Old 04-09-2005, 01:33 PM   #1
RicksVue
RicksVue is on a distinguished road
RicksVue's Avatar
2008 Astra XR
Question LS2 Water Pump and the timing belt
My neighbor has a 2000 LS2 (V6), around 58,000 miles. He recently had it in to the local retailer for an oil change where the tech reported a problem with the water pump. It's reportedly going bad and needs to be replaced - he was told that if the water pump goes bad, it's connected to the timing belt and can cause engine destruction if it seizes.
I thought the accessory belt on the V6 was separate from the timing belt. Is there *really* some connection there? There's no indication of problem with the water pump - no noise, no coolant loss, etc. It's a pretty expensive repair (and apparently requires special tools.) I recommended waiting until there's a real indication of a problem before spending the money.
Is there any truth to the story that water pump failure can eat the engine? Is there a problem with the L-Series water pump, and if so what's the symptoms to be looking for?
Thanks.
-Rick
Add to RicksVue's Reputation
Rate the quality of this post and help RicksVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RicksVue is offline
Old 04-09-2005, 01:53 PM   #2
Default Re: LS2 Water Pump and the timing belt
The V-6 water pump is not in contact with the timing belt in any way. If it is leaking the coolant can get onto the timing belt which is not good for the belt.
The labour time to replace the pump is aound three hours (approx) flat rate. No real special tools involved other than an engine support as the front engine mount needs to come off and it is not reccommended to support the engine on the aluminum oil pan. You do need a selection of torx bits and sockets.
Add to ssicarman's Reputation
ssicarman is offline
Old 04-09-2005, 03:23 PM   #3
RicksVue
RicksVue's Avatar
2008 Astra XR
Thumbs Up Re: LS2 Water Pump and the timing belt
Thanks. I'll pass the info on.
-Rick
RicksVue is offline
just did my timing belt/water pump with PICS! nitroussaturn Vue Tech 109 03-21-2016 11:19 AM
New Water Pump/Timing Belt - 90K danf L-Series Tech 6 03-14-2007 05:04 PM
2000 LS2 Water pump replacement ikkie78 L-Series General 2 03-09-2006 09:57 AM
Water pump/timing belt on 03 VUE FWD V6 johnbasler Vue Tech 5 01-10-2006 10:35 AM
Did the Timing Belt and water pump today... what a ripoff!! marmaduke L-Series General 3 07-15-2005 10:59 PM
