Old 01-17-2010, 07:16 PM   #1
bob50
bob50 has a spectacular aura aboutbob50 has a spectacular aura aboutbob50 has a spectacular aura about
1997 SC1
2000 SL2
Default 2000 SL2 fast idle.
Everyday My SL2 will idle fast about 1,500 in park,
I shut it off and restart it the idle goes back to normal. Then a few minutes later go high again.
I've changed the idle valve, cleaned the throttle body and replaced the coolant temp sensor
Could it be the throttle position sensor? I was told they hardly ever go bad.
Add to bob50's Reputation
Rate the quality of this post and help bob50 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bob50 is offline   Reply With Quote
Old 01-17-2010, 07:24 PM   #2
akasnacker
akasnacker is on a distinguished road
akasnacker's Avatar
Default Re: 2000 SL2 fast idle.
I have the same exact problem for my 2001 SC2 HELP US!
Add to akasnacker's Reputation
Rate the quality of this post and help akasnacker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
akasnacker is offline   Reply With Quote
Old 01-17-2010, 08:13 PM   #3
With Charlie moving us around it can be confusing as to where to post; you're both posting in the L-series forum where you should be in the S-series forum.
If the high idling stops when restarting its been the consesus here as a worn out throttle position sensor (TPS). TPS' do wear out despite opinions contradicting this. The past posts say so. Not what someone says.
Old 01-17-2010, 09:03 PM   #4
akasnacker
akasnacker's Avatar
Happy Re: 2000 SL2 fast idle.
[If the high idling stops when restarting its been the consesus here as a worn out throttle position sensor (TPS). TPS' do wear out despite opinions contradicting this. The past posts say so. Not what someone says.[/QUOTE]
Thanks I will try that fix the throttle position sensor replacment, as to this post I can't post anywhere else I want to post my sales AD for the 1999 Saturn SC2 I'm selling but I can't? How or when can we post to the classifieds of the S series department? Thanks for your reply to the fix, bless you fdryer!
Old 01-17-2010, 09:22 PM   #5
No thanks necessary. Charlie the Administrator is migrating our site to a new server and I've noticed some small glitches maneuvering around. This is temporary and just another small inconvenience to everyone but this too will pass. Let a few days go by and try posting again or just keep trying every day.
Old 01-22-2010, 05:46 PM   #6
bob50
1997 SC1
2000 SL2
Yes, thanks for the info, plan to replace it this weekend .
Old 01-22-2010, 08:03 PM   #7
akasnacker
akasnacker's Avatar
Wrench Re: 2000 SL2 fast idle.
Yes its got to be the TPS, refer to fdryer's post:If the high idling stops when restarting its been the consesus here as a worn out throttle position sensor (TPS). TPS' do wear out despite opinions contradicting this. The past posts say so. Not what someone says.
Im going to start with the cheaper of the two coolant sensor then if thats the fix I'm done if not then I will buy a TPS looks like you have already done the cheaper fix & it didnt work hope I have better luck?
Old 02-06-2010, 10:47 AM   #8
bob50
1997 SC1
2000 SL2
yes, replaced the tps and the fast idle is gone,thanks everyone
Old 02-06-2010, 11:30 AM   #9
BoDuke70
BoDuke70 is on a distinguished road
BoDuke70's Avatar
2004 ION-3 Quad Coupe
Don't sweat it, bob50. Trust me, with no real clear badging the model designations can get muddy real quick. LS1, L100, L300.2...
A different kind of parts guy...now in a bow tie!
Add to BoDuke70's Reputation
Rate the quality of this post and help BoDuke70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BoDuke70 is offline   Reply With Quote
Old 01-20-2012, 02:37 PM   #10
mammoth77
mammoth77 is on a distinguished road
2000 SL2
Just wanted to post a "thanks" in this thread. I recently purchased a 2000 SL2 and it was having intermittent high idle episodes that would go away with a cycle of the ignition. TPS has been replaced and so far, so good...
Now to get the emissions diagnostic monitors to complete given the cold weather.
Thanks!
Add to mammoth77's Reputation
Rate the quality of this post and help mammoth77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mammoth77 is offline   Reply With Quote
Old 01-21-2012, 01:27 AM   #11
akasnacker
akasnacker's Avatar
Thumbs Up Re: 2000 SL2 fast idle.
Yes, I had to replace the TPS sensor back then in "2010" & now the cars been running fine for 2 years now! Thanks to fdryer
2000 sc-1 fast idle SATURN ONE S-Series Tech 1 03-08-2008 04:54 PM
Fast idle raydog S-Series Tech 4 02-25-2008 11:22 AM
Fast Idle pedros003 S-Series Tech 2 02-01-2008 02:21 PM
No Fast Idle on Cold Start Up and Strange Idle There After Larry Horne S-Series Tech 11 07-21-2006 02:18 PM
01 Sc2 Goes To Fast Idle Enky01SC S-Series Tech 4 12-27-2005 07:31 AM
