Old 04-26-2005, 12:29 AM   #1
Stephannie
Stephannie is on a distinguished road
2005 ION-2 Sedan
Default My key keeps getting stuck in the ignition...
I have a 2005 ion 2, and for some reason, the key keeps getting stuck in the ignition for no reason. I am not a blond, and I know that sometime the steering wheel needs to be in the right positon, and the car needs to be in park. Anyone else have this problem??
Add to Stephannie's Reputation
Rate the quality of this post and help Stephannie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Stephannie is offline
Old 04-26-2005, 09:36 AM   #2
Bertillion
Bertillion is on a distinguished road
Bertillion's Avatar
2004 ION-3 Sedan
2008 AURA XE
Default Re: My key keeps getting stuck in the ignition...
I'm a blond and I did the wasn't in park thing before. My only suggestion would be to use the spare key they gave you. Perhaps there is something wrong with the key itself. Does your instrument panel light up and beep when it wont come out? Passlock system problem perhaps. If you are still under 30 days and 1,500 miles you might want to exchange it to save the hassle of counting on the dealership to fix the problem for you.
"Success is the happy feeling you get between the time you do something and the time you tell a woman what you did." -Dilbert
Add to Bertillion's Reputation
Rate the quality of this post and help Bertillion reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bertillion is offline
Old 04-26-2005, 09:45 AM   #3
DSLaBuda
DSLaBuda is on a distinguished road
DSLaBuda's Avatar
2005 ION-1 Sedan
1997 SL1
i noticed that too, but it only happens rarely. when it happens i can't turn the key or remove it. i found that it i move the wheel in either direction while attempting to move the key it will unstick after 2-3 tries.
Add to DSLaBuda's Reputation
Rate the quality of this post and help DSLaBuda reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DSLaBuda is offline
Old 04-26-2005, 04:03 PM   #4
saturncanuck
saturncanuck is on a distinguished road
saturncanuck's Avatar
2006 ION-3 Sedan
2006 ION-3 Sedan
This sounds like I'm being a smart*** but its an honest question.
Is there a cup in the cupholder? We noticed that a larg mug or Big Gulp with stop the auto shifter from going all the wat forward and not release the key.
Check it out.
Add to saturncanuck's Reputation
Rate the quality of this post and help saturncanuck reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturncanuck is offline
Old 04-26-2005, 04:12 PM   #5
DanielT
DanielT is on a distinguished road
1994 SL
2005 ION-1 Sedan
if they key is getting stuck, i would go to the dealer and spen $5 and get a new key cut, try that first. and if not you might was to have a tech look at the tumblers in the ignition cylinder.
Add to DanielT's Reputation
Rate the quality of this post and help DanielT reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DanielT is offline
Old 04-26-2005, 04:28 PM   #6
Stephannie
2005 ION-2 Sedan
Thanx you guys!! It hasn't happened again, but I'll keep all those suggestions in mind. Honestly, I think that the cup in the cup holder might have been the problem, DUH!!!
Old 04-26-2005, 04:44 PM   #7
Dione
Dione is on a distinguished road
Dione's Avatar
2005 ION-3 Quad Coupe
2002 L-Series 2.2L Sedan
Already had mine car service for this exact problem... it was the shift linkage. It went forward into the Park position but not far enough to disengage the key.
Check the manual it discusses how to remove a little panel under the ignition where you can push a button to remove the key. If that seems to be your issue get it serviced. Mine was in and out in 30 minutes and has never happened again.
-D
Add to Dione's Reputation
Rate the quality of this post and help Dione reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dione is offline
Old 04-26-2005, 05:16 PM   #8
RichSoucie
RichSoucie is on a distinguished road
2004 ION-2 Quad Coupe
this is why MANUAL RULES you guys are screwed if your battery dies i remember reading somthing in the manual that if it dies it wont let you shift into or out of park and the key wont release.
Add to RichSoucie's Reputation
Rate the quality of this post and help RichSoucie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RichSoucie is offline
Old 04-26-2005, 06:29 PM   #9
KevinF
KevinF is on a distinguished road
KevinF's Avatar
Pop-starting a manual car is fun when the battery is dead
Add to KevinF's Reputation
Rate the quality of this post and help KevinF reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KevinF is offline
Old 04-26-2005, 11:11 PM   #10
DSLaBuda
DSLaBuda's Avatar
2005 ION-1 Sedan
1997 SL1
so why does it happens on mine and i have a manual?
lol, this is just another item on my list to bring to the dealer
DSLaBuda is offline
key stuck in ignition racegirlfor1 Ion General 14 07-03-2013 06:33 PM
Key stuck in ignition Ziek Aura General 6 10-13-2006 04:22 PM
Key stuck in ignition Maui Jim S-Series Tech 11 10-06-2006 12:36 PM
Spare key gets stuck in ignition, main key doesn't 94sc293sl1 S-Series Tech 7 07-12-2004 12:03 AM
Key stuck, very hard to remove key from ignition... Actaeon S-Series Tech 7 12-21-2003 12:08 AM
