Old 04-24-2010, 08:11 PM   #1
Rebel65
Rebel65 is on a distinguished road
Rebel65's Avatar
2002 VUE 3.0L
Wrench Hello New here with P0431 code
Hello again I'm new here and great forums I read a lot of them even on my
P0431 code. Just curious does anyone know what exactly to look for? I have a 2002 Satarn Vue All wheel drive with 3.0 L Automatic and had codes with
P0700 and fixed that with CRS sensor but I keep having P0431 and when it happens is after I'm driving awhile and stop and shut it off then start it up and go again. Having trouble determining weather it's an 02 sensor or a Cat on bank 2. And what is bank 2 witch side of the engine is that? There are 4
O2 sensors 2 on each side one right next to the manifold and one infront of the cats. Can anyone help.
Thanks
Rebel out
Add to Rebel65's Reputation
Rate the quality of this post and help Rebel65 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rebel65 is offline   Reply With Quote
Old 04-24-2010, 10:19 PM   #2
far2grumpy
far2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to all
far2grumpy's Avatar
Default Re: Hello New here with P0431 code
You can find P0431 information and engine bank in post # 2 of this thread:
http://saturnfans3.saturnfans.com/~s...d.php?t=147531
Good luck.
Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
Old 05-03-2010, 09:22 PM   #3
burlyvue2
burlyvue2 is on a distinguished road
2000 L-Series 3.0L Wagon
Hello Rebel,
I had 2003 with V6 and had the same codes. Does not appear to affect performance of the vehicle, just super annoying. It is the Cat and .... dang that is an expensive piece of exhaust equipment. I was gonna bite the bullet and buy used exhaust from wrecker supply but the vehicle was totalled when a chick speeder removed the front of the vehicle in her Infiniti. BTW I was only slightly injured by the driver side door nailing my left hip. Vue is a very safe vehicle.....
If you plan to keep the vehicle you will need to get a new cat and they are available. Saturn might have some available still.
Add to burlyvue2's Reputation
Rate the quality of this post and help burlyvue2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
burlyvue2 is offline   Reply With Quote
P0421, P0431, hard to start cold jlb0305 Vue Tech 7 03-18-2010 03:42 PM
Check engine light codes P0421 & P0431 pjm71 Vue Tech 10 03-11-2010 07:59 AM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 05:17 PM
Trans code 25, engine code 32, 1993 sl-1 1993 S-Series Tech 3 06-27-2004 10:13 PM
vin egine code to original code how to check? silver97sl General Saturn Discussion 1 01-12-2004 03:17 PM
