Old 05-01-2008, 02:37 PM   #1
hydromech
hydromech is on a distinguished road
hydromech's Avatar
Default Code P0442 – new gas cap…
Got code P0442. Replaced gas cap, had the code reset. It came back in 3 days… Now it is listed twice...
Any ideas – what else to check? The car is running fine – 31 MPG
2000 Saturn SL1, SOHC, Automatic, 182K
Add to hydromech's Reputation
Rate the quality of this post and help hydromech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hydromech is offline   Reply With Quote
Old 05-04-2008, 10:11 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: Code P0442 – new gas cap…
Since no one answered I'll give you two things to try. First replace the ECTS. Don't know what I'm talking about? Use the forum jump at the bottom of the page and go to the How-To Library. The sticky at the top explains all about it. Also replace your thermostat. If that doesn't do it, replace the cannister purge solenoid.
Add to BarnOwl's Reputation
Old 05-04-2008, 10:44 PM   #3
samsr
samsr is on a distinguished road
2000 L-Series 3.0L Wagon
I just repaire that same code except my code came up as soon as I started the car. It seems that some mice got to the wiring harness by the ecu on my 2000 SL2. The only two wire that it got to were the ones for the purge canister by the fuel tank. Whoed of known. Drove me nuts finding it though. Hope you find it.
15 S-series put back on the road.
Now working on a 2000 LW2 v6 auto. Timing belt, 2 intake valves and more getting discovered.
Add to samsr's Reputation
Rate the quality of this post and help samsr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
samsr is offline   Reply With Quote
Old 05-05-2008, 12:09 AM   #4
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Check air filter, all vacuum lines and ensure air intake clamps are tight. PO442 is the code for a small vacuum leak.
2007 Chevy Equinox LT 180K miles
Add to ruley73's Reputation
Old 05-05-2008, 09:50 AM   #5
hydromech
hydromech's Avatar
Thanks a lot for info and advice, guys.
One thing - this code P0442 first poped up shortly after I did my regular throttle body cleaning with a spray-cleaner... Maybe I created that small vacuum leak myself ??
I already cheched all intake clamps and vacuum connections - look OK.
Is there a diagram for EVAP for Saturn SL ?? It would really help to trace ALL vacuum lines and find a leak...
Old 06-12-2011, 11:39 AM   #6
hydromech
hydromech's Avatar
I'm getting this p0442 code AGAIN
It is ON for a month then OFF for a month... I can't go for Emission Test with that code
Anybody has any idea what to do about it ?
Old 07-05-2011, 11:52 AM   #7
gmyette5NH
gmyette5NH is on a distinguished road
i have the same issue. have u had any resolves?
Add to gmyette5NH's Reputation
Rate the quality of this post and help gmyette5NH reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gmyette5NH is offline   Reply With Quote
Old 07-05-2011, 02:09 PM   #8
manualman
manualman is on a distinguished road
1995 SL
Ideas:
1. Gas cap. Fixed mine (already tried by the OP)
2. Gas filler tube mating surface for gas cap. Any nick or corrosion there will spoil the seal to the cap. Stuff tube with rag, sand well, vacuum up debris, grease lightly to fix.
3. vacuum line to evap solenoid. This is the vac tube from the throttle body that runs straight down under the intake. Sometimes is dislodged from the solenoid.
4. Check all vacuum lines for deterioration. The PCV is classic.
5. Check for intake manifold gasket leak with TB cleaner. Spray along mating surface. If idle speed changes at all, the gasket is bad. Especially common in 3rd gen SOHC engines.
Add to manualman's Reputation
Rate the quality of this post and help manualman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
manualman is offline   Reply With Quote
P0442 code SaturnManiac S-Series General 21 09-30-2013 03:48 PM
P0442 engine code namato1 S-Series Tech 3 09-29-2008 10:48 AM
P0442 code bwfbezerk S-Series Tech 5 05-21-2008 10:42 AM
CODE P0442 Again tay25lor S-Series Tech 2 10-03-2007 08:18 PM
Code 0440 - 03 LW 200 92,000 - Gas Cap? PEBLUM L-Series Tech 5 04-07-2007 03:05 PM
