Old 12-01-2010, 10:46 PM   #1
Leonard1818
Leonard1818 will become famous soon enoughLeonard1818 will become famous soon enough
Leonard1818's Avatar
2004 VUE 3.5L
Default 3.5 V6 AWD transmission (TSB?)
Hey everyone.
In reading the forums I think I've found an answer for the problem we have had with our vue since buying it. It seems to hesitate or studder right around 35 or 40 MPH (right around 3rd gear?).
Sounds like #PIP3713B (found in a different thread).
I want to get some routine maintenance done on the vehicle. It's at 90,000 miles and it needs things like plugs, tranny fluid, timing belt etc. So I turn to the forums with the following questions:
1. It REALLY sounds like we're experiencing TSB #PIP3713B (see below). At 90,000 miles, I doubt there's anything GM is going to do about this. Is this a fair assumption?
2. Let's assume GM is NOT going to do anything. Is it worth me at least asking them to flash the PCM? I would think even if they are not willing to replace the tq converter, perhaps they will flash the PCM and the problem will go away or lessen?
3. If I don't pay to replace the torque converter at this time, will this problem be detremental down the line?
4. I'm thinking about transmission service. At 90K, would I need the full transmission service (pressurized) or just a simple drain and fill?
5. Will a drain and fill do ANYTHING to help the studdering between 35-40MPH?
Any input is GREATLY appreciated. I wish they would fix this issue for us but seeing as we're at 90K miles, I doubt they will do anything. I'm hoping to at least get the PCM reflashed for free but I don't even know if that will help or if it will actually hurt the issue. Also any input on drain/fill vs. full transmission service? Thanks in advance!
Here's that TSB for reference:
Torque Converter Shudder - keywords chuggle hesitation PCM PWM reflash reprogram surge vibrate #PIP3713B - (11/28/2006)
Models: 2004-2005 Saturn Vue
equipped with a 5AT transmission
This PI was superseded to include more keywords in eSI per request. Please discard PIP3713A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
The vehicle that is equipped with a 5AT transmission shudders or vibrates while driving between 35 and 40 MPH.
To confirm the customer's complaint, test drive the vehicle on a smooth road, preferably one with a slight uphill incline. Set the cruise control speed between 35 and 40 MPH, and monitor the engine RPM using the vehicle's tachometer, or use the Tech 2 to take a snapshot of engine RPM.
Recommendation/Instructions:
Replace the torque converter and reflash the PCM. The new calibration for the 5AT transmission will be any superseded calibration available at this time.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Add to Leonard1818's Reputation
Rate the quality of this post and help Leonard1818 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leonard1818 is offline   Reply With Quote
Old 12-02-2010, 12:38 AM   #2
chillin05VUE
chillin05VUE is on a distinguished road
chillin05VUE's Avatar
Default Re: 3.5 V6 AWD transmission (TSB?)
Have you changed the trany fluid. GM says to change it at 100k miles but Honda says to change it every 15-20k miles.
"Remember, if the women don't find you handsome, they should at least find you handy" -Red Green
2005 VUE V6 AWD
Add to chillin05VUE's Reputation
Rate the quality of this post and help chillin05VUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chillin05VUE is offline   Reply With Quote
Old 12-02-2010, 01:46 AM   #3
MoparNut
MoparNut will become famous soon enough
MoparNut's Avatar
I would strongly suggest a flush, rather than a drain/refill. It will remove far more of the dirty fluid and will save you money versus the 3 drain/fill services many on this board have done.
As far as the software update, it is a good idea but beware that on the older Honda VUEs (04-05 IIRC) with the 4th gear pressure switch that is mounted vertically I have had several that tripped a check engine lamp immediately after flashing. A new sensor is cheap and fixed the code, but it is rather odd that it only sets the code with the old sensor after the reflash. Also, on the Tech2 it states it is a THIRD gear pressure switch problem, when it actuality it is the 4th
+1 to changing the fluid every 35-50k miles, depending upon your driving style. 100k is just asking for trouble. And speaking of mileage, you are approx 4 years and 54,000 miles out of warranty. It would not be at all reasonable to expect any assistance from GM, especially considering they didn't even manufacture the powertrain on your VUE. Just my 2 cents
Add to MoparNut's Reputation
Rate the quality of this post and help MoparNut reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MoparNut is offline   Reply With Quote
Old 12-02-2010, 08:39 AM   #4
Olivier
Olivier is on a distinguished road
Have a look at what I have written in this thread:
"For those that have experienced torque converter failures (3.5L)"
It should be evident to everybody by now that our transmission is flawed and that using Z1 fluid does not work 100%.
I think an oil cooler is necessary because the transmission runs too hot, and a thicker viscosity ATF is better. This is based on this experience: 3 days ago I added 24 oz of Lucas Transmission Fix and it solved the issue for me. I drive the car everyday and it now feels like I have a new transmission...
Olivier
Vue 2005 3.5l FWD
Add to Olivier's Reputation
Rate the quality of this post and help Olivier reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Olivier is offline   Reply With Quote
Old 12-02-2010, 09:38 AM   #5
Leonard1818
2004 VUE 3.5L
You know, I bought the car at about 75,000 miles. My father-in-law says he usually has transmission fluid changed around 50K but he doesn't have the maint. records for the car so I can't say with 100% certainty that it has EVER been changed. With that said, I plan on doing at least a drain/fill.
I'm usually on a 30K mile schedule with all of my Hondas (drain/fill).
If I do anything it's going to be a flush or one drain/fill. I don't have the time to go thru several drain/fill cycles (much less the money!). The independent shop must have been quoting a flush at about $150. Does this seem right? They're usually really fair with pricing but I've never had a flush service done on a transmission so I don't know what pricing would be like.
I may investigate the software flash a bit more. I don't want it to trigger a CEL though. I'm not extremely mechanically inclined so I would likely just take it to a garage to do any pressure switch replacement (obviously a reflash is not a DIY job either lol).
I will have the fluid done soon. I just need to determine if it needs a drain/refill or a flush. Would there be any potential issues with dong a flush at this point? I hear there are internal filters in the Honda transmission. Would these be effected negatively by a flush?
To be honest, I agree with you about the warranty thing. Obviously I'm out of warranty however I wouldn't think it to be *too* insane to question if GM would do something about it... The way I see it, this is a KNOWN problem that they've admitted to (I see anything they issue a TSB for to be a "known" issue). This would be similar to the gas cap issue that I've been seeing lately. Except with that issue, they did come out and extend the warranty for that particular part. I don't think it to be unreasonable to question if they've extended the warranty for this issue as well. Further, I don't really care WHO they sourced the part from, they provided the vehicle so be it their part or hondas, I would expect them to take ownership of it. That would be like you buying a computer from dell, it dies and they say "Well, we got the processor fron intel so it's not really our problem..."
Don't get me wrong, I agree... it's out of warranty so it's my problem at this point. If the warranty was not extended, so be it. I have heard of some places doing "goodwill" work on something that is SLIGHTLY out of warranty (however I wouldn't fall into this category) and it would be nice as this car is starting to get on my nerves... but I'm not going to get too hung up on anything but ensuring that my pregnant wife is safe this winter and won't get stranded. I just need to know what my best course of action is without spending a ton of money unnecessarily but also getting the work done to fix the problem.
I greatly appreciate your input as you seem to have first-hand experience with this type of issue. Thank you VERY much!
Olivier
Vue 2005 3.5l FWD
Olivier, thanks for your input as well! I will have a look at your thread and take all experience into consideration when determining what course of action to take.
I welcome any further input as well. The facts are:
-- I don't know when the transmission fluid was last changed
-- I need to determine if I should do a flush or drain/fill (I've got one vote for flush!)
-- I then need to determine if $150 is reasonable for a flush service.
-- Finally, I need to determine if I should pursue a reflash or if that will compound the problem.
Thanks again to all who took the time to post replies!
Old 12-02-2010, 09:38 AM   #6
1saxman
Olivier; just curious, but how did you get 24 oz of fluid in the trans without raising the level too high?
Add to 1saxman's Reputation
Old 12-02-2010, 10:52 AM   #7
mlc5
mlc5 is a jewel in the roughmlc5 is a jewel in the roughmlc5 is a jewel in the rough
Leonard...do yourself a favor... get the fluid done.. pronto! And you need to drain/fill 3 times.. otherwise, what's the point.. you only remove 4.5 out of 12 or so quarts with a single drain/fill...
Secondly.. from what i've read, Honda does NOT recommend a flush.. due to the sensitivity of the internal parts.. so beware. Others will probably chime in on this....
My wife's 2004 Vue had problems at around 75k a while back, and the fluid change took care of the noises/vibrations, etc. Unfortunately this past a summer i had to get it rebuilt at 145k ...
This could probably have been avoided if I didn't follow the Saturn recommendation of 100K .. The tranny guy told me these tranny's run very hot, and need to be changed every 30k t 50k or so...depending on your driving profile.
Add to mlc5's Reputation
Rate the quality of this post and help mlc5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mlc5 is offline   Reply With Quote
Old 12-02-2010, 12:38 PM   #8
Leonard1818
2004 VUE 3.5L
MLC5, thank you!
I am taking the car in for plugs and a DRAIN/FILL tomorrow. I called Honda and spoke to them. I like my local honda dealership and have been dealing with them for some time. They know me (I'm the idiot who stores a civic for the winter ) and I asked them about it. He said that Honda NEVER recommends flushing their transmissions (EVER). My family has owned many hondas and many have seen 200,000+ miles. They've never been flushed (to my knowledge).
I'm going to go with the drain/fill this time around. If it doesn't get all of the fluid, then I'll have to go back when my wallet recovers. I think the recommended procedure is drain/fill, drive for a few hundred miles. Drain/fill drive for a few hundred miles, drain/fill. Is this correct?
FWIW, I passed on getting the transmission on our Grand Am SE flushed as I've read the same thing on the GA forums about the internal tranny parts not being too happy with the flushing process. Personally, I've driven hondas my entire life (OK, so my entire DRIVING life which has only been about 12 years) and I've done tranny fluid on one of them (Acura RSX-S) it was easier than an oil change and seemed to smoothen up the shifting (placebo effect, maybe?). Point is, I've never heard of Honda recommending a flush of the transmission (where you hook it up to a pressurized machine). The term "flush" as used on my Acura forums (and IIRC in the manual) meant to unscrew the fill bolt, undo the drain bolt, drain fluid out, pour a qt of fluid in, let it drain all the way out, put another in, let it drain all the way out (a 3rd is optional), then replace drain bolt, fill to spec, replace fill bolt and good to go.
I still welcome input and experiences with pressurized flushes.
Old 12-02-2010, 12:42 PM   #9
far2grumpy
far2grumpy's Avatar
mlc5 - I'll point out that Saturn recommends ATF service at 100K if vehicle is operated under "normal" conditions.
My 2005 Vue (V6) owners manual recommends ATF service on a 25K mile schedule for severe service. Their definition of severe service probably describes how majority of Vue owners use the vehicle.
Here's definition from 2005 manual:
Severe service is when the vehicle is mainly driven under one or more of these conditions:
− In heavy city traffic where the outside temperature regularly reaches 90F (32C) or higher.
− In hilly or mountainous terrain.
− When doing frequent trailer towing.
− Uses such as found in taxi, police, or delivery service.
Old 12-02-2010, 12:52 PM   #10
Leonard1818
2004 VUE 3.5L
Hey there!
I was looking fwd to you chiming in here...
any futher input besides the obvious "Leonard, you really really need to get your ATF changed ASAP" lol?
While I've got your attention, what do you feel about changing the RDM fluid and/or Transfer assembly fluid? Are these critical at 90K?
Old 12-02-2010, 01:13 PM   #11
far2grumpy
far2grumpy's Avatar
Originally Posted by Leonard1818 View Post
Hey there!
I intend to stick to severe service intervals for RDM (50K) and PTO (25K).
I'm a fluid changing idiot but I sort of think it'll be cheaper in the long run.
Please don't ask if I intend to change the timing belt at 50K (severe service suggested). I might let that slide until 75K (at minimum).
Old 12-02-2010, 02:01 PM   #12
Leonard1818
2004 VUE 3.5L
Yeah, the other 2 are on my "to do" list and hopefully soon. I will do plugs and tranny drain/fill. Next comes T-belt (hard pill to swallow) and finally RDM and Transfer assy fluid.
I'm debating if I should do the coolant flush (again, is this a drain/fill or a FLUSH?) and water pump when I get the t-belt done... Dealer wants $685 for coolant/T-belt and $960 for coolant/T-belt/h2o pump.
Old 12-03-2010, 08:10 AM   #13
Olivier
Saxman, I just drained about 24 oz of ATF before putting the stuff in, but I think the actual ATF level is not too critical as long as you have the minimum. I know I am still a bit high but it is difficult to measure correctly.
Olivier
Old 12-03-2010, 04:30 PM   #14
mrtube
mrtube is on a distinguished road
Olivier
I suspect you are right for the most part regarding fluid level. Too low is a bad thing however too full should not cause damage. I assume too full will just cause it to blow out of the vents and make an unnecessary mess. the 4 times I've done our fluid I was sure to keep it pretty much right at the top line on the dipstick.
Overfilling could possibly cause undue stress on seals, but I doubt it. Regardless of stress on seals or an oily mess its easy to avoid. Don't over fill it.
Add to mrtube's Reputation
Rate the quality of this post and help mrtube reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrtube is offline   Reply With Quote
Old 12-05-2010, 12:26 AM   #15
HerBabyTruck
HerBabyTruck is on a distinguished road
HerBabyTruck's Avatar
2005 VUE Red Line
Too full WAS the problem with mine. As soon as I drained enough to get it back into the correct range it shifted and drove perfectly. No more studdering.
HerBigTruck = SILVERADO HD K2500 8.1 Allison
Add to HerBabyTruck's Reputation
Rate the quality of this post and help HerBabyTruck reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HerBabyTruck is offline   Reply With Quote
Old 12-07-2010, 07:51 PM   #16
MoparNut
MoparNut's Avatar
$150 is quite reasonable for a flush. As far as flushing machines go, it depends on how it operates; if it uses the pump internal to the transaxle to move the fluid (such as the machine made by MOC that we use) then it basically takes the place of the cooler temporarily and cannot harm the trans. If it forces the fluid through with it's own pump I suppose it might not be great, but since the trans can generate over 300 psi I doubt it would hurt.
Old 12-08-2010, 11:33 AM   #17
Leonard1818
2004 VUE 3.5L
Thanks MoparNut for the insight.
I ended up just doing a drain/fill per the recommendation of Honda (they do not recommend pressurized flushing of any of their trannies ever). I'll probably do another drain/fill in the spring as I don't think doing just one gets all the fluid out (?)
Old 12-11-2014, 09:53 AM   #18
Ziggyrz07
Ziggyrz07 is on a distinguished road
Ziggyrz07's Avatar
2004 VUE 3.5L
2004 VUE 2.2L
I know this is a old thread but I came across it during a search and feel like I should update some of the information. The torque convertor shutter problem from Honda is recommended this process.
Flush transmission
If problem isn't fixed
Replace torque converter and re flash computer.
GM covered costs on this problem up until February 2014 which of course has expired. Too bad I didnt know ahead of time.
In April we added one quart of fluid because it was low and problem reduced heavily. Problem came back so in June we did flush per Honda TSB. Problem went away. 1500 miles later it's shuttering again. I'm at the dealership today getting my new ignition installed. I have them the TSB and requested that it be re flashed if they can find the information. In all honesty I should do it at the Honda dealership. The GM guys around here didn't even know it has a Honda engine and transmission...
So I'll update when I leave, but if they can't find it I'll try transmission honey first, if that doesn't help I willjust replace the torque converter myself its only 160$. The fluid cost that lol.
2004 Saturn Vue AWD V6
3.5 j35S1
Painted trim
255/55-18 tires stock height of 29"
2004 Saturn Vue AWD I4
2.2 ecotec
Add to Ziggyrz07's Reputation
Rate the quality of this post and help Ziggyrz07 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ziggyrz07 is offline   Reply With Quote
Old 12-11-2014, 10:14 AM   #19
far2grumpy
far2grumpy's Avatar
GM offered to update PCM and/or replace defective torque converters for 05 - 07 Vue's with 3.5 powertrain and the program expiration date was extended to 02-28-2015.
I recall one or two members paying dealers to update 04 Vue PCM and I think price was around $100.
Old 12-11-2014, 10:36 AM   #20
Ziggyrz07
Ziggyrz07's Avatar
2004 VUE 3.5L
2004 VUE 2.2L
All data lists 2014 as expiration not 2015 and yeah they said that there was nothing listed under the 2004 vue even know we all know it had the exact same problem, but I have no problem paying 100 for a updated flash. I'm sure since 2003 there has to be some data that was updated on the flash since the factory one.
What I wish they would update is when the vehicle downshifts on the highway it's so annoying that it downshifts right away. My mom bought this car brand new and I learned to drive in. I bought it from her and got her a deal on a nice rav 4. So I know the vehicles while history and every thing that we liked and hated about it lol.
3.5 j35S1
Painted trim
2.2 ecotec
How to change transmission fluid in VUE with manual transmission David 93 SL2m Vue Tech 35 06-30-2017 06:47 PM
rebuild mp7 transmission, Saturn TAAT transmission, Locks up in reverse, help mordo2 S-Series Tech 5 05-23-2016 08:28 AM
Transmission cooler/radiator replacement when transmission is bad? infinitewisdumb S-Series Tech 2 04-16-2010 08:59 AM
122,000 miles on transmission with no transmission fluid change in car's history. foo General Saturn Discussion 10 04-22-2008 05:04 PM
'95 Transmission Operation Debrief: Transmission stuck in 2nd gear rc1488 S-Series General 0 01-12-2008 12:28 AM
