Old 10-06-2004, 11:49 AM   #1
Blue Goose
Blue Goose is on a distinguished road
Blue Goose's Avatar
Default How much oil does the 3.5L hold?
I don't have the manual handy but need this info...anyone know offhand capacity it takes...??
2011 Chevrolet Silverado LT 4x4
Add to Blue Goose's Reputation
Rate the quality of this post and help Blue Goose reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Blue Goose is offline
Old 10-06-2004, 11:53 AM   #2
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
Default
4.5 quarts with the OEM filter.
Gives me a half quart left over to use in my tractor.......
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bill Murray is offline
Old 10-06-2004, 12:11 PM   #3
Blue Goose
Blue Goose's Avatar
Default
Thanks!
Also is the 5w20 synth or not synth? I'm bringing my own tonight My SM says dino but not sure if I believe him
Old 10-06-2004, 01:21 PM   #4
TomH
TomH is on a distinguished road
TomH's Avatar
Default
The 5w20 oil that comes to us from Saturn is a dino oil.
There's no reward for failure..........but death!
Add to TomH's Reputation
Rate the quality of this post and help TomH reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TomH is offline
Old 10-06-2004, 02:36 PM   #5
Qlara
Qlara's Avatar
Default
FYI if you do own oil change....
The drain plug is like 17mm.
The Filter for this Jap motor is so small in diameter (compare to the oil filter in compact S-series car). I actually need to buy a small-size filter wrench just for this....yuck!
Require a steady hand to refill fresh oil (or simply require a funnel). The fill-hole is so low and tiled to a clumsy angle.
Trivia:
Oil dip-stick is in Orange? color, and awkward to pull out without using both hands.
ATF dip-stick is in Yellow? color......how so-not intuitive.
On contrary: Dip-sticks in Saturn's S-series:
ATF is red, Motor oil is Yellow.
VUE also has Oil Monitor system:
The oil light no longer has English written "Change Oil Soon". It's an icon with a Wrench + Oil Cup.
To Reset the light after oil change, you need to FLOOR the gas padel 3 times within 5 seconds while the key is in RUN. (Must sure Motor is NOT running!)
It's 4.5Q for Oil, but I dump in 5 bottles of 0W-20 instead....the heck of 0.5Q, my Honda motor didn't complain anyway.
Add to Qlara's Reputation
Qlara is offline
Old 10-06-2004, 04:14 PM   #6
rickpa75
rickpa75 is on a distinguished road
rickpa75's Avatar
Default
I put the full 5 in also - Mobil 1 (5w-30)
-Rick
Add to rickpa75's Reputation
Rate the quality of this post and help rickpa75 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rickpa75 is offline
Old 10-06-2004, 07:15 PM   #7
sspeer
sspeer is on a distinguished road
sspeer's Avatar
Default
I think I used all of 5 qts...I don't have a half empty bottle of Mobil 1 0w20 sitting around at least..
Add to sspeer's Reputation
Rate the quality of this post and help sspeer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sspeer is offline
Old 10-06-2004, 07:58 PM   #8
corympak
corympak is on a distinguished road
corympak's Avatar
Default
Could someone convert quarts to litres, please!
1-2003 Jeep Rubicon
1-Bubble Blowing Lawn Mower
Add to corympak's Reputation
Rate the quality of this post and help corympak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
corympak is offline
Old 10-06-2004, 08:23 PM   #9
LATEMODELRACING
LATEMODELRACING is on a distinguished road
Default
5 qts. in the 3.5 is recommended. yeah that darn filter is small.
Add to LATEMODELRACING's Reputation
Rate the quality of this post and help LATEMODELRACING reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LATEMODELRACING is offline
Old 10-06-2004, 08:27 PM   #10
bigbird
bigbird is on a distinguished road
bigbird's Avatar
Default
1 US quart = 0.94635295 L
4.5 US quarts = 4.2586 L
Add to bigbird's Reputation
Rate the quality of this post and help bigbird reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigbird is offline
Old 10-06-2004, 08:38 PM   #11
Dante
Dante is on a distinguished road
Dante's Avatar
2004 VUE Red Line
Default
I've varied between 4.5 and 5 quarts. I think it depends on how warm the oil is when you go to drain it (colder oil = more viscous -> requires more time to drain, I get impatient, say screw it, cap it up and fill 'er up). I put in 4.5 qts and top off until it reads full on level ground on the dipstick cold. I check the stick again after heating the engine up (first drive afterwards) and make sure it's not overfilled or leaking.
Needless to say, my mower (also Powered by Honda :P ) gets *really* darn fine oil in it (leftovers from Vue).
Tupperware cars FTW!!!
Add to Dante's Reputation
Rate the quality of this post and help Dante reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dante is offline
Old 10-07-2004, 08:36 AM   #12
Bill Murray
1997 SC1
1997 SC1
Default
Originally posted by Blue Goose
Thanks!
I'm pretty sure the 5W20 from the factory is dino.
I'm using Mobil 1 5W30 summer and 0W30 winter changing twice a year with about 5000 miles between changes.
This is overkill but I've always been a Mobil fan.
Over on www.bobistheoilguy.com they seem to like the Ford Motorcraft 5W20 which is a synthetic blend you can get at WalMart for 1.42/quart.
Old 10-07-2004, 03:23 PM   #13
Qlara
Qlara's Avatar
Default
I have to mention that Mobil-1 now also has 0W-20 SuperSyn....the label has a big stamp saying it's specific for Ford & Honda motors.
5w-30 should work in this Honda motor, but I'd rather avoid any finger-pointing.
Got the M-1 0W-20 from Pepboys, just FYI.
Qlara is offline
Old 10-08-2004, 08:39 AM   #14
Bill Murray
1997 SC1
1997 SC1
Default
Interestingly in Europe Honda specs 20W50 for their engines for operation above +10F - probably to stand up to autobahn conditions.
So the thin weights spec'd for the USA are primarily driven by CAFE fuel mileage.
Old 10-08-2004, 08:52 AM   #15
rickpa75
rickpa75's Avatar
Default
It just scares me to put 0w anything in an engine. Especially in these advance engines, friction is always going to be a problem. With dino oil, they need the low oil weight for fuel mileage, but synthetic is soo good now. Also, I believe Mobil 1 20w-50 flows @ -15 degrees F, so there is really no need to change summer\winter.
-Rick
rickpa75 is offline
Old 10-08-2004, 09:34 AM   #16
BlueDevil
BlueDevil is on a distinguished road
BlueDevil's Avatar
Default
i prefer using synthetic blends. i have found in the past with my mustangs that pure synthetic gets really thin at higher temperatures, regardless of weight. i look at it like this: conventional for viscosity consistency, synthetic for start up protection.
Add to BlueDevil's Reputation
Rate the quality of this post and help BlueDevil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlueDevil is offline
Old 10-08-2004, 12:52 PM   #17
Blue Goose
Blue Goose's Avatar
Default
hmmmm Have you guys noticed that after you put all 5 qts in that the oil is really high on the dipstick? I just checked and my reading is up on the letters(rbg or something like that) on the dipstick. In other words over the full mark.
When I questioned where my 1/2 of bottle of oil was after the change the SM said that the Vues take all 5 qts...apparently not
So I imagine everyone who has put all 5 in should also be overfilled? Usually this is a bad bad thing but is there something diff with the 3.5 that will let you get away with it?
Old 10-08-2004, 12:54 PM   #18
BlueDevil
BlueDevil's Avatar
Default
a half quart is not really enough to cause any problems.
i understood that it took 4.5 quarts.
Best way to hold L300 oil filter housing (to prevent spinning)? linuxdude L-Series Tech 8 11-04-2014 11:01 PM
How much oil does the 3.6 hold? bgates2b Aura General 1 08-24-2007 07:30 AM
How long can I hold it? sl2gold S-Series General 10 08-16-2007 11:28 PM
Orders on hold? duke15 Sky General 12 05-05-2006 10:27 AM
How many quarts of oil dose the 3.5L motor hold? snowdog Vue General 5 01-16-2004 07:26 AM
