Old 12-08-2010, 04:47 PM   #1
stb100
stb100 is on a distinguished road
1996 SL1
Default IDLE high at startup. Rough too! - '96 SL1 Auto
Hi,
Thanks in advance for any help.
Our '96 Saturn SL1 4dr automatic (1.9L?; 4Cyl; 137k) starts easily but revs up to 2K+ rpm quickly like it's stuck and runs kind of "rough". Vibrates. If put in drive, it's chompin at the bit. Calms down after 10 minutes or so. Can't stomp the gas to make it come down. Does it when it wants to.
Any ideas?
Add to stb100's Reputation
Rate the quality of this post and help stb100 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stb100 is offline   Reply With Quote
Old 12-08-2010, 05:07 PM   #2
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
Default Re: IDLE high at startup. Rough too! - '96 SL1 Auto
does this happen when you start the car and the engine is cold or is it everytime you start it up?
'02 SL1.414213562^2, Deebs ftw
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 12-08-2010, 05:13 PM   #3
stb100
1996 SL1
Just at startup. Cold.
High idle at startup... most likely culprit?... Hackster S-Series Tech 4 07-21-2007 10:09 PM
Rough idle on startup Imagyne S-Series Tech 4 08-17-2005 03:21 PM
rough idle at startup OldGeezer Ion General 16 07-30-2003 09:56 PM
Rough startup idle and some tapping monkeyman Miscellaneous Tech 5 03-17-2002 01:42 AM
Rough Idle at Startup Steve96SL2m Miscellaneous Tech 10 03-10-2002 12:44 PM
