Old 06-27-2010, 10:13 PM   #1
shanetill254
shanetill254 is on a distinguished road
Default 2001 saturn sl1 sohc 4 cyl starts then dies
I have a 2001 saturn sl1 with the sohc 4 cyl . Just bought the car from a lady that could not ge it running. The car turns over, starts the dies. I have good fuel pressure. I have replaced the crankshaft position sensor, I have been told something about a 30 min relearn but I dont know how to . any ideas would be great
Add to shanetill254's Reputation
Rate the quality of this post and help shanetill254 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shanetill254 is offline   Reply With Quote
Old 06-27-2010, 10:39 PM   #2
Default Re: 2001 saturn sl1 sohc 4 cyl starts then dies
Welcome to the Board.
Do a search of the board for
30 minute pass lock relearn
or a combination of.
The bottom of the thread should have some links that will help your search as well.
Add to ssicarman's Reputation
Old 06-29-2010, 12:53 PM   #3
shanetill254
the car does not have passlock any other sugestions
Old 06-29-2010, 03:52 PM   #4
Put the gas pedal all the way to the floor, then turn the key and try to start. If it starts, replace the ECTS (and connector, if corroded).
I take it you have good spark?
Old 06-29-2010, 05:19 PM   #5
bluesl2
bluesl2's Avatar
Yes it does, 2000-2002 models have it.
Add to bluesl2's Reputation
Old 06-29-2010, 07:30 PM   #6
As bluesl2 said you do have passlock. It is not a key encode passlock system. It is in the ignition cylinder and housing.
Old 07-02-2010, 09:09 AM   #7
shanetill254
Well I tried to do the relearn but I could never get the security light to flash or better yet I could not find it any ideas
Old 07-02-2010, 05:22 PM   #8
bluesl2
bluesl2's Avatar
When you first turn the key to run do you hear the fuel pump run for a couple seconds? Check the fuse if not.
Old 07-11-2010, 11:34 AM   #9
shanetill254
ok so this is what I got
I used he code scanner and it said the tps sensor was bad
so I changed it I can now start the car if I keep the throttle around half way and it will stay running al long as I dont let the rpms drop below around 1800 but If I keep pushing the gas it stays running and running good it sound like
Old 07-11-2010, 08:18 PM   #10
harley2003
harley2003 has a spectacular aura aboutharley2003 has a spectacular aura aboutharley2003 has a spectacular aura about
harley2003's Avatar
2002 SL1
2002
First of all this is a 2001 SL1, bad intake manifold gasket, this is the first place to look for a known problem and it causes all kinds of codes and runs terrible. Check this and replace it ,if it's not bad it will be.
2013 Hyundai Sonata new
2003 Harley Davidson FXDWG wide glide.
2015 Hyundai accent hachback
Add to harley2003's Reputation
Rate the quality of this post and help harley2003 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
harley2003 is offline   Reply With Quote
Old 07-11-2010, 08:37 PM   #11
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
It may need to relearn its idle servo position after replacing the tps.
On most older cars EGR stuck open is the normal cause of "it starts then dies".
You could always pull the egr and start it and see if it helps..........If it starts and stays running Bingo.
Old 07-17-2010, 01:06 AM   #12
shanetill254
ok here we after some trial and error we got it started
it is hard to start but starts and runs decent and now will stay idling.
it is very sluggish one thing I should have pointed out was that the car was setting up for 8 months without being started because the previous owner did not know how to fix it.
Old 07-17-2010, 07:34 AM   #13
1996SL11.9L
2002 SL1
Put some dry gas in also.
Can you drive it, or no tags?
Old 07-17-2010, 11:08 AM   #14
Use the Forum Jump below to find the How-to library about the infamous engine coolant temperature sensor (ECTS). Yours may have the original plastic one and needs to be replaced with the brass one. Hard starting and flooding are only two of many issues with faulty ects'.
Having the car sit for so many months creates new problems. Cars don't like sitting still and like being used otherwise things occur that don't when used once a week, even if just starting and idling for a half hour.
Old 09-17-2010, 08:45 AM   #15
yav444
yav444 is on a distinguished road
This "30 minute pass lock relearn" procedure worked for me. The battery was replaced in my 2002 SL1, the car would turn over, but would not start. My security light was flashing. Following the 30 minute relearn procedure fixed the problem.
note...the original problem was caused by the chattering door lock issue
(documented in another posting on this site). This problem was draining the battery and was temporarily fixed by removing the driver side power lock switch (a 2 minute job). The white plastic actuator in the switch had broken.
procedure is as follows.
1. Start with the key in the OFF position.
2. briefly turn it to the CRANK positon (very briefly try to start the car)
3. The car will try to start (it will turn over, but will not start)
4. Leave the key in the RUN position as if the car started
5. The security light will be flashing.
6. Wait 10 minutes (almost exactly) until the SECURITY light goes out (wait on the light not the time)
7. When the light goes out turn the key to the OFF position (keep the key in the ignition) for 5 seconds
8. Repeat steps 1-7 two more times for a total of 3 cycles (30 minutes).
9. After the 3rd cycle, starting with the key in the OFF position (per step 7), start the car.
NOTE: On this next start cycle the car will actually learn the passcode from the BCM
Add to yav444's Reputation
Rate the quality of this post and help yav444 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yav444 is offline   Reply With Quote
Old 03-21-2011, 10:42 PM   #16
Wolfen76
Wolfen76 is on a distinguished road
Add to Wolfen76's Reputation
Rate the quality of this post and help Wolfen76 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wolfen76 is offline   Reply With Quote
Old 02-13-2016, 02:42 PM   #17
The Mechanic
The Mechanic is on a distinguished road
The quick learn did not work for me. any other ideas
Add to The Mechanic's Reputation
Rate the quality of this post and help The Mechanic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
The Mechanic is offline   Reply With Quote
2001 SC1 starts then dies instantly..??? kb7010 S-Series Tech 13 09-03-2008 12:06 PM
96 Saturn SL runs dies then starts roscoemegan96sl S-Series Tech 21 08-16-2008 12:01 AM
95 Saturn SC1 SOHC,Starts Hard Cold Only?? Help Please. lordgalla S-Series Tech 6 12-15-2005 01:55 PM
Starts then it dies Raiderx18 S-Series General 5 03-15-2005 09:17 PM
Starts in cold then dies, then starts again ??? Scyan S-Series Tech 10 02-16-2003 09:16 PM
