Old 09-18-2011, 09:02 AM   #1
budweiser1993
budweiser1993 is on a distinguished road
Default 2001 sc2 wont start
hi new member here. i changed sparkplugs ngk of course wires and coil packs. now when i try and start my saturn it turns over but wont start.if i push on the gas pedal when cranking it will start then die. if i rev the engine for about a minute it will idle and run fine any help will be appreciated
Add to budweiser1993's Reputation
Rate the quality of this post and help budweiser1993 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
budweiser1993 is offline   Reply With Quote
Old 09-18-2011, 09:24 AM   #2
Default Re: 2001 sc2 wont start
Welcome to the Board.
Sounds typical of a bad ECTS (coolant temp sensor) and connector especially if the engine is chugging when you rev it to keep/get it running.
If it only happened once then I might think that you had some oil in the plug wells that got into the engine and caused the problem but if it is all the time then that is doubtful.
Did you do anthing else to the car with the plug, wire and coil change?
Add to ssicarman's Reputation
Old 09-19-2011, 11:25 AM   #3
budweiser1993
no thats all i did i was thinking maybe i knocked a connecter off or something i replaced the sensor about a year ago
2001 sl1 wont start zglass93 S-Series General 4 06-25-2011 02:25 PM
Help 2001 L200 2.2l Wont Start kanondel L-Series Tech 3 02-21-2011 10:58 AM
2001 L100 wont start SaturnTom L-Series Tech 7 11-19-2008 07:36 PM
2001 L100 wont start SaturnTom L-Series Tech 0 11-14-2008 05:21 PM
2001 SC2 wont start between5and7 S-Series General 5 06-15-2005 10:47 AM
