Old 02-23-2010, 08:37 PM   #1
GTDanny
GTDanny is on a distinguished road
2001 SC1
Default sticky gas pedal
Any fix for a sticky gas pedal. It sticks when you start to press it. It comes and goes. thanks
Add to GTDanny's Reputation
Rate the quality of this post and help GTDanny reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GTDanny is offline   Reply With Quote
Old 02-23-2010, 09:08 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: sticky gas pedal
clean your throttlebody. Search feature will give you directions, it's a piece of cake.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 02-23-2010, 09:26 PM   #3
paulo
paulo will become famous soon enoughpaulo will become famous soon enough
+1 I would watch Richpin's video on cleaning the throttle body and idle air control valve. You can find it in the "How to Library" under Richpin videos. Some of these symptoms can be corrected by cleaning certain parts.
Add to paulo's Reputation
Rate the quality of this post and help paulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paulo is offline   Reply With Quote
Old 02-23-2010, 10:07 PM   #4
Tommie
Tommie is a jewel in the roughTommie is a jewel in the roughTommie is a jewel in the rough
1996 SL1
2002 SL1
If the throttle plate opening is clean, sometimes the plate actually digs into the bore under vaccuum. Adjust with the throttle plate screw so it doesn't bind...
Add to Tommie's Reputation
Rate the quality of this post and help Tommie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tommie is offline   Reply With Quote
Old 02-23-2010, 10:38 PM   #5
mr18436572
mr18436572 is on a distinguished road
2000 SL2
Throttle body needs to be cleaned
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
Add to mr18436572's Reputation
Rate the quality of this post and help mr18436572 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr18436572 is offline   Reply With Quote
Old 02-23-2010, 11:18 PM   #6
That screw is NOT a user adjustment. It is to be set for 500 RPM with the IAC intake port blocked off. If it has been tweaked then it will foul up all the other hard coded setpoints in the PCM.
Old 02-24-2010, 07:35 AM   #7
Tommie
1996 SL1
2002 SL1
Well I can only tell you what I found in my experience and you obviously have a lot of your own.
The throttle plate and opening on my car is clean and the plate is hanging up in the opening with the engine running so making a MINOR adjustment so the pedal is not sticking is what I have done. I have not had any problems doing this and idle speed is identical.
Not user adjustable? I guess we should not touch anything then.
Old 02-24-2010, 08:50 AM   #8
You can adjust it, just set it to the correct point.
Old 02-24-2010, 12:58 PM   #9
Norseman
Norseman is on a distinguished road
Have you checked to see if your Toyota floor mat is not causing it?
Add to Norseman's Reputation
Rate the quality of this post and help Norseman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Norseman is offline   Reply With Quote
Old 02-24-2010, 01:09 PM   #10
brico
brico is on a distinguished road
1993 SL2
I thought he was driving a toyota...
Add to brico's Reputation
Rate the quality of this post and help brico reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brico is offline   Reply With Quote
Old 02-24-2010, 01:20 PM   #11
Hidalgo
Hidalgo is on a distinguished road
1998 SW2
Good advice.
As a side note ... I was pushed for time, and simply removed the intake hose from the throttle body and shot a little carb cleaner on the plate. Fixed the problem with the pedal sticking.
I did, however, remove it and give it a thorough cleaning a few days later.
2006 Porsche Boxster (hers)
1998 Saturn SW2 (ours)
2010 Ford Flex (his)
Add to Hidalgo's Reputation
Rate the quality of this post and help Hidalgo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hidalgo is offline   Reply With Quote
Old 02-24-2010, 03:21 PM   #12
adventureoflink
adventureoflink's Avatar
Wrench Re: sticky gas pedal
and if it is, PLEASE be sure to zip-tie it down AWAY from the accelerator and brake (and clutch).
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 02-24-2010, 06:58 PM   #13
acman
acman has a spectacular aura aboutacman has a spectacular aura aboutacman has a spectacular aura about
1999 SC1
"Sticky gas Pedal?" Do you think this is the Toyota forum???
1997 SL2, 5 speed
1999 SL1, Automatic
Add to acman's Reputation
Rate the quality of this post and help acman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acman is offline   Reply With Quote
Old 02-24-2010, 07:04 PM   #14
RobertGary1
Everyone's comment on cleaning the TB is right on. This is a problem that will reappear from time to time. Often times I can get away with just spraying some carb cleaner into the TB aimed at the interface between the butterfly valve and the internior body. Often times this is enough to solve the issue, but eventually you will need a good full cleaning involving removing the TB and the IAC.
-Robert
Old 01-03-2011, 12:11 AM   #15
saturn_babe
saturn_babe is on a distinguished road
saturn_babe's Avatar
1997 SL1
ah, I was searching and I'm glad I found this thread. My gas pedal becomes kind of sticky sometimes and it gets annoying. Gonna get my b/f to check it out. Thanks yall!
Add to saturn_babe's Reputation
Rate the quality of this post and help saturn_babe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn_babe is offline   Reply With Quote
Sticky pedal Blind898 S-Series Tech 12 06-14-2009 09:22 PM
sticky gas pedal mental.piracy S-Series Tech 6 09-26-2007 02:45 PM
Sticky pedal... Elementkng20 S-Series Tech 3 05-07-2007 07:19 PM
Sticky gas pedal Tim T S-Series Tech 17 12-01-2002 08:50 AM
Sticky accelerator pedal MrBigglesworth Miscellaneous Tech 3 11-08-2000 08:54 PM
