Old 01-09-2010, 06:47 PM   #1
Bookemdano
Bookemdano is on a distinguished road
Default HEAVY smoke from steering column
1996 Saturn SL2, 140,000 miles.
After reviewing these forums, Iím not the first person to have a similar problem. Although most of the post I read concerned the ignition switch, my problem appears to from the light switch.
After retuning to the Saturn after a stop at the gas station, I start the car and within seconds I thought I smelled something hot. Not long after that smoke started rolling out of the steering column. I shut off the car, waited about five minutes, and turned everything off (radio, lights, etc.) The car started fine and no smoke, I drove the car directly home and started going over it. One by one I started turning on things, when I got to the lights I noticed the RPMs drop a little and the hot smell returning. After removing the steering column cover, I found a nice mess with the 6 wires going the turn signal/light switch. The orange and black wires had completely burned up, and had damaged the 4 remaining wires going to the switch and several others further back in the wiring harness.
The car runs fine as long as the lights are not used. Before I start repairing this mess, I would like to know a couple things.
1. Why did a fuse not blow? From what I can tell, there is a 10 Amp fuse in this circuit. I would think that more than 10 Amps where in the wires to completely burn off the insulation.
2. Could this be a possible recall case?
3. The causeÖ Iím thinking bad turn signal/light switch, but I have not pulled the switch yet to check.
Add to Bookemdano's Reputation
Rate the quality of this post and help Bookemdano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bookemdano is offline   Reply With Quote
Old 01-09-2010, 07:26 PM   #2
Default Re: HEAVY smoke from steering column
The reason the fuse does not blow is you had a couple of fuses in parallel when it all stated to melt together. These are the 98-99 wiring diagrams, you will need them before you are done. This is only the head lights section of the switch.
Welcome to the Forums!
Old 01-11-2010, 12:20 PM   #3
Bookemdano
Thank you for the information! Does anybody know if the turn signal/head light switch can be purchased from other than the Saturn dealer? They want $163.00 for this part!!
Old 01-11-2010, 12:47 PM   #4
Check RockAuto under electrical switches for your year and model. If they do not have it then check the price at Get Saturn Parts http://www.trademotion.com/splash/in...?siteid=214643
Old 01-11-2010, 01:26 PM   #5
ttreibel
ttreibel is on a distinguished road
ttreibel's Avatar
2006 ION-2 Quad Coupe
2002 SL1
I paid less than 30 bucks for both the turn signal and light switch either from a wrecking yard or ebay not sure which. The switch was used but is still working fine 4 years later now. Often there is somebody parting out a Saturn on craigslist too, not a fun repair by any means.....disabling and removing airbag....pulling the steering wheel......good luck!
1995 SL1 oil burner school commuter looks nice...1997 SL1 Gold 5-speed with new junk yard wheels and tires just got 40.4 MPG....2002 SL1 sometimes 45 MPG on a spring highway drive
Add to ttreibel's Reputation
Rate the quality of this post and help ttreibel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ttreibel is offline   Reply With Quote
Old 01-11-2010, 01:46 PM   #6
^^^^ Oh, it's not THAT daunting. Remove the fuse and WAIT 30 MINUTES to disarm the air bag. Buy or free-rent a puller for the wheel. The potential snag is those silly 5.5mm-head fasteners for the column covers, in those narrow recesses. You need either a dedicated nut driver, or a socket with the outer wall ground down to fit the recess. Same tool needed to remove the clockspring, IIRC.
But +1 on eBay, Craigslist, salvage yard. IIRC I paid $30, shipped, for one on eBay, and that was for a harder-to-find wagon-specific switch assembly.
Add to madpogue's Reputation
Old 01-11-2010, 01:49 PM   #7
RobertGary1
I can't imagine any benefit to buying a new switch. Just purchase one from a wrecking yard either locally or you can often find them on eBay. Some parts make sense to buy new, others (such as this) do not.
-Robert
Old 01-11-2010, 05:27 PM   #8
The wrecking yard approach works if you can go extract it yourself from a car that is in good shape. It is a fairly durable component so the J/Y approach is viable.
Old 01-11-2010, 07:33 PM   #9
SLCraig
I had the headlight switch go back when I had my 2001 Neon... I have yet to hear of one of these ones going. The switch on the S series seems fairly solid overall. Bad luck!
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-11-2010, 07:41 PM   #10
The wiring in multifunction switches is a well known failure point. Its a matter of proper wire dress when assembling so it is not pinched. If they are assembled properly they last a very long time.
Sizzle sound, smoke out of steering column, now electrical problems! Thoughts? flyhop S-Series Tech 9 02-06-2006 11:22 AM
Heavy Steering RustyBear Vue General 8 10-15-2005 09:28 AM
Smoke came out from the steering column (SL1) NikkiYahew S-Series Tech 5 07-29-2005 09:22 AM
rubbing noise steering wheel/steering column on 04 Vue ynotps Vue General 6 03-03-2005 07:59 PM
Black Smoke Under Heavy Acceleration piratepress Miscellaneous Tech 5 10-02-2002 01:57 PM
