Old 10-12-2007, 01:47 PM   #1
eddysemail
eddysemail is on a distinguished road
2000 L-Series 3.0L Sedan
Default Code P0300
I Went To Start My Car And It's Missing Bad!!!!!!!
Pulled Plugs Saw That One Was Fouled So I Replaced All Of Them. Put The System Back Together And It's Still The Same. I Scanned It And It Came Out With A Code P0300 Which Doesnt Help Me At All, I Already Know It Has A Misfire. Can Any One Help Me Out Here?
The Car Is A 2005 Ion2 Quad Coupe With 55,000 Miles On It. I Don't Dog It Out Or Anything Like That And I Perform All The Required Maintenance On Or Before It's Due.
Thanks,
Eddy
Add to eddysemail's Reputation
Rate the quality of this post and help eddysemail reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eddysemail is offline   Reply With Quote
Old 10-12-2007, 03:14 PM   #2
Default Re: Code P0300
For an '05 Ion your car's still new to have anything worn out. Still under warranty? If so then bring it to Saturn for them to fix otherwise it would be worth pulling the plugs again, especially from the cylinder that fouled the first plug just in case that cylinder has a problem. If the second plug is fouled then you've isolated it to that cylinder for possible compression problems, a coil wire gone bad (simple swap with the other wires) with maybe an end terminal broken within the wire, or the coil needing wirebrushing if corroded from road salts. There's plenty of threads covering general misfires related to coil wires, plugs, and coils needing a good wirebrushing to clean up the ground contact surfaces and the coil towers. Look them up or search for misfire conditions.
P0300 code, HELP!!! ColoradoDoug S-Series Tech 5 11-12-2009 07:45 PM
P0300 Code mbolena S-Series Tech 4 12-07-2007 01:20 PM
Help if you can code p0300 dec29p Ion Tech 8 02-06-2007 10:21 PM
Code P0300 livingwaters L-Series Tech 3 02-02-2007 11:53 PM
P0300 Code plainzwalker S-Series General 4 08-02-2004 12:56 AM
