Old 07-15-2008, 09:36 AM   #1
livingproofofit
livingproofofit is on a distinguished road
Default How To Get Your Saturn To Stop Burning Oil!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ok I Was Previously Using 5w30 Castrol Gtx High Mileage Oil
Since Last Oil Change I Tried Penzoil 5w30 High Mileage Oil And It Stopped It Form Burning Oil I Used To Add 3 Quarts Every Oil Change I HAVENT Added Any At All In The Last 5 Weeks I Used To Have To ADD HALF A QUART at Least Once A Week Or More Depening On How Much I Drove!!!!!!!!!!!!!!!!!!!!!!
every 100 miles id add some
\holy ****!!!!!!!!!!!!!!!
I Spoke To A Car Repair God The Other Day Who Has A Radio Talk Show And He Said Penzoil Is One Of The Better Bigger Oil Companies Therefor Their Products Are Better!!!!
Ps Youre Welcome I Guess You Wont Be Needing That Valve Job After All?
Im The Man If Only Saturn Had Me Working For Them.. Wait Then Id Be Helping Them Rip U Guys Off
190K 1995 SL2
Add to livingproofofit's Reputation
Rate the quality of this post and help livingproofofit reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
livingproofofit is offline   Reply With Quote
Old 07-15-2008, 09:38 AM   #2
tarsun
tarsun is on a distinguished road
Default Re: How To Get Your Saturn To Stop Burning Oil!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
re-ring your engine..... thats about it.
Add to tarsun's Reputation
Rate the quality of this post and help tarsun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tarsun is offline   Reply With Quote
Old 07-15-2008, 09:54 AM   #3
OnDaGround
OnDaGround's Avatar
1993 SC2
tis about the only way... But I wonder if they would start leaking again as the age of the new rings continued. Though it would be wonderful. I would like to get a new motor and put it in... but If i had that much money I wouldn't buy a new motor, I'd buy a new car or a supra... or something like that.
Saturnless...
Old 07-15-2008, 10:53 AM   #4
Kal
Kal is on a distinguished road
Kal's Avatar
I use Castrol High Mileage Oil. Doesn't burn near as much, but however, I think I liked how it ran better on the Syntec Blend.
Add to Kal's Reputation
Rate the quality of this post and help Kal reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kal is offline   Reply With Quote
Old 07-15-2008, 11:21 AM   #5
Try a little Pennzoil on that STUCK SHIFT KEY.....
Add to madpogue's Reputation
Old 07-15-2008, 11:58 AM   #6
froggy81500
froggy81500 is on a distinguished road
2006 ION-2 Sedan
Items that will also stop it from burning oil: stop driving it or stop putting oil in it.
problem solved and the environment will be safer.
Add to froggy81500's Reputation
Rate the quality of this post and help froggy81500 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
froggy81500 is offline   Reply With Quote
Old 07-15-2008, 03:09 PM   #7
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1991 SL2
[QUOTE=livingproofofit;1282224]I Used To Add 3 Quarts Every Oil Change I HAVENT Added Any At All In The Last 5 Weeks QUOTE]
Add straight STP and you won't bury any oil at all! Even if you can get your car to start.
And we're sure about it burning oil vs. leaking it? Can't imagine what a "high mileage" oil does differently that would make it burn less... . I can picture it swelling seals to make a "mature" engine leak less oil.
Might a heavier weight oil (10W30 or 10W40) conventional oil be a cheaper alternative?
Add to MiSaturn's Reputation
Rate the quality of this post and help MiSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MiSaturn is offline   Reply With Quote
Old 07-15-2008, 03:39 PM   #8
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
STP is the first full syn oil that was offered ,kept many an old Chevy from losing oil pressure at operating temps, It won't burn ,or lose viscosity !
But it will scorch ,then lock up assemblys ,without some dino to flow it on through,or thin it out .
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Old 07-15-2008, 05:32 PM   #9
STP is a can of VI improver and it is synthetic. VI improver=viscosity index improver.
Old 07-16-2008, 09:02 AM   #10
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
Don't discount the goodness of thin oil either.
I've only lost a pint in 2000 miles using 5W20 Pennzoil yellow - 130,000 mile engine.
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-17-2008, 05:47 PM   #11
westwind999
1999 SW1
I've been having good luck with Auto-rx. It's not an instant cure but it does make improvements without causing damage. Very well reviewed on bobistheoilguy, lots of independent tests. So far it's cost me about $40 to treat my SW1, lot's cheaper than new rings.
Old 07-18-2008, 09:51 AM   #12
ShuttlecraftX47
ShuttlecraftX47 is on a distinguished road
1993 SW2
Cool science that the stuff works. I guess the question is what oil to use next - do you keep using the treated oil, which some say will over-treat the gaskets, or keep using it? From what I read, what you're experiencing is likely a temporary fix, and that other gaskets throughout the engine could possibly end up worse off - ??? My 2cents is to switch back to regular oil on the next change ~
Add to ShuttlecraftX47's Reputation
Rate the quality of this post and help ShuttlecraftX47 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShuttlecraftX47 is offline   Reply With Quote
97 Saturn Sl2 Burning Oil kickinazz S-Series Tech 22 11-17-2008 06:22 PM
1994 Saturn Sc2 Burning oil. Racer93 S-Series Tech 15 04-04-2008 05:17 AM
oil burning saturn woonyboi02895 S-Series General 8 03-09-2008 10:21 PM
Saturn SL1, Oil Burning and general reliability Playincard S-Series General 22 03-22-2007 09:20 PM
How to stop oil burning in S-series quasar S-Series Tech 2 12-14-2006 01:32 PM
