Old 10-22-2004, 07:34 PM   #1
dantheman70
dantheman70 is on a distinguished road
Default Emissions and sensors, 99 SL1
Recently, my1999 SL1 failed emissions inspection in Maryland:
Code P0452 EVAP Control System Pressure Sensor Low Input
Took it to a mechanic, and he replaced the fuel cap. Went for reinspection, and the same failure code was produced.
The mechanic thinks it's the sensor, although his initial check of the sensor showed that it was fine.
The car has had little wrong with it other than a recent brake job. It has ~64,000 miles. I bought it brand new.
My question - and I realize this may not be answerable - is this: How much do you think a new sensor will cost? Does anyone here have an idea of the range?
I'm hoping the biggest part of the bill will be the labor.. Any help appreciated, TIA.
Add to dantheman70's Reputation
Rate the quality of this post and help dantheman70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dantheman70 is offline
Old 10-22-2004, 11:50 PM   #2
wrg813
wrg813 is on a distinguished road
Default
P0452 is not a common code for that year or model. Once the fuel cap was replaced, were the codes cleared?
Add to wrg813's Reputation
Rate the quality of this post and help wrg813 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wrg813 is offline
Old 10-23-2004, 12:07 AM   #3
dantheman70
Default
That's a good question, wrg813. I thought they had been. The SES light, which had been on prior to the fuel-cap replacement, was not on when I drove the car home. However, the next day, it was back on.
So the short answer - I dunno. I'll have to ask the mechanic to recheck that before he does any real work on it.
Old 10-23-2004, 12:13 AM   #4
wrg813
Default
Did the SES light come on before reinspection or after?
wrg813 is offline
Old 10-23-2004, 12:16 AM   #5
dantheman70
Default
Before. IT came on when I started the car that morning. After work, I went over to the inspection station. It never went off.
Old 10-23-2004, 12:23 AM   #6
wrg813
Default
I pm'd you with my htmail, I will try and send you in the right direction. Instant message!
wrg813 is offline
Old 10-23-2004, 08:14 AM   #7
dantheman70
Default
Whoops, didn't see this before I finally went to bed for the night..
Old 10-23-2004, 08:24 PM   #8
wolfman
wolfman's Avatar
Default
The pressure sensor is in the fuel tank. Part of the fuel pump module. Replacement requires removing the tank. (Sorry) in past instances I have found however that the sensor rarely fails. It is most likely (in order of probability)
1. Bad gas cap.
2. Loose rubber sleaves on filler pipe to tank junctions causing a vacuum leak
3. Bad/loose wiring to the sensor at the splice pack located under the carpet, driver's side trunk wheel well area.
4. Loose or bad hose connection at the carbon canister, CCPS (carbon canister purge solenoid) or tank vapor line at the tank.
5. HOLE in the gas tank. (Seen people drill right into the top of the gas tank on occasion when installing a stereo amp in the trunk area of the car)
Add to wolfman's Reputation
wolfman is offline
Old 10-23-2004, 08:43 PM   #9
dantheman70
Default
Well, we know it's not the gas cap, because that was replaced.
I hope the fuel pump or tank don't need to be replaced. That I surely can't afford.
In a perfect world, the parts will cost less than the labor. I know removing/reinstalling the pump or tank is time consuming.
I don't seem to be leaking gas, so I don't think #5 is applicable. I could be wrong, though.
Old 10-23-2004, 09:24 PM   #10
wolfman
wolfman's Avatar
Default
The hole could be on the TOP of the tank (hence the drill through senario I posted) Anything that allows air to free flow into or out of the tank in anything other than a VERY slight amount will trip the tank pressure sensor and SES light. Pull up the velcro attatched trunk carpet where it meets the rear seat bottoms in the trunk and look at the sheet metal. Any sign of drilled holes are suspect. If you do find one. Simply installing a tight fitting sheet metal screw with some RTV sealant on the threads will usually reseal the hole and fix this issue. (Ask me how I know that)
wolfman is offline
Old 10-23-2004, 09:44 PM   #11
dantheman70
Default
I'll look for the drilled holes tomorrow morning.
I've added your comments to the note I've written to the mechanic - I'm dropping the car off Monday morning.
I suspect it'll cost four arms and eleven legs, which I can't afford.
I greatly appreciate the help here, guys.
Old 10-24-2004, 11:37 AM   #12
dantheman70
Default
Update - I did look for the holes. Saw nothing at all.
Old 10-25-2004, 06:50 AM   #13
wrg813
Default
Sorry, but I've been away from the comp. Wolfman has given you very good and complete advice. Let me add... make sure the new fuel cap is OEM. P0452 actually has to do with low voltage. Battery replaced recently? Once the code is confirmed cleared and the SES light does not come back on, you will have to go through a drive cycle to get the I/M(inspection/maintenance) part of the PCM to read ready or pass.
wrg813 is offline
Old 10-25-2004, 07:11 AM   #14
dantheman70
Default
Drive cycle as in...... start 'er up, drive around, turn 'er off? Does that constitute a cycle?
The battery has not been replaced recently. Wouldn't it be something if that's all it was? In fact, I'm pretty sure it's the original.
Old 10-25-2004, 07:14 AM   #15
Mork
Mork is on a distinguished road
Default
Check all houses in the EVap system. If none are off or broken,
replace the pressure sensor located on the top of the float assembly. This will cure the problem. been there done that.
Add to Mork's Reputation
Rate the quality of this post and help Mork reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mork is offline
Old 10-25-2004, 08:05 AM   #16
wrg813
Default
Drive cycle for Pcm being 50 or more miles under various conditions. Try a search for "Drive Cycle". I believe someone posted a GM example that should work for Saturn.
wrg813 is offline
How many Oxygen sensors in 1998 Saturn sl1 WadeNKC L-Series General 3 05-12-2009 12:51 PM
96 sl1 california emissions or not? irondiezl3 S-Series Tech 1 03-29-2007 05:59 PM
1996 SL1 Emissions Trauma Mooncet S-Series Tech 15 01-14-2007 06:24 PM
2000 sl1 failed emissions test.. HELP maroman84 S-Series General 5 10-14-2005 09:26 AM
96 SL1 02 Sensors - Up & Down Stream parakris S-Series Tech 11 03-20-2002 08:55 PM
