Old 11-25-2008, 01:30 PM   #1
tkeahi
tkeahi is on a distinguished road
Default 1998 SL1 No Start: No Fuel, No Spark, big Problem
I bought this 1998 SL1 from a person who said "it doesn't start and my friend the mechanic says it needs a new computer." I'm trying to do my own homework but need help figuring out what else I should be looking at before I blame the computer.
Here's where I am:
-The car cranks but does not start.
-No codes from the computer
There is fuel pressure at the fuel rail but when I pull the plugs after cranking the car they are dry.
-There is no spark at the coils (as tested by the 'pull the plug wires off and see if spark jumps towers' test)
-There is power to the coils (thanks for the youtube videos, richpin!)
-The CPS has been replaced and tests good for output (again, using the guidance in richpin's video)
Any other things I should be looking at to solve this mystery? Thanks!
Add to tkeahi's Reputation
Rate the quality of this post and help tkeahi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tkeahi is offline   Reply With Quote
Old 11-25-2008, 01:34 PM   #2
Cheyne
Cheyne will become famous soon enough
2000 SL2
Default Re: 1998 SL1 No Start: No Fuel, No Spark, big Problem
Have you checked for corrosion at the coils?
Add to Cheyne's Reputation
Old 11-25-2008, 01:51 PM   #3
Cheyne
2000 SL2
Also, what about the condition of the wiring to the cps?
Old 11-25-2008, 02:09 PM   #4
Checked for a blown PCM fuse?
Old 11-25-2008, 02:12 PM   #5
Cheyne
2000 SL2
Yep. Much better place to start. Can't believe I missed that one.
Old 11-25-2008, 02:27 PM   #6
tkeahi
PCM fuse(s) are good. IGN fuses are good as well.
Old 11-25-2008, 02:36 PM   #7
tkeahi
Thanks for the idea. I will jack it up and take a look today. If the computer were not getting the CPS signal for some reason (say wiring issues, for example) would the computer throw a code?
Old 11-25-2008, 02:38 PM   #8
No, and a lack of CPS signal will kill the fuel injection, and spark. The starter will run and crank though.
Old 11-25-2008, 02:38 PM   #9
Cheyne
2000 SL2
Perhaps not. There was no code when my cps went out.
Old 11-25-2008, 02:39 PM   #10
tkeahi
Is there any way to check that the CPS signal is getting to the computer?
Old 11-25-2008, 03:06 PM   #11
If you have checked for spark at the coil towers by cranking over the engine then the next step is to replace the CPS. You could check its resistance but since its such a pain to get at just put in a new one. Be sure the new one is all the way in. the bolt will not pull it in completely.
Old 11-25-2008, 04:00 PM   #12
Being that you're on an island and have to depend on doing it yourself, look over the wiring in general and locate the PCM. The cps wiring has to wind up connecting to the PCM and the PCM must be plugged in and look like its never been removed. In other words no one has tampered with it or been at it trying something. Everything should look normal and not out of place for a 10yr old car. The cps wiring will disappear into the main harness and not look out of place either unless you can actually find broken wiring. You'll need a wiring diagram to trace where the signals wind up in the PCM.
There's also the possibility of the ignition module fault that also kills the spark. Have a known good ignition module to swap?
Old 11-25-2008, 06:30 PM   #13
Cheyne
2000 SL2
Have you hooked it up to a scanner? Checked the ground and power leads to the pcm?
Old 11-26-2008, 12:58 AM   #14
rc1488
rc1488's Avatar
Re install you CPS. If it is not seated correctly ( even 1mm pulled out) it will not work right. It MUST be pushed in fully. One member went through...3? CPS's and found out...he didnt push it in all the way each time. Do not count on the bolt to push it in.
Add to rc1488's Reputation
Old 11-26-2008, 01:10 PM   #15
The bolt will definitely not pull it in but it will break it. If you need to see what you are doing remove the passengers side wheel and splash shields.
Old 11-28-2008, 05:37 PM   #16
tkeahi
The CPS was the first thing I replaced and I did test it for output with a voltmeter but I will doublecheck to make sure it is pushed in fully.
Thanks for the advice guys...keep the suggestions coming, I am going to work on it today and will keep you posted.
Old 11-28-2008, 06:04 PM   #17
Unless you have an eye ball on the end of your finger you need a mirror to see if its all the way down in the block.
Old 11-28-2008, 06:59 PM   #18
tkeahi
Default Re: 1998 SL1 No Start: SOLVED
Thanks to all...the car is now FIXED!
I replaced the CPS with a known good CPS out of another car and it starts and runs perfectly. The CPS that was in there before was brand new and fully seated but must have been bad from the store. Thanks to everyone who helped keep me focused on the CPS.
Aloha
Old 11-28-2008, 07:02 PM   #19
Cheyne
2000 SL2
Another Saturn back on the road where it belongs.
No Start, 93 SC2 (Got spark and fuel) SC2 93 S-Series Tech 11 10-31-2009 08:56 AM
1998 SL1 Won't Start! JRROGERS S-Series Tech 4 02-20-2008 03:08 PM
1998 SL1 won't start cold HDR S-Series Tech 8 02-14-2008 12:11 PM
No spark, got fuel pressure, new cps, but still no start! delturcious S-Series Tech 41 09-13-2006 09:16 PM
has spark, air and fuel but wont start kre8ive_kustomz S-Series Tech 28 06-23-2006 10:06 PM
