Old 07-10-2011, 04:45 PM   #1
DrewHetzer
DrewHetzer is on a distinguished road
Default No Reverse 2000 Saturn S DOHC automatic
I have searched the forum and I don't think it is the "reverse slam." I am new to the forum and am unfamiliar with the term but I assume it has to do with a hard kick when putting the car in reverse. All of the other gears work fine but after putting the car in reverse it won't go anywhere while hot. After it cools then it feels like it is slipping but it went enough to back it into the garage.
These are some options I have researched:
- Replace the input shaft nut
- Replace the valve body
- Replace the transmission
It is my girlfriends car and has lacked maintenance. Checked the fluids and it is full. What should I replace first? I have experience with working on cars but mostly Manual Nissans. Any input would be greatly appreciated!
Thanks,
Drew
Add to DrewHetzer's Reputation
Rate the quality of this post and help DrewHetzer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DrewHetzer is offline   Reply With Quote
Old 07-10-2011, 04:57 PM   #2
DrewHetzer
Default Re: No Reverse 2000 Saturn S DOHC automatic
Also the engine is back against the firewall so I probably need to replace a motor mount as well. I have mounts from a manual saturn s series. Are the automatic transmission mounts the same as manual ones?
Old 07-10-2011, 10:43 PM   #3
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
2003 VUE 2.2L
Welcome to the forums!
I would replace your fluid and conduct the reverse slam cure all.
Summarizing,
1. Change fluid and filter
2. Refill with new fluid and Prolong transmission treatment (any tranny treatment will do.
3. Set the parking brake and chock two wheels from the back
4. Start the car and set in reverse.
5. Let it idle there, in reverse, for 30 mins.
6. Change the fluid and filter again and see if that fixed it.
If that does not fix it, I would go with replacing and retorquing your input nut.
Basically, if it's slamming, you still have hope, if no reverse at all, it's a nut retightening:
http://www.saturnfans.com/forums/sho...d.php?t=112858
shawn
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
problem removing engine 2000 SL2 automatic DOHC mjm S-Series Tech 16 05-15-2009 12:33 PM
2001 Saturn SL1 Automatic - NO reverse problem (grinds) kim_lombard S-Series Tech 5 09-03-2008 07:38 PM
2000 Saturn SL2 wont reverse... sheena477 S-Series General 3 12-12-2006 12:09 AM
1999 Saturn S-1 Has no Reverse (automatic) aeromech S-Series Tech 17 05-26-2006 09:01 PM
New (sort of) Saturn SC2 2000 Automatic Bigsmoker S-Series Tech 4 11-07-2002 07:44 PM
