Old 07-08-2003, 07:55 PM   #1
scrt69
scrt69 is on a distinguished road
Default knocking sound from suspension..
Has anyone ever had any problems with strut mounts on a 94 sc clunking at low speeds?....sounds like the mount is non existant..but only at low speeds // 25-40km/h and on a bumpy road (bad parking lot)
any ideas????
Add to scrt69's Reputation
Rate the quality of this post and help scrt69 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scrt69 is offline
Old 07-09-2003, 04:10 AM   #2
2fast4all
2fast4all is on a distinguished road
2fast4all's Avatar
Default
Yes I have the same thing I told me local Saturn dealership to check my motor mounts, it happens to be that the mounts are a little weak You can get an upgread, to motor mounts from SaturnMotorSports.com for $137 Buy the way did you know that when you get up to 5mph the anti lock breaks make a little noise, but if that is not it then it's your mounts.
Add to 2fast4all's Reputation
Rate the quality of this post and help 2fast4all reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2fast4all is offline
Old 07-09-2003, 06:39 AM   #3
vtunderground
vtunderground is on a distinguished road
vtunderground's Avatar
Default
If the Twistec group buy is going on, you can get the same mounts for $85. Good deal. http://www.xtremesaturn.com/phpbb/viewtopic.php?t=13387
Add to vtunderground's Reputation
Rate the quality of this post and help vtunderground reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vtunderground is offline
Old 07-09-2003, 08:35 AM   #4
eRic 02sc2
eRic 02sc2's Avatar
Default
take a look at the engine and transaxle mounts. the torque axis mount. also check the strut bearings. and the lower control arm bushings.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 07-09-2003, 09:53 PM   #5
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
S-series will exhibit a rattle/clunk noise from the front struts, that is most noticable at parking lot speeds, this is quite common, and not much to worry about, unfortunately, the only cure is to replace the front struts (if the noise is indeed coming from the front)
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline
Old 07-10-2003, 08:15 AM   #6
scrt69
Default
thank you all for your responses.... as from what i noticed the other week, the upper engine mount was TOAST!!! so ever since i replaced that, it has been 100% better, but still not good enough.
willl prob put on KYB struts, and then lower. hopefully everything will be good and ready by then.
thanks again.!!
scrt69 is offline
L200 Knocking Sound (Suspension) lymanhall44 L-Series Tech 7 10-10-2009 02:12 PM
Knocking sound chris422 Outlook General 2 09-26-2008 10:22 AM
front left suspension knocking gord888 Ion Tech 2 12-01-2006 05:38 PM
Knocking sound saturnpowersw2 S-Series General 3 05-31-2006 08:50 AM
SL2 suspension knocking, exhaust issue, A/C Rozzwell S-Series Tech 2 06-08-2005 09:39 AM
