Old 07-19-2008, 12:42 AM   #1
eibbor
eibbor is on a distinguished road
2000 L-Series 3.0L Wagon
Default Ignition won't turn
I put the key in the ignition and it won't turn, I tried taken pressure of the steering wheel by trying to turn it and made sure it is in park. Are there any adjustments on the column to make it work.
Add to eibbor's Reputation
Rate the quality of this post and help eibbor reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eibbor is offline   Reply With Quote
Old 07-19-2008, 02:09 AM   #2
Default Re: Ignition won't turn
What year, model? Playing twenty questions gets very old around here so its easier to put your car info into your personal profile for automatically popping up when you post problems.
Have you tried your spare key that hasn't been worn down? Lock cylinders can wear down as well as igntion keys preventing rotation. The steering column lock also needs to be positioned just so before releasing excessive pressure on the ignition cylinder.
Old 07-19-2008, 05:55 PM   #3
eibbor
It's a 2000 LW2 with V-6.
Old 07-20-2008, 08:35 AM   #4
eibbor
Got it, I kept trying and it finally turned when I put the reverse side of the key in. This has happened before with the cars ignition, my wife parked the car in the garage with the front wheels slightly turned. I think this has something to do with it. The other time it happened it was in the garage as well.
Old 07-20-2008, 08:55 AM   #5
s3nfo
s3nfo has a spectacular aura abouts3nfo has a spectacular aura abouts3nfo has a spectacular aura about
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Common problem with the earlier L's. There's a TSB on ignition problems and the dealer will have to replace and re-key the ignition. If you don't get it fixed, eventually your key will get stuck in the ignition.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 01-16-2010, 04:14 PM   #6
crispy5
crispy5 is on a distinguished road
Any idea where I can print out that TSB? I have a 2000 LW2 with the same issue.
Add to crispy5's Reputation
Rate the quality of this post and help crispy5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
crispy5 is offline   Reply With Quote
Old 01-17-2010, 08:52 AM   #7
s3nfo
s3nfo's Avatar
Every place I know to print out TSB requires a subscription. I don't know of any free page. If you still have a Saturn dealer open near you, go ask them to print it out for you, never been told "no" when I've asked the dealer for a copy of a TSB.
Jerry N
Groucho Marx
Old 01-17-2010, 10:39 AM   #8
ernesto rex
ernesto rex is on a distinguished road
ernesto rex's Avatar
2000 L-Series 3.0L Sedan
BULLETIN NO.: 01-T-23
ISSUE DATE: April, 2001
CATEGORY TYPE: Electrical - 01
CATEGORY: Locks and Security
CORPORATION NO.: 01-08-110-002
TECHNICAL INFORMATION BULLETIN
SUBJECT:
Ignition Key Binds or Does Not Turn Out of the LOCK Position
(Replace Ignition Lock Cylinder, Tumblers and Springs)
MODELS AFFECTED:
2000 - 2001 Saturn L-Series and S-Series Vehicles
CONDITION:
Some customers may comment that the ignition key will not turn out of the LOCK position.
CAUSE:
This condition is caused by one or more of the ignition cylinder tumblers binding in the ignition cylinder tumbler body.
CORRECTION:
Refer to the procedure detailed in this bulletin to replace ignition lock cylinder, tumblers, and tumbler springs.
IMPORTANT: This bulletin contains separate service procedure for L-Series and S-Series Vehicles.
^ For L-Series vehicles, refer to this bulletin.
^ For S-Series vehicles, refer to this bulletin.
"So, this is where dreams come to die."
SGT Richard McCarthy, 2-127th IN Regiment, 32nd IBCT
Camp Bucca, Iraq
Add to ernesto rex's Reputation
Rate the quality of this post and help ernesto rex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ernesto rex is offline   Reply With Quote
Old 01-17-2010, 06:25 PM   #9
crispy5
Much appreciated!
Ignition won't turn off GlennCoco S-Series Tech 14 02-18-2009 09:47 PM
ignition wont turn keek S-Series Tech 3 10-14-2007 01:12 PM
Sl-1 1999 Ignition Won't Turn WCEE S-Series Tech 2 07-15-2007 10:17 PM
Key won't turn in ignition moore_y Vue Tech 9 05-20-2006 09:18 PM
ignition does not turn all the way -ONLY when cold MBman S-Series General 0 01-22-2005 08:19 PM
