Old 05-30-2010, 08:44 PM   #1
Demons5910
Demons5910 is on a distinguished road
Default 2000-2002 Saturn Intake Manifold Fix
Hey Everyone. I just recently bought a 2001 Saturn sc2 and the only problem with it so far was that the coolant stem on the intake manifold was leaking. After much research, it was noticed that this was a common problem with SC2 and SL2 models of 2000-2002. The coolant intake stem is plastic and therefore cracks under the intense pressure from the coolant going through at such high temperatures. I also read on many sites that even if you replace the part, which is about $250, will crack again under pressure. So you will just continue to replace this part. So by luck I ran across this guy on ebay who makes a part that solves this issue and it has worked great on mine. Go to ebay and type in "2000-2002 Saturn SL2 intake manifold part" and it should come up and he has included a video to demonstrate. Hope everyone enjoys and if you have any questions about how I installed mine just let me know.
Add to Demons5910's Reputation
Rate the quality of this post and help Demons5910 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Demons5910 is offline   Reply With Quote
Old 05-31-2010, 12:09 PM   #2
quantumech
quantumech is on a distinguished road
Default Re: 2000-2002 Saturn Intake Manifold Fix
Wasn't this posted sometime last week too? Seems a little fishy.
Sasha: 2000 SL1, Manual, 130,500 miles 5-18-2014.
I learn from my experiences. If I screw up, I'm sorry.
Add to quantumech's Reputation
Rate the quality of this post and help quantumech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quantumech is offline   Reply With Quote
Old 07-14-2010, 04:59 PM   #3
Mike Angel
Mike Angel is on a distinguished road
Hello, I had the same problem, and I stumbled across this thread using the search option. I went to the eBay link, and bought the repair kit. I got it in the mail, and it works great. The only thing fishy is the smell of the money saved that is in my pocket.
Add to Mike Angel's Reputation
Rate the quality of this post and help Mike Angel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mike Angel is offline   Reply With Quote
Old 07-15-2010, 11:05 PM   #4
Demons5910
Glad I could help someone.
Old 05-20-2011, 06:15 PM   #5
chrissycbaby
chrissycbaby is on a distinguished road
does this kit work for the saturn sl intake manifold?
anybody know?
Add to chrissycbaby's Reputation
Rate the quality of this post and help chrissycbaby reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chrissycbaby is offline   Reply With Quote
Old 05-20-2011, 06:37 PM   #6
If you mean specifically the SL model, then no, that car has an aluminum intake manifold which doesn't have this problem.
If you're using "SL" to refer generally to the S-Series sedans, then specifically it works on the SL2, which has the plastic manifold which is susceptible to this problem.
Add to madpogue's Reputation
Old 05-20-2011, 07:52 PM   #7
SL2Many
SL2Many is on a distinguished road
It's not fishy, I had the same problem earlier this week. Since I cannot do the work myself, I found a decently priced NOS manifold and had that installed. The first one lasted 10 years and I doubt the car (or I?!) will last another 10. I'm sure this kit works but I don't know the long-term durability.. JMHO.
Add to SL2Many's Reputation
Rate the quality of this post and help SL2Many reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2Many is offline   Reply With Quote
Old 05-20-2011, 09:23 PM   #8
off-track
off-track's Avatar
Old thread Chrissy. If you (as Mad said) are asking about a DOHC it's still out there but they've set up their own site.
http://www.carsaturnstore.com/produc...epair-Kit.html
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 06-23-2011, 03:19 PM   #9
dalgal4sure
dalgal4sure is on a distinguished road
demons,
do you have the specs on the ebay guy you got the sl2 intake manifold kit? i cannot find him on ebay.
thx!
Add to dalgal4sure's Reputation
Rate the quality of this post and help dalgal4sure reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dalgal4sure is offline   Reply With Quote
Old 06-23-2011, 04:50 PM   #10
Here------------> http://www.carsaturn.com/
Old 09-02-2011, 08:03 PM   #11
2teendaughters
2teendaughters is on a distinguished road
2teendaughters's Avatar
So whats the final opinon on this kit? I have one leaking along with a noisy timing chain. The chain and sprockets I did four years ago. Should have bought a better set than the El Chepo one off of Flea Bay.
Craig
2000 Sl2 (1st Daughter 2nd Sl2)
2001 Sl2 (Wifes)
2002 Sl2 (2nd Daughter)
2000 Sl2 (RIP Wrecked by 1st Daughter Sold)
2001 Sl2 (1/2 a car bought for Parts Sold)
Add to 2teendaughters's Reputation
Rate the quality of this post and help 2teendaughters reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2teendaughters is offline   Reply With Quote
Old 09-03-2011, 11:07 AM   #12
SLCraig
I like '99 aluminum intake manifold swap better
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-03-2011, 06:17 PM   #13
I keep mentioning that...
I think you will find the manifold fix is still without detractors. Looks good.
Intake Manifold Gasket/2002 SL1 Jhawk S-Series General 8 12-14-2011 03:59 PM
2002 sl2 Intake Manifold ddsmithjr S-Series Tech 6 02-07-2006 09:55 AM
2002 SC1... Need new Intake Manifold Gasket?? WrathX S-Series General 4 12-11-2005 12:34 AM
WTB: 2000-2002 OE air intake and intake manifold Tycho Classifieds 0 03-03-2005 11:52 AM
Injen Technology Intake System (Polished) For Saturn S or SC-Series (2000-2002 All DO luckykasper Classifieds 0 03-14-2003 02:04 PM
