Old 02-16-2010, 11:17 PM   #1
saturnvue2
saturnvue2 is on a distinguished road
Default clutch problem not bleeding
can anyone give me a idea my wife has a2005 saturn vue and when the vehicle is first started she cant get it in gear it only has 1/2 pedal so i tried to blead it at the bleader by the tranny no luck .now no pedal can some one please help
Add to saturnvue2's Reputation
Rate the quality of this post and help saturnvue2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnvue2 is offline   Reply With Quote
Old 02-18-2010, 12:33 AM   #2
bern
bern will become famous soon enough
2004 ION-2 Sedan
Default Re: clutch problem not bleeding
You'll need to pull a vacuum on the master cylinder resivor. Hold vacuum for about 3 minutes, release vacuum pump the padel and repeat 2 more times. the last one I did (ion) I first used my hand vac pump. It only pulled about 23" vac and didn't work well. So I tried my vacula type tool and that pulled a greater vacuum and the clutch worked great.
Add to bern's Reputation
Old 02-18-2010, 06:29 AM   #3
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
This is exactly what mine did.
Your clutch mater cylinder is shot. We actually broke a vacuum pump trying to bleed mine - it's not terribly expensive, but replace it. The seal turned sideways in mine and jammed it up.
My master failed, we replaced it... about a year later, my slave failed and took the master with it. At that time, I had all of the hydraulics replaced as well as the pressure plate and such while they were in there - this was at 45K miles.
OhioVueBoy is offline   Reply With Quote
clutch bleeding mesared Ion Tech 6 06-04-2009 06:46 PM
Bleeding clutch arendsg S-Series Tech 13 06-04-2009 03:07 PM
Clutch Bleeding? Brock4u Vue Tech 0 04-16-2008 07:28 AM
bleeding clutch 92sl24ya S-Series Tech 10 02-21-2004 06:46 AM
clutch bleeding 94sc2boy Miscellaneous Tech 1 10-27-2000 10:01 PM
