Old 10-07-2009, 01:23 PM   #1
RobertGary1
Default 06 V6 100K service timing belt
I was looking through the service tables in my Alldata subscription and found it interesting that Saturn actually requires very few things of a 100K service on the engine. Really its just valve adjustment, timing belt, plugs.
Notice they are not recommending
1) not tensor
2) not water pump
3) not pullys (idler or tensor)
4) not cam sprockets
5) not seals crank or cam
I know a lot of people talk about doing this stuff at 100K but I'm thinking I'll skip it until its necessary. Right now I"m considering just doing the belt and the pullys and will not do anything else unless I see a problem with the pump, leaking oil or a bad tensor.
Does this board have service experience that says otherwise? Is there really a need to do more than Saturn says?
-Robert
Old 10-07-2009, 01:41 PM   #2
Chazberry
Chazberry's Avatar
Default Re: 06 V6 100K service timing belt
So far I've only got L81 experience, but fwiw - I didn't have any visible timing belt wear after 93k - it definitely had a lot more life left in it. But I think it was prudent changing the tensioner and idlers. The water pump had nothing to do with my timing belt, but for $58.79, while I had it exposed, I thought it would be worth not having to worry about that for a long time. Certainly no need to replace sprockets.
Add to Chazberry's Reputation
Old 10-07-2009, 01:46 PM   #3
RobertGary1
I'm looking at the following prices
tensor - Kragen Gates = $125 or Saturn = $121
water pump - Kragen $70-$95 depending on brand or Saturn = $135
If it were a few bucks I would just do them but these seem to be very "valued" parts. The tensor is hydrolic, not sure if its the same for the L81.
-Robert
Old 10-07-2009, 02:17 PM   #4
Chazberry
Chazberry's Avatar
-Robert
This is the hazards of having a Japanese engine - parts are going to cost double. See attached for what you get in the Gates kit for $205. The L81Tensioner is spring loaded.
Old 10-10-2009, 06:17 AM   #5
kodak_jack
kodak_jack is on a distinguished road
kodak_jack's Avatar
We've discussed this job in the past and have seen prices of upwards of $1,000 for a dealer to do it and less for your local guy to do it. Are there special tools needed? How do you hold the timing where it should be when you're in there routing around? If your Vue has 90,000+ on it, doing the water pump while it's apart is very prudent. With 90,000+ on it, I don't think I'd risk ruining the whole top end if it's only a $300 DIY job.
Add to kodak_jack's Reputation
Rate the quality of this post and help kodak_jack reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kodak_jack is offline   Reply With Quote
Old 10-10-2009, 08:17 AM   #6
Chazberry
Chazberry's Avatar
I had instructions that came with the Gates kit and some that I downloaded from Autozone. I found them both to be very confusing because of all the bogus "special tools" they wanted you to use. I've become convinced that special tools are somebody's lame attempt at a money-making scheme. I wound up resorting to common sense. The only thing I think you need is something to stop the Cam Spockets from moving - see this thread . . .
http://www.saturnfans.com/forums/sho...d.php?t=144381
Old 10-10-2009, 10:05 AM   #7
Chazberry
Chazberry's Avatar
Oops! I'm talking 3.0L and you're talking 3.5. Maybe someone else knows if special tools are needed for the Honda 3.5?
Old 10-10-2009, 11:55 AM   #8
3RedLines
3RedLines has a spectacular aura about3RedLines has a spectacular aura about
3RedLines's Avatar
2004 VUE Red Line
2004 VUE Red Line
No special tools needed on the 3.5l
2007 STS-V
2006 STS 1SC
2005 STS 1SE MRC, ACC, HUD
Add to 3RedLines's Reputation
Rate the quality of this post and help 3RedLines reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
3RedLines is offline   Reply With Quote
Old 10-10-2009, 12:30 PM   #9
nitroussaturn
nitroussaturn will become famous soon enough
nitroussaturn's Avatar
i did a writeup on this,,only speacial tool u need is to remove the crank pully and its only like 30$
2004 REDLINE FWD TONS OF MODS..CLICK HERE http://www.cardomain.com/ride/3144619
1999 MERCEDES BENZ AMG E55,MY DD VETTE KILLER
2000 328I M3 RIMS
Add to nitroussaturn's Reputation
Rate the quality of this post and help nitroussaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nitroussaturn is offline   Reply With Quote
Old 10-12-2009, 11:39 AM   #10
RobertGary1
Everytime I've looked for this holding tool its been near $200. However, I figured I didn't need it since I have an impact wrench. I'm assuming that a few hits of the impact would do it. However, the holding tool would be useful if cam sprokets need to be replaced.
-Robert
Old 10-12-2009, 01:33 PM   #11
3RedLines
3RedLines's Avatar
2004 VUE Red Line
2004 VUE Red Line
Less than 20 bucks here: Crank Tool
Impact tool wouldn't budge mine and I had to use a floor jack to push the breaker bar hard enough to break the crank bolt loose after installing the holding tool
2007 STS-V
2006 STS 1SC
Old 10-12-2009, 07:25 PM   #12
RobertGary1
Holy Crap! They're calling for 180 ft/lb of torque on that bolt? Jesus, did they have problems with them flying off at 100 ft/lbs? So I'm guessing that this tool, my 1/2 driver breaker bar and my 800 ft/lb impact wrench should do the job?
-Robert
Old 10-13-2009, 04:15 AM   #13
kodak_jack
kodak_jack's Avatar
How do you hold the timing where it should be? Is there enough room in that area to use an impact gun and/ or all the other stuff that comes to mind? What else have you guys replaced while you're in there? The water pump? What else?
Old 10-13-2009, 11:44 AM   #14
RobertGary1
Saturn's recommendation for the 100K service is *only* the belt, no pullys, no tensor, no water pumps, etc. Just the timing belt. The tensor on the 3.5 is a lot more sophisticated than the older motors that were spring driven.
-Robert
Old 10-13-2009, 11:45 AM   #15
3RedLines
3RedLines's Avatar
2004 VUE Red Line
2004 VUE Red Line
The 3.5l is a single overhead cam where the 3.0 is dual cams. The single cam tends to hold its position better than the dual due to more even pressure on the cam lobes from the intake and exhaust valves.
Hope that makes some sense
Oh, and replace that water pump while you're in there.
2007 STS-V
2006 STS 1SC
Old 10-13-2009, 05:23 PM   #16
kodak_jack
kodak_jack's Avatar
Yes, definitely replace the water pump. Hey, you have some neat vehicles in your driveway!! I like the Fiero GT's.
Timing Belt service Saturngirl4ever Vue Tech 21 12-11-2009 07:34 PM
100K Time Belt Change hilarski Vue General 9 12-20-2007 05:56 AM
100K Timing Belt Change V6 AWD Vue hilarski Vue General 0 12-17-2007 07:56 PM
3.0 V6: Replace Timing Belt at 100K Miles? canoecrafter L-Series Tech 5 02-24-2007 02:08 AM
Service Wrench light after timing belt replace aaront L-Series General 4 07-13-2006 02:03 PM
