Old 12-27-2007, 11:18 PM   #1
djking51
djking51 is on a distinguished road
Default Replacing rear quarter panel
I need to replace a rear quarter panel on a '98 SC2. Any procedures would be appreciated, and save me a lot of time figuring it out on my own.
Add to djking51's Reputation
Rate the quality of this post and help djking51 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djking51 is offline   Reply With Quote
Old 12-27-2007, 11:23 PM   #2
Uzzy
Uzzy's Avatar
2002 SC1
Default Re: Replacing rear quarter panel
All I know is the rear bumper has to come off and most of the rocker panels too. I didn't take mine off, my buddy did at work (he's a Saturn Tech) and I asked him what has to come off.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 12-27-2007, 11:50 PM   #3
You sure, Uzzy? For the wagon, the "orthodox" procedure is to remove the rear-most two or three fasteners to the rocker panel and lower it, and to loosen the bolts to the bumper cover and slide it backward. But I didn't have to do that with the bumper. I just removed the inner wheel well parts (which you need to do anyway), and reached up into the cavity to get to the bolts/nuts that hold the bumper cover and that part of the quarter panel to the spaceframe. Coupe, of course, may be different.
If it's the driver's side, you'll need to deal with the gas filler, but it should be visually self-explanatory.
Add to madpogue's Reputation
Old 12-27-2007, 11:55 PM   #4
Uzzy
Uzzy's Avatar
2002 SC1
That's what he told me. The had the rear bumper cover off and the rockers partially off. He only did the one side, so I don't think he had to take the rear bumper all the way off, but I guess he was driving it without the rear quarter so he had to take the whole bumper off. I wish I would have seen it driving around half naked.
Old 12-28-2007, 12:24 AM   #5
QCs_R4_Girls
QCs_R4_Girls is on a distinguished road
QCs_R4_Girls's Avatar
2006 ION-2 Quad Coupe
I just did my Ion, and from what the guys at the junkyard told me, most Saturn body panels are replaceable the same way.
You're gonna need, or at least I did:
1 flathead screwdriver (pops out plastic bolts)
1 Torx bit, size TX 25 (unscrew outer bolts)
1 Torx bit, size TX 10 (removes bolts on window trim)
1 10 mm ratchet (removes bolts holding qp in)
The bottom part of the qp will snap into a hole down by the lower door sill. Pop out 3 plastic clips and pull the qp out. Replace in reverse. Also make sure you completely take off the inner wheel well liner. You don't have to take off the wheel; the lining can just rest on the wheel. There are also 3 tabs that slide to hold the qp, and theyre a pain to get off. In fact, I cut the thinnest part of the tab cutout so I could wedge the tab out (since it's busted, I didn't care) Sounds strange, but once you get to this step, you'll understand. There's a 2-part lip on the bottom of the qp right above the wheel well and the bumper will fit right in between the 2, IIRC. Sorry if I'm rambling, here's my thread on it on the Ion: http://www.ionforums.net/viewtopic.php?t=2869 Any other questions just let me know. I've replaced the rear bumper on an SL2 so between the Ion and the SL2, I think I could walk you through it.
It took about 2 hrs for me to do it.
"Remember folks, street lights timed for 35 mph are also timed for 70 mph."
3 - 2006 Ion Quad Coupe 2.2L, Manual, Black
2 - 2002 SC2, Manual, Silver
1 - 1998 SL2, Manual, Blue
Add to QCs_R4_Girls's Reputation
Rate the quality of this post and help QCs_R4_Girls reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
QCs_R4_Girls is offline   Reply With Quote
Old 12-28-2007, 10:54 AM   #6
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by djking51 View Post
...rear quarter panel on a '98 SC2.
Here’s a picture of the car with its trousers removed:
Add to bumpdraft's Reputation
Old 12-28-2007, 11:20 AM   #7
Yeah, from the photo, the setup is analagous to the sedan/wagon. I bet you could just remove all that wheel well stuff, and reach up with enough socket extensions and get those panel-to-bumper fasteners out.
Old 12-28-2007, 11:29 AM   #8
dgrant09
dgrant09 is on a distinguished road
2002 SL1
Here's a link for instructions for a Coupe quarter panel to fix the infamous trunk leak. It's describes removing the rear quarter panel and is about 1/2 down in the posts, should be similar for a sedan.
It was posted by f3qu3t (Thanks again f3qu3t!!)..
http://www.saturnfans.com/forums/sho...ght=trunk+leak
Add to dgrant09's Reputation
Rate the quality of this post and help dgrant09 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dgrant09 is offline   Reply With Quote
Old 12-28-2007, 12:19 PM   #9
djking51
dgrant09, thanks for the link to the instructions from f3qu3t. The pics are a big help, too. And guess what -- we just bought this car, and I was curious about some dampness in the trunk. So thanks to you guys, I'll know to seal the seam while I have the panel off.
Thanks again to all of you who shared your wisdom. It may be a few weeks before I can get to this project, but I'll let you know how it goes.
Old 12-28-2007, 07:00 PM   #10
Uzzy
Uzzy's Avatar
2002 SC1
That's usually why that panel comes off on coupes. That's what mine was in for.
Rear quarter panel replacement PSDFan S-Series General 4 12-03-2009 07:46 PM
replacing sw rear quarter panel blk6rl S-Series Tech 2 07-19-2008 02:26 AM
replacing quarter panel? oldgoat S-Series General 7 05-04-2008 10:21 AM
WTB: 2000 Saturn sc2 Rear bumper and rear driver side quarter panel vextc05 S-Series General 2 11-06-2006 01:17 PM
WTB: 92-95 SL left rear quarter panel bryan_johnson Classifieds 0 02-15-2005 11:27 AM
