Old 01-18-2009, 03:59 PM   #1
lrslooney
lrslooney is on a distinguished road
Sad 2001 Saturn A/C Heat Blower stopped working
Can someone help me. My 2001 Satrun L200 heater, A/C air stopped working. Not knowing much about cars. I checked the fuses and replaced the A/C Relay.. Wishing that would fix the problem.. NOPE.. Auto parts store thinks it may be the blower died / blower motor. Does anyone know where the location of the blower motor and is this a easy thing to replace myself?
Thanks, Cold in Idaho... lrslooney
Add to lrslooney's Reputation
Rate the quality of this post and help lrslooney reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lrslooney is offline   Reply With Quote
Old 01-18-2009, 04:29 PM   #2
fdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud of
Default Re: 2001 Saturn A/C Heat Blower stopped working
1-You do not need a/c for heat and the a/c failure itself has nothing to do with the blower.
2-Have you looked in the driver and passenger footwell areas for additional fuses? The access covers will have information embossed onto the inside of the covers as a guide to fuse application.
3-The blower is usually located on the passenger side under the dash - the large roundish looking thing taking up space near the glove box. Blowers hardly fail as much as fuses, switches, the printed circuit board containing the three-speed resistors to vary the fan speed, and the wiring.
*The CPS is the heart of the entire EFI system. No cps = dead EFI system*
*There's more to a/c than just a few cans of refrigerant*
*There's more to brakes than just replacing parts*
Old 01-18-2009, 04:39 PM   #3
lrslooney
fdryer - The a/c light comes on but no air comes out and the same with the heat.
I checked the underhood fuses, and the fuses on both sides of the foot well. All is fine..
A few days ago the heater was on high when all of a sudden it stopped. I just turned the heat off and then back on again and it was fine. working like normal, untill two days ago it just wont come on - no air blowing out..
lrslooney
Old 01-18-2009, 05:14 PM   #4
Although I don't have a wiring diagram for an '01, this seems to me like an overheating wire connection issue with your latest info. Some poking around, starting at the fan area where the wiring exits and disappears into the main harness', some wiring going to the resistor card (may be hidden from view) where the three speeds are controlled from, back to the control panel, may reveal a burned/discolored wire or two. Using the HI fan setting uses the most power and connections usually suffer if they're loose, resulting in excess current heating the connection instead of going to the motor. Look for it. It may help to simply set the fan on LO or MED speed with or without the engine running and tugging the wiring in and around the blower motor which may result in a re-connection. Tug/pull/push slowly and stop to listen to the blower starting up as the last movement of wiring may lead you to the something. Having a wiring diagram would help. Removing the connector to the fan and wiring it directly to the battery will tell you whether or not the fan is worn out.
2001 Saturn L200 4 cylinder Blower Not Working Varagon L-Series Tech 19 02-26-2013 04:53 PM
2000 Saturn L Series HVAC Blower Stopped omahaseo L-Series Tech 32 03-09-2010 08:21 AM
2004 saturn vue , ac/heat blower motor no power iamyourtech Vue Tech 3 09-08-2009 09:40 PM
2001 L300 AC/Heat Fan Not Working NoDents L-Series General 6 10-25-2005 09:04 AM
2001 SC1 - A/C stopped working all of a suddden.... Overfloater S-Series General 1 07-07-2005 01:53 PM
