Old 09-13-2011, 05:24 PM   #1
Bustinlips
Bustinlips is on a distinguished road
Default No spark on a 1996 SL2
Hello everybody,
I am looking for some help on a 1996 SL2 that is not getting spark. I have replaced the crank sensor, starter, the coil packs are new and all fuses appear to be good. I am still getting no spark. I tested the plastic fitting below the coil packs and I am getting power to there but not to the coils. The engine cranks and the battery is new in '09. Any ideas on what may be the problem?
Add to Bustinlips's Reputation
Rate the quality of this post and help Bustinlips reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bustinlips is offline   Reply With Quote
Old 09-13-2011, 06:37 PM   #2
Default Re: No spark on a 1996 SL2
Usually the cps fails first but a few ignition control modules fail with the same effect - a no spark condition. The icm is what the two coils plugs into. If you can, buy a used set of coils and icm from a junk yard as they're cheaper and work just as well as new ones costing more.
Old 09-13-2011, 08:33 PM   #3
^^^^^ +1; buy at the pick & pull junkyard, put the coils on the module and bring it to the office as one assembly, say it's "a coil", and you'll probably only be charged a one-part price.
Add to madpogue's Reputation
Old 09-13-2011, 09:45 PM   #4
Bustinlips
Is there any way to test the ICM so I don't waste anymore money. It looks like the ICM is around $300
Considering I only paid $300 for the car I am a little hesitant to put anymore money into this thing.
Old 09-13-2011, 09:51 PM   #5
Well, you have a choice to try a junk yard for used parts at very low cost, shop ebay for the same, check the icm (maybe) at Autozone(?) or buy a new expensive replacement.
Old 09-13-2011, 09:53 PM   #6
Wrecking yard. ICM's don't go bad very often so it's a good way to go. That said make wure that you have the crank sensor in the block all the way and the connector in the sensor all the way.
When you say that the fuses all appear to be good did you make sure with a test light? Power on both sides of the fuses?
Add to ssicarman's Reputation
Old 09-14-2011, 09:18 PM   #7
Bustinlips
I found an ICM for 25 bucks so I will be putting that in soon. I'll let you know as soon as I find out if that is the culprit. Would a bad battery connection cause no spark? I didn't test the fuses but they all look like they should work. The EIS and both PCM fuses have been swapped out for new ones just for S's & G's. Thanks for the replies so far
Old 09-15-2011, 08:53 PM   #8
Bustinlips
Put the ICM tonight and it started right up. Thanks guys for the advice!!!
1996 SL2 Stalls when warms up... then no spark, until it cools down. Nick96'SL2 S-Series Tech 18 01-20-2011 01:25 PM
1996 sl1 Spark Plug Gap lost_wreckage S-Series General 5 09-30-2010 09:59 AM
1996 sl1 with no spark dmlewis S-Series Tech 2 09-29-2008 07:04 AM
1996 sc1 spark plug wires ken54501 S-Series Tech 3 02-25-2007 09:00 AM
Spark Plug Gap on early 1996 SL2 andybot2000 S-Series Tech 13 09-18-2004 10:08 PM
