Old 12-31-2007, 08:16 AM   #1
happycampers116
happycampers116 is on a distinguished road
Default Shifting into overdrive, or not!
My daughter has a 98 SL2 143,000 miles and noticed lately that when you first drive it in the morning it does not want to shift into overdrive for a couple of miles. after that it seems to be o.k. Seems to have started since colder weather has set in. I just changed the trans fluid and filter in September and I just checked to make sure the fluid level is right and everything looks good. Any thoughts on this issue would be appreciated. Thanks, Brian. Oh, and I guess you figured out it is an automatic. sorry
Add to happycampers116's Reputation
Rate the quality of this post and help happycampers116 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
happycampers116 is offline   Reply With Quote
Old 12-31-2007, 10:27 AM   #2
rc1488
rc1488's Avatar
Default Re: Shifting into overdrive, or not!
Change your ECTS?? if not do it. theres a sticky in the How-to
Add to rc1488's Reputation
Old 12-31-2007, 11:24 AM   #3
Project84
Project84 will become famous soon enough
Project84's Avatar
2009 AURA XR
ECTS isn't always to blame for all Saturn issues.
I changed mine less than 3k ago, and I've experienced a poor/failing ECTS several times so I know what it's like.... my car does the same thing. The engine is just running cold. I don't think there is any type of mechanical fix for this problem, my '96 SL2 has done this since day 1.
Have her warm the car up a little before she takes off, or install a remote car starter for her!
John
'09 Saturn Aura XR 2.4L
Previous - '01 SL1 daily driver and '96 SL2 auto 40+mpg hypermiler.
Add to Project84's Reputation
Rate the quality of this post and help Project84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Project84 is offline   Reply With Quote
Old 12-31-2007, 11:34 AM   #4
happycampers116
Thanks for the replys. I did change the ECTS in october but didn't really see any change in anything. I was thinking too it was just the engine and trans are cold because once warmed up it seems to run fine. Not a problem just wanted to make sure it wasn't something major. Thanks again.
Old 12-31-2007, 01:10 PM   #5
hardisk_c
hardisk_c is on a distinguished road
hardisk_c's Avatar
I believe it's mentioned in my owner's manual that the transmission will not shift into overdrive until the temp sensor in the trans says the fluid is at a certain temp. I know mine (I live in ND) won't shift into OD until about 5 minutes of highway time off a cold start. If it seems like the car's taking an inordinately long time to shift into OD, it may be worth checking the Trans temp sensor.
1994 Jeep GC Laredo - 165,xxx
1996 Saturn SL2 - 179,xxx
Add to hardisk_c's Reputation
Rate the quality of this post and help hardisk_c reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hardisk_c is offline   Reply With Quote
Old 12-31-2007, 04:23 PM   #6
RickD.
RickD. is on a distinguished road
RickD.'s Avatar
1997 SW2
How about the thermostat? Mine was bad last winter, and the trans wouldn't shift into 4th on the highway because it cooled the car down to the point where it was running on closed loop (or did I say that backwards? I can never remember). Once the car warmed up it would shift fine, and now that I've replaced the thermostat the shifting is normal.
Add to RickD.'s Reputation
Rate the quality of this post and help RickD. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RickD. is offline   Reply With Quote
Old 01-01-2008, 02:45 AM   #7
SaturnManiac
SaturnManiac's Avatar
I would recommend you let the car warm up to begin with...also don't rev it to try to warm it up quicker...that doesn't work and won't help anything...instead might cause problems. And I'd suggest being easy on it until it warms up fully...no high RPM's.
I don't think it's a problem personally...cars tend to be different when they aren't warmed up...I sure know how mine acts...I let him warm up at lower temps...especially anything under 40. Above 40, I'm easy on him til he warms up.
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-01-2008, 12:05 PM   #8
Bill Murray
Bill Murray will become famous soon enough
1997 SC1
1997 SC1
could it just be not engaging tcc
takes 122F
http://www.saturnfans.com/forums/sho...&highlight=tcc
Add to Bill Murray's Reputation
Rate the quality of this post and help Bill Murray reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-01-2008, 01:05 PM   #9
Normal. The car is likely going into "overdrive" aka 4th gear just fine. What you are not feeling is the torque converter locking up. That will not happen until (as mentioned already) until the engine warms to a certain temp.
Add to ssicarman's Reputation
Old 01-01-2008, 01:25 PM   #10
techsista
techsista is on a distinguished road
techsista's Avatar
well that sort of answers a question i've been asking myself. and it's supposed to be freezing in the morning down here so i better start out early and warm her up
Add to techsista's Reputation
Rate the quality of this post and help techsista reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
techsista is offline   Reply With Quote
Old 01-01-2008, 02:04 PM   #11
rc1488
rc1488's Avatar
you should always let the car warm up Each metal part in the engine has been broken in to fit perfectly only at operating temperture tho. Like doing a warm up before you start running
Old 01-02-2008, 03:19 AM   #12
SaturnManiac
Yup. Just like I don't really feel like driving until the car is warmed up because as I am sitting there shivering waiting for the heat to be able to be turned on my car is sitting there shaking too, LOL. Kinda hard to move when you get too cold, LOL.
Old 01-03-2008, 05:28 PM   #13
xtremeranger
xtremeranger is on a distinguished road
xtremeranger's Avatar
2005 VUE Red Line
2006 ION Red Line
Mine does it too....The ECm will not let the car go into lockup till the car is a certain temp....
Her best bet is for her to take it easy on it till it locks up.....its bad to go all out on a cold motor..
2005 VUE Red Line AWD - Tint, Audio, K&N
2006 ION Red Line Competition Package - Stage 2, strut bar, Hurst, Antenna delete, tinted corners, painted headlights
1998 SL2 - SOLD 87K-113K
Add to xtremeranger's Reputation
Rate the quality of this post and help xtremeranger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xtremeranger is offline   Reply With Quote
Overdrive only mcguirjf S-Series Tech 6 07-21-2009 03:30 PM
'99 SW1 - Shifting Back Into Overdrive??? Coaster S-Series Tech 3 06-26-2009 04:03 PM
Harsh Shifting no overdrive rs16017 S-Series General 2 12-15-2004 10:35 AM
towing in overdrive daves04bluevue Vue General 20 09-16-2004 01:25 PM
Saturn Overdrive Azrael_02 General Saturn Discussion 13 03-24-2002 10:42 PM
