Old 04-01-2008, 10:08 PM   #1
Pioneer_Saturn
Pioneer_Saturn is on a distinguished road
Pioneer_Saturn's Avatar
Default Type of tranny fluid for 97 SL2
Hey guys,
Also, what type of transmission fluid does my 97 SL2 take?
Thanks in advance
First and only dual-alternator Saturn
"Louder than your Saturn on music or your money back!"
Add to Pioneer_Saturn's Reputation
Rate the quality of this post and help Pioneer_Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pioneer_Saturn is offline   Reply With Quote
Old 04-01-2008, 10:22 PM   #2
banditkaine
banditkaine is on a distinguished road
banditkaine's Avatar
Default Re: Type of tranny fluid for 97 SL2
Saturn Transaxle Fluid (P/N 21005966) is recommended. If not available, DEXRONŽIIE or DEXRONŽIII transmission/transaxle fluid is also acceptable.
Add to banditkaine's Reputation
Rate the quality of this post and help banditkaine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
banditkaine is offline   Reply With Quote
Old 04-01-2008, 10:33 PM   #3
Tiger
Tiger's Avatar
When coming to this forum Mobil 1 transmission fluid was highly recommended. Has worked out well for me.
http://www.mobiloil.com/USA-English/...hetic_ATF.aspx
I came here with reverse slam, a condition that happens when the auto transmission valve body gums up. Seems like the Mobil 1 has kept it from returning in over 50,000 miles.
Add to Tiger's Reputation
Old 04-02-2008, 10:06 PM   #4
05vueblue
05vueblue is on a distinguished road
How often should the fluid be changed on the 2000 sl1 tranny? do you need to change the filter that is on it? I just bought this car and noticed it has a filter that look like and engine oil filter. In another thread someone said never flush the tranny, why?
Add to 05vueblue's Reputation
Rate the quality of this post and help 05vueblue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
05vueblue is offline   Reply With Quote
Old 04-02-2008, 10:57 PM   #5
rc1488
rc1488's Avatar
Automatics are recommended to have the fluid and filter changed every 30k. Some also suggest closer intervals such as every 10k or every 3rd or 4th oil change. The filter is a scew on filter however to NOT mix the ATF filter and the oil filter up
Flushing the tranny is NOT recommended as any particles sitting at the bottom can get stirred up and stuck in various parts of the transmission.
Add to rc1488's Reputation
Old 04-02-2008, 11:24 PM   #6
Tiger
Tiger's Avatar
I always use OEM transmission filters. Some aftermarket ones leak or are not as good (so I have been told). Your owners manual should have a nice write up on changing the fluid. I would just stick with a service interval of 30,000 miles or less. I think later models may say 100,000 service interval. Problem with this transmission is reverse slam which can be caused be extending the service interval. The input shaft nut can come loose and for those who spin tires the diff pin flys through the transmission making a gapping hole. Not a pretty site. You now have all my knowledge of the the S-Series Auto trans.
I used this How-To when changing my transmission fluid. Wolfman was a Saturn Trained Tech. I find many of his posts or write ups very helpful.
http://www.saturnfans.com/forums/showthread.php?t=65426
ATF Fluid Type 97sl2DOHCaut1.9 S-Series Tech 8 12-28-2009 05:24 PM
SL2 Manual Tranny fluid filler Tyrant_007 S-Series Tech 22 12-21-2009 11:23 AM
S-Series Trans Fluid type??? dlacacres S-Series Tech 7 10-31-2009 11:15 AM
tranny fluid, 97 sl2 gr3atm3linko S-Series Tech 2 03-02-2009 08:06 PM
What type transmission fluid? Forrest Vue Tech 4 07-17-2008 04:01 PM
