Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 06-02-2007, 11:51 AM   #1
bigjwman
bigjwman is on a distinguished road
1993 SL2
Default Rough Shifting
My 2002 SL2 has developed a shifting problem when attempting to accelerate for passing. The dealer says the exhaust back pressure is too high at over 4PSI. They disconnected the cat but the pressure was still too high. They recommend replacing the exhaust manifold for $900. There is still no guarantee this fixes the acceleration problem. Do you think there is a link between the two problems? If the manifold has a blockage, what is the cause? Is it very difficult to remove the manifold and try to clean or replace it myself?
Add to bigjwman's Reputation
Rate the quality of this post and help bigjwman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigjwman is offline   Reply With Quote
Old 06-04-2007, 03:04 PM   #2
Default Re: Rough Shifting
This is not a "General Saturn" question; you'll get more responses posting in either "S-Series General" or "S-Series Tech".
They probably want you to replace the exhaust manifold because it has another catalytic converter built into it, and that's the probably the one that's clogged. It can't be cleaned; if it's clogged, it's toast. You might be able to DIY this, but the part (at saturnparts.net, anyway) is almost $500. Some aftermarket price shopping might be in order.
Add to madpogue's Reputation
Rough shifting motu56 S-Series General 6 11-11-2006 12:39 AM
Rough Shifting baribenny L-Series Tech 2 01-20-2006 08:48 AM
Rough shifting ym42 S-Series Tech 5 07-19-2003 09:46 AM
Rough Shifting Henry S-Series General 5 06-25-2003 10:11 AM
Sluggishness and Rough Shifting saturnrings S-Series Tech 5 11-06-2002 11:56 PM
