Old 04-10-2011, 06:36 PM   #1
athlonwirez
athlonwirez is on a distinguished road
2004 VUE 3.5L
Default 2004 3.5L Vue Valve Clearance
I just got done doing a 100,000 mile service and my valves are noisy. I spec'ed them to what I read in the haynes manual. .20 to .22 for the intake and .28 to .32 for the exhuast(mm). Are those specs correct. I was wondering why I had to loosen every valve in order to get these clearances. Now it sounds like I have a diesel. WTF
Add to athlonwirez's Reputation
Rate the quality of this post and help athlonwirez reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
athlonwirez is offline   Reply With Quote
Old 04-10-2011, 07:11 PM   #2
djb383
djb383 is on a distinguished road
djb383's Avatar
Default
I don't know what the factory specs are but those numbers seem mighty loose compared to other motors I've set/checked valves on.
.32 is 1/3 of an inch......that can't be right.
Add to djb383's Reputation
Rate the quality of this post and help djb383 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djb383 is offline   Reply With Quote
Old 04-10-2011, 07:38 PM   #3
far2grumpy
far2grumpy's Avatar
Default Re: 2004 3.5L Vue Valve Clearance
I've pasted extract from service manual - supposed to start with cold engine (less than 100 deg F) - FSM numbers agree from MM stand-point.
Select the proper thickness feeler gage.
Specification:
Intake valve adjustment: 0.2-0.24 mm (0.008-0.009 in)
Exhaust valve adjustment: 0.28-0.32 mm (0.011-0.013 in)
The complete extract is too large to post - I can email if you PM address.
Old 04-10-2011, 08:42 PM   #4
djb383
djb383's Avatar
Ooops, my bad, didn't read mm.
2004 vue v6 valve adjustment? hustler Vue Tech 4 03-15-2009 09:52 PM
Real Valve Stem Clearance on head rebuild DJCannon5 S-Series Tech 5 12-13-2008 11:33 PM
Valve Chattering - 2004 QC raverMJK Ion Tech 16 07-31-2007 11:58 AM
Valve clearance ym42 Vue Tech 11 10-12-2004 10:05 AM
anyone using a fumoto oil drain valve on an 2004 V6 Vue? squidward Vue General 6 05-19-2004 07:25 PM
