Old 03-29-2004, 10:28 PM   #1
hummers86
hummers86 is on a distinguished road
Default Oil Pressure Sending Unit
Hey guys got a question for ya. I was under my saturn takin the alternator out when I noticed the oil pressure sending unit was unplugged the part on the engine has a piece of plastic busted off so I cant plug the wire back in. I havent noticed any problems with the car so i was wonderin if this needs to be replaced immediatly? How easy it is to take out and replace? And what exactly the sensor is for? Thanx
Add to hummers86's Reputation
Rate the quality of this post and help hummers86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hummers86 is offline
Old 03-29-2004, 11:10 PM   #2
pcfixer_VA
pcfixer_VA is on a distinguished road
pcfixer_VA's Avatar
Default
If you ever do or did have a low oil pressure situation, such as a low oil level you will not know until it's too late... Don't underestimate the importance of the low oil pressure light!!
Otherwise it will not make a difference.
Someone correct me if I am wrong. It connects the wire that is plugged into to it to ground when the oil pressure is too low. This makes the oil light illuminate on the dash.
Add to pcfixer_VA's Reputation
Rate the quality of this post and help pcfixer_VA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pcfixer_VA is offline
Old 03-29-2004, 11:52 PM   #3
wolfman
wolfman's Avatar
Default
YES oil pressure of around 8 psi or UNDER will short the oil pressure sender to ground and light the "OIL" light on the dash. The sender just screws directly into the oil rail on the block, and is relatively easy and cheap to replace.
Add to wolfman's Reputation
wolfman is offline
Old 03-30-2004, 12:10 AM   #4
hummers86
Default
Thanx a lot again so im guessin the dealer sells it?
Old 03-30-2004, 08:22 AM   #5
pcfixer_VA
pcfixer_VA's Avatar
Default
Yes.
location of oil pressure sending unit? RKelly5327 L-Series General 4 06-22-2009 05:58 PM
Oil Pressure Sending Unit Sensor rockermikey S-Series Tech 8 07-16-2008 11:16 AM
Where Is The Oil Sending Unit 93 Sl1 johnholl S-Series Tech 1 10-09-2007 11:28 AM
Where is the oil pressure sending unit located? z28com Ion Tech 11 05-07-2007 08:10 PM
Oil sending unit bad? bennett9000 S-Series Tech 5 08-18-2006 02:04 PM
