Old 06-22-2011, 08:37 PM   #1
bob16652
bob16652 is on a distinguished road
Default 2000 saturn ls/ls1 speedometer not working
Hello all we have a recently acquired saturn l series sedan that is continually throwing a po502 code and the speedometer is not working. The speedometer will cut in and out at times but typically does not work. I looked high and low and the only speed sensor i can find is on the passenger side of the vehicle and i am assuming that this is the sensor i am after. I pulled it all apart tonight and the wires and connections were all good. I need some further advice does it sound like a sensor? The wrench is on as well as the ses light and the security light. The air conditioning is also not working but I have not checked into it yet i suspect it could be low on coolant. help please
Add to bob16652's Reputation
Rate the quality of this post and help bob16652 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bob16652 is offline   Reply With Quote
Old 06-22-2011, 10:39 PM   #2
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
Default Re: 2000 saturn ls/ls1 speedometer not working
If you have a manual transmission, the speed sensor is located on the right front wheel bearing. It is the same type of sensor used for ABS, but if you have MTX you won't have ABS. If you have an automatic transmission the speed signal is from a sensor on the transmission. It would be a big help to people if you can fill in the blanks (engine. transmission) and get the codes pulled and posted here.
Cars this age are showing leaks in the aluminum piping of the AC system. Two common places are at a tube clamp under the air filter and at the flex hose connection on the line next to the compressor. Look for some recent posts on this.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-23-2011, 12:21 AM   #3
bob16652
Yes sorry the car has a manual transmission and i did find the one sensor on the right wheel i had a look and all the wiring was good and the connections are ok. The motor is a 2.2
Old 06-23-2011, 12:23 AM   #4
bob16652
so what are my chances that i have aq bad sensor?
Old 05-21-2012, 09:23 AM   #5
intruder800
intruder800 is on a distinguished road
Born Again: are you saying the trans speed sensor is the only sensor that will prevent a/t ls2 speedo from working? i just replaced mine ( no speedo, rough idle, hard shifts) and still no speedo. Wouldn't wheel speed sensor have similar symptoms?
Add to intruder800's Reputation
Rate the quality of this post and help intruder800 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
intruder800 is offline   Reply With Quote
93 Saturn Sl2 speedometer not working?? gambiteer Support Forum for Canadian Saturn Owners 2 04-03-2011 01:26 PM
93 Saturn Sl2 speedometer not working?? gambiteer S-Series Tech 1 04-15-2010 12:03 PM
1999 Saturn SL speedometer and tachometer stop working (funky electrical) gary80920 S-Series Tech 2 11-19-2009 01:05 PM
Speedometer Not working Need Help jcardzcollects S-Series Tech 3 05-04-2008 10:16 AM
Speedometer... not working wrightco S-Series Tech 5 12-30-2002 08:06 AM
