Old 03-08-2010, 12:48 PM   #1
mariopalumbo
mariopalumbo is on a distinguished road
2003 VUE 2.2L
1998 SL1
Default Replace Harzard Light Switch 2003
My hazard switch is not working. When I depress the buttonm the signal lights will not work. When the button is in the 'home' position (not on) the signal light works. I took apart the dash (again after my wife pushed the button through the dash earlier) and held the hazard switch unit while I turned on the signal lights and I could feel it clicking with the signal light. But when I drepressed it the signal stopped and no clicking. I know the signal runs through the hazard, but when it is depressed it seems to be blocking the power from passing through the device. When it is home, it allows the signal to pass through. Any thoughts besides a bad switch. anyone else have to replace a switch?
Add to mariopalumbo's Reputation
Rate the quality of this post and help mariopalumbo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mariopalumbo is offline   Reply With Quote
Old 03-08-2010, 07:02 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Replace Harzard Light Switch 2003
I've noted several posts in the last 18 months regarding the hazard switch.
The flasher for both hazard and turn signals are embedded with switch.
Sounds like there's some sort of impending internal failure.
You can find a schematic in post 7 of following thread:
http://saturnfans3.saturnfans.com/~s...d.php?t=148307
Old 03-09-2010, 07:38 AM   #3
mariopalumbo
2003 VUE 2.2L
1998 SL1
far2grumpy, that is excellent thank-you
Old 03-10-2010, 09:49 PM   #4
mariopalumbo
2003 VUE 2.2L
1998 SL1
UPDATE:
well I found the issue and I feel pretty dumb. It was the fuse. I did not know there was a separate fuse for the hazard lights. I thought because the signal lights worked and it was linked to the hazard lights that it could not be the fuse. But as I looked over the schematic (thanks again far2grumpy), I saw there was indeed a fuse for the hazard lights and if that was blown it would short out the signal lights when the hazard switch was engaged.
I was starting to look around at wrecking yards for parts. I'm glad I found the easy fix...................
Saturn Vue 2003 Reverse Light Switch Replacement texplayboy Vue General 4 10-16-2013 12:40 AM
Harzard Switch mariopalumbo Vue General 1 11-09-2009 10:13 AM
Cracked a line while trying to replace the back-up light switch on a 2000 sc1 manual negilum S-Series General 12 07-23-2007 11:19 PM
How to replace the headlight switch on a 92 SL? turbobuick33 S-Series Tech 1 11-22-2006 09:39 PM
replace ignition switch davem S-Series Tech 4 10-08-2002 09:30 AM
