Old 01-19-2009, 01:24 PM   #1
ddechene
ddechene is on a distinguished road
1998 SW2
Default Dealers that will reflash PCM in SW Ontario
Hi all,
Planning on doing a manual swap on a 98 SL2. I understand I need the existing PCM reflashed to the options needed. Anyone know dealers in SW ontario that can do this (ideally without the car, just the PCM box).
--Dan
Add to ddechene's Reputation
Rate the quality of this post and help ddechene reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ddechene is offline   Reply With Quote
Old 01-19-2009, 01:27 PM   #2
OnDaGround
OnDaGround's Avatar
1993 SC2
Default Re: Dealers that will reflash PCM in SW Ontario
From what I understand about the swap, this does not sound true... maybe that's if you grab the one out of the car. I cannot remember.... anyways here are all the details, I read through it once breifly and that's why I do not remember.
http://www.differentracing.com/tech_...anny_swap.html
Saturnless...
Old 01-19-2009, 01:42 PM   #3
PurdueGuy
PurdueGuy's Avatar
1999 SC1
You can run the car on the auto pcm, but it will throw codes. If you aren't in an area that does inspections, this may not be an issue. There may also be a slight difference in how the spark timing is controlled, but I have yet to see this affect functionality. I've been running mine on the auto pcm for two years now, and it's been perfectly reliable, and gets better than EPA estimated fuel economy. Often people who want the "correct" PCM just try to locate one from a salvage yard, so that's another option aside from getting yours reflashed.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 01-19-2009, 01:46 PM   #4
ddechene
1998 SW2
In Ontario we require Drive Clean inspections every two years to keep the car on the road, for them to do the test, the car can't be throwing any codes so it's really not an option. I'm reluctant that I will find a used PCM with the same options, and not really worried about having the PCM flashed, but not sure where this can be done without having to bring the car in.
Old 01-19-2009, 04:34 PM   #5
92SL1Mann
92SL1Mann is on a distinguished road
1992 SL1
bah - I ve had SES light on now for ohhhh 8 years...never been an issue. Take it to the ****ty wheel (aka crappy tire) they never say anything about the light.
1992 SL1, 376,000Kms
1996 SC2, 243,000Kms
Add to 92SL1Mann's Reputation
Rate the quality of this post and help 92SL1Mann reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92SL1Mann is offline   Reply With Quote
Old 01-19-2009, 04:36 PM   #6
ddechene
1998 SW2
Thanks for the heads up. I just called crappy tire and told the guy that the SES light was on. He was like as long as it drives for the drive clean, it doesn't matter. So I guess Ill just run it with the 98 Auto PCM .
Old 01-19-2009, 04:38 PM   #7
92SL1Mann
1992 SL1
Perfect!
ecm reflash? 3500srw S-Series Tech 4 04-21-2008 12:58 PM
reflash 01saturnsl1 S-Series Mods 4 11-15-2006 02:53 PM
ECU Reflash 1759society S-Series Mods 11 10-15-2006 11:21 PM
How do reflash a PCM? remedys S-Series Mods 14 08-22-2006 07:17 PM
Cost to reflash a PCM for Cruise JLWhid S-Series General 1 08-19-2005 11:07 AM
