Old 10-12-2009, 08:59 PM   #4
rayjaybiden
rayjaybiden is on a distinguished road
Roll Eyes Re: VTI transmission fluid
When I rebuilt the trans I put it together with a blue trans assembly lube. Will that contaminate the Dex CVT FLUID & ADDITIVE? Because I am getting a tad bit of shutter when I come to a stop. It is a VT-25E. THANKS.
Add to rayjaybiden's Reputation
Rate the quality of this post and help rayjaybiden reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rayjaybiden is offline   Reply With Quote
5spd Transmission Fluid Change - Fluid? Satsational S-Series Tech 17 10-20-2008 05:57 AM
Vti Fluid Change? LelandC Vue General 8 09-21-2006 02:16 AM
Vti additive/fluid change HfxVue Vue General 13 06-09-2005 09:59 PM
03 VTi Fluid Problem? jdt141 Ion General 7 04-02-2005 10:08 AM
New VTI fluid Lucas1 Miscellaneous Tech 1 08-19-2004 06:18 AM
