Old 09-26-2008, 10:02 PM   #1
GROVERBOY
GROVERBOY is on a distinguished road
Default radiator drain valve
I have a 2002 SC1 and want to change the antifreeze( 1- @ 96000km do I need to and (2 if I do, how do you loosen the drain plug as it is a weird one. Thanks
Add to GROVERBOY's Reputation
Rate the quality of this post and help GROVERBOY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GROVERBOY is offline   Reply With Quote
Old 09-26-2008, 10:45 PM   #2
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1991 SL2
Default Re: radiator drain valve
1/4" drive rachet with a short extension works wonders... . Turns about 90 degrees and pulls out. I always keep a spare (about $4.50 at the dealer) since I usually round out the square hole on it.
Add to MiSaturn's Reputation
Rate the quality of this post and help MiSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MiSaturn is offline   Reply With Quote
Old 09-27-2008, 10:16 AM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
I take it you must be using a socket like this.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 09-27-2008, 10:49 PM   #4
Tiger
Tiger's Avatar
I had a hard time figuring it out also. Thought I would break the plastic on mine. The o-ring stuck and finally broke loose. I epoxied a piece of metal to the part you grip which gave me more leverage without tools. Worked like a charm. Now I have a new radiator and my modified drain cock went to the scrap heap. Lefty loosey.
Add to Tiger's Reputation
Old 09-28-2008, 10:58 AM   #5
PurdueGuy
PurdueGuy's Avatar
1999 SC1
why would he be? The drain plugs on saturns I've seen have a square hole in the middle that are a perfect fit to a 1/4" ratchet...
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 09-28-2008, 10:59 AM   #6
The drain plug on my original 98 radiator has a little flat oval handle on it that the wrench on the right would fit just fine.
Old 09-28-2008, 11:43 AM   #7
Low Saturn
Low Saturn's Avatar
2000 SC2
I have four OEM radiators and one aftermarket outside. No square hole.
Mike
-2000 Saturn SC2
Old 09-28-2008, 11:46 AM   #8
hmmm, mine looks just like #2..
Old 09-28-2008, 12:01 PM   #9
Low Saturn
Low Saturn's Avatar
2000 SC2
Nice and clean.
Mike
-2000 Saturn SC2
Old 09-28-2008, 05:20 PM   #10
white95SL1
white95SL1 is on a distinguished road
white95SL1's Avatar
1992 SC
2004 VUE Red Line
My '01 SC2 had a drain plug with a square hole that you put a 1/4" ratchet into. I'd never seen one before that, so I was confused at first. All of the others I've seen were like the ones posted above.
Brandon
'92 Saturn SCm- Red & Silver (rebuild in progress)
'04 Saturn VUE Red Line- Black Onyx
Add to white95SL1's Reputation
Rate the quality of this post and help white95SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
white95SL1 is offline   Reply With Quote
Old 09-28-2008, 09:57 PM   #11
DIYguy
DIYguy's Avatar
Happy Re: radiator drain valve
Both my original and the ReadyRad replacement had/have the 1/4" square hole plug. No "wings" at all. I wish the present one had a plug like the ones shown above.
However, I happen to have a 1/4" square drive "L" shaped wrench left over from an Ikea build. Works like a charm. I honestly hadn't thought of using a 1/4" drive ratchet because I have the wrench and didn't even stop to consider anything else....
Great idea though. Perhaps I'll try the ratchet next time because space it tight where it is located (on mine anyway).
DIYguy
Quando Omni Flunkus Moritati
97SC2 Saturn, Cruze Eco, Chevy SS P/U, Honda VT1100C
Add to DIYguy's Reputation
Rate the quality of this post and help DIYguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-29-2008, 12:00 AM   #12
Growser
Growser is on a distinguished road
Growser's Avatar
Just a thought, when I'm at a pull your own junk yard I look for the old style drain valve, and keep a couple on hand for my newer Saturns. They usually don't even charge me for the plug.
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Add to Growser's Reputation
Rate the quality of this post and help Growser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Growser is offline   Reply With Quote
Radiator drain plug wishihadacamaro S-Series Tech 6 11-15-2008 11:27 PM
radiator drain valve saturnsctwo S-Series General 13 05-12-2007 03:58 PM
Radiator Drain _PuNiShEr_ S-Series Tech 5 04-03-2006 04:53 PM
How much coolant in the if I drain the radiator johnyrrr S-Series General 3 10-17-2005 12:52 PM
Radiator drain problems maracle Miscellaneous Tech 3 07-18-2004 06:50 PM
