Old 06-08-2009, 04:01 PM   #1
goBoating
goBoating will become famous soon enoughgoBoating will become famous soon enough
goBoating's Avatar
2004 VUE 3.5L
2008 AURA XE
Default 2004 V6 Vue
Hello All,
My wife's 2004 V6 Vue (~50K miles) has a new trick. If the head lights are on, the left turn indicator stays lit.
If the headlights are not on, when you turn on a turn signal, the odometer LCD and radio display dim and brighten in sync with the blinker.
It appears that everything still works. (Come to think of it, I have not checked all the bulbs.)
What's up with that?
Don't Tread on Me
A strict constructionist fiscal conservative free market freak I am.
"The problem with socialism is that you eventually run out of other people's money." - M. Thatcher
Add to goBoating's Reputation
Rate the quality of this post and help goBoating reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goBoating is offline   Reply With Quote
Old 06-09-2009, 10:32 PM   #2
VTchemist
VTchemist's Avatar
Default Re: 2004 V6 Vue
If you have checked all your bulbs and none are out, it may be the Body Control Module (BCM). It controls most of the lighting and electrical components. It's not a DIY; a dealer has to program it. Total cost is ~$400.
A first attempt to remedy the problem is to disconnect the battery for at least 30 minutes. The onboard computers will reset their memories. This may fix your problem.
You can search the site for BCM failures and see what other folks have seen and done with BCM problems.
Add to VTchemist's Reputation
Rate the quality of this post and help VTchemist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-09-2009, 11:02 PM   #3
far2grumpy
far2grumpy's Avatar
Originally Posted by goBoating View Post
Hello All,
I've attached a hazard flasher and turn signal schematic. There's at least one error on schematic as the right and left turn signal switches are reversed.
My prime suspect to cause this problem is if one of the combo left turn/park light bulbs are bad ... shorted.
A shorted bulb would provide a path for park light voltage to return to turn signal circuits.
Old 06-10-2009, 11:27 AM   #4
goBoating
goBoating's Avatar
2004 VUE 3.5L
2008 AURA XE
Hmmmm.... 'seems like I remember something about bulbs causing unexpected symptoms.
I'll check them.
And, thanks for the schematic and battery disconnect ideas.
Don't Tread on Me
Old 07-21-2009, 10:16 AM   #5
goBoating
goBoating's Avatar
2004 VUE 3.5L
2008 AURA XE
Finally got the Vue to the shop and they quickly identified the problem. The U-haul trailer hitch and wiring are to blame. The pig-tail wiring has a switching module of some sort that is after the Vue tail lights and before the end of the pig tail. U-Haul installed the the module (3" x 4" x 1/2" plastic encased) so that is was suspended just above the tail pipe where it likely got very hot. And, thus it got toasted, literally, and no longer works. Now, the Vue lights all work correctly and I just need to rework the pig tail wiring.
Don't Tread on Me
Old 07-21-2009, 10:30 AM   #6
far2grumpy
far2grumpy's Avatar
goBoating ... good to see you're all fixed up.
I question why U-Haul installed trailer wiring underneath the Vue. One of the better options - especially if you use the typical four wire flat cables - is to wire into the pigtail provided in the jack stowage compartment.
You can leave the cable rolled up and out of the way until needed. The rear hatch weather seal will close over the cable when you deploy to use with a trailer.
Old 07-21-2009, 10:12 PM   #7
davcon
davcon is on a distinguished road
davcon's Avatar
battery disconnect is an old wives tail - does not work anymore.
'04 Black Vue
Add to davcon's Reputation
Rate the quality of this post and help davcon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davcon is offline   Reply With Quote
Old 07-21-2009, 10:26 PM   #8
1saxman
You should have told us about non-original electrical work/parts on the vehicle, since that would have been the prime suspect.
Add to 1saxman's Reputation
2004 Vue V6 Help jfulle5 Vue General 8 09-09-2008 06:31 PM
2004 Ion 2 or 2004 Vue? (or taking advice from complete strangers) kennywhy General Saturn Discussion 11 12-28-2004 01:30 PM
2004 Saturn Vue Red Line: Finally, Some Zoom With a Vue (New York Times) DualCamCoupe Vue Red Line 21 03-17-2004 04:01 PM
2004 Vue hugh Vue General 6 12-05-2003 07:25 PM
2004 VUE V. 2004 Subaru 2.5XT taxlaw Vue General 0 07-15-2003 03:18 PM
