Old 12-08-2003, 10:59 AM   #1
donosborn
donosborn is on a distinguished road
Default '95 Saturn SL1 - alternator removal question
Hi,
I have been trying to remove the alternator from my '95 Saturn SL1 sedan. I finally got it entirely unscrewed and it is loose. However, for the life of me I can not pull it out of the engine. It is too small of an area for it to come down. I can't even get it below that bottom piece of metal where the main, lower bolt passes through.
I have the front wheel off as well as some plastic piece that was behind the wheel.
Does anyone have any advice? I would appreciate it.
thanks
Don
Add to donosborn's Reputation
Rate the quality of this post and help donosborn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
donosborn is offline
Old 12-08-2003, 11:33 AM   #2
IDB
IDB is on a distinguished road
Default
if you have the bolts off the only thing you can do is wiggle the hell out of it untill it comes out.. its a pain i know but thats realy the only way you will get it out
Add to IDB's Reputation
Rate the quality of this post and help IDB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IDB is offline
Old 12-08-2003, 01:47 PM   #3
dixonba
dixonba is on a distinguished road
dixonba's Avatar
2007 ION-2 Sedan
Default
it can be done...
I got it out through the wheel well splash guard.
You could also try unbolting the power steering and moving it to the side...its only three bolts.
Add to dixonba's Reputation
Rate the quality of this post and help dixonba reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dixonba is offline
Old 12-08-2003, 01:54 PM   #4
TedL
TedL is on a distinguished road
Default
Remove pass side wheel, and splash guards. Alt comes out through space behind the strut.
Add to TedL's Reputation
Rate the quality of this post and help TedL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TedL is offline
Old 12-08-2003, 02:43 PM   #5
amazinghl
Default Re: '95 Saturn SL1 - alternator removal question
Take that bar off, it's only coupe of bolts.
I did.
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 12-08-2003, 02:54 PM   #6
donosborn
Default Re: Re: '95 Saturn SL1 - alternator removal question
I did.
Really? That would do it. I didn't see where that piece comes off. If we are talking about the same piece, that is. The piece I am talking about looks like it is just part of the whole engine block. Maybe it's not. Hmm.
thanks
don
Old 12-08-2003, 03:42 PM   #7
Saturn-Eh!
Saturn-Eh!'s Avatar
Default Re: Re: Re: '95 Saturn SL1 - alternator removal question
thanks
don
I think AmazingHL is referring to the intake brace that is present on DOHC equipped cars. That peice would not be present on a SOHC...
I'm assuming that you have power steering, as removing the alternator from an SL is easy, right out the top. It's likely that the P/S lines are preventing you from getting the alternator back past the block. Just unclip the lines (in their retainer bracket) from the rack, and push them back over the rack. then push the alternator toward the driver's side of the car while wiggling it past the P/S lines. Once past the lines, the alternator will drop down and be removable through the wheel well.
All this assumes that you have the alternator off the block (big aluminum part the bolt goes through. If the alternator wont come off of this, pry gently between the alt and the block with a medium sized screw driver.
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline
95 Saturn sl1 Alternator dilemma Please Help!! chrisnband L-Series Tech 4 05-11-2009 04:10 PM
Alternator removal 1994 sl? sixxxofus S-Series Tech 5 03-05-2009 12:30 AM
'02 VUE alternator removal question frog8546 Vue Tech 1 12-14-2004 01:04 PM
Alternator removal.....you must be joking! Twin_Cam Miscellaneous Tech 12 10-11-2003 04:57 PM
95 SL2 Alternator removal? CorradoKidd S-Series General 4 07-26-2003 03:15 AM
