Old 12-14-2011, 08:41 AM   #1
dsquare86
dsquare86 is on a distinguished road
2002 SL1
2001 SL2
Default Bucking Under Light Load and Then Stall
Ok guys, this one is a bit tricky. Whenever I am taking one certain exit off the interstate that has a moderate uphill grade, it requires light throttle in order to maintain speed until the end of the ramp where we stop. During light throttle the car will begin to buck, if this continues then the car will stall and restarting is very difficult. Once started car acts like nothing ever happened.
The following items are new on the car:
Air Filter, Plugs, Wires, ICU, EGR, TPS, IAC, Fuel Filter/Regulator (Napa), CPS, ECTS, IAT, Upstream O2 Sensor, Throttle Body Cleaned.
The car is only throwing a CEL for secondary air pump.
I am starting to suspect the fuel pump or the MAP sensor. Advice?
2001 SL2 246k, 5 Speed. Recently replaced the head.
Add to dsquare86's Reputation
Rate the quality of this post and help dsquare86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dsquare86 is offline   Reply With Quote
Old 12-14-2011, 09:53 AM   #2
RobCampau
RobCampau is on a distinguished road
1993 SC2
Default Re: Bucking Under Light Load and Then Stall
Could very well be a fuel pump. Check the fuel pressure.
Add to RobCampau's Reputation
Rate the quality of this post and help RobCampau reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RobCampau is offline   Reply With Quote
Old 12-14-2011, 11:16 AM   #3
dsquare86
2002 SL1
2001 SL2
Remind me again what fuel pressure should be?
Old 12-14-2011, 06:40 PM   #4
SC2BuzzBomb
SC2BuzzBomb is on a distinguished road
With 246K on the ticker, it appears this car is ready to give up the ghost and be flushed down the cosmic toilet.
Add to SC2BuzzBomb's Reputation
Rate the quality of this post and help SC2BuzzBomb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SC2BuzzBomb is offline   Reply With Quote
Old 12-14-2011, 06:54 PM   #5
dsquare86
2002 SL1
2001 SL2
Thanks but that's no help.
Old 07-03-2012, 10:06 AM   #6
dsquare86
2002 SL1
2001 SL2
Sorry to revive old threads but this issue was addressed by gutting the pre-cat and replacing the main catalytic converter.
Derek
2002 Saturn SL1 SOHC 5 Speed.
2001 Saturn SL2 DOHC 5 Speed - Retired.
Old 07-03-2012, 01:13 PM   #7
RobertGary1
Curious, did you use a back pressure gauge to determine that or trial-and-error?
Old 07-03-2012, 01:44 PM   #8
dsquare86
2002 SL1
2001 SL2
Neither. The catalytic converter saga is detailed in this thread. In hindsight my catalytic converter was ailing my car for a long time. This thread was the initital symptom. It progressed to the point that the car would idle ok, but did not have enough power to even go up a relatively flat driveway and the exhaust was actually exiting the exhaust manifold gasket. My muffler has had holes in it for many years and towards the end of the original cat, it was actually very quiet.
Derek
SES Light, Missing Under Load danf L-Series Tech 4 08-02-2010 10:37 PM
1994 SL1 Bucking under light load tinsley207 L-Series Tech 0 09-14-2009 08:52 AM
Erratic idle, stall at light load, esp. when turn a/c off Ronborsk S-Series Tech 14 05-11-2006 09:04 AM
Red Battery Light Under Load marcusa S-Series Tech 19 03-30-2006 11:23 AM
Bucking when under load MCEDENO S-Series Tech 6 09-24-2003 05:44 AM
