Old 04-24-2004, 03:11 AM   #1
TXVue04
TXVue04 is on a distinguished road
TXVue04's Avatar
Default 04 VUE hand brake
Has anyone noticed that the hand brake in the VUE is crappy? I was parked on a slight incline and used the handbrake. I always check and make sure it is all the way up and it was. I was finishing up a box to go mail at Fedex, my elbow tapped the handbrake, and it slipped!!! The car slid back, not a lot but a little. But I couldn't help but think, what if I had been San Francisco or something.. geez..
Add to TXVue04's Reputation
Rate the quality of this post and help TXVue04 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TXVue04 is offline
Old 04-24-2004, 04:23 AM   #2
nortsr
nortsr is on a distinguished road
Default
Did you have your foot on the brake pedal when you set the handbrake?....then applying the handbrake (as per manual)? After doing this and then releasing foot from brake padal, the only movement should be very slight and then it is set.
Add to nortsr's Reputation
Rate the quality of this post and help nortsr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nortsr is offline
Old 04-24-2004, 04:44 AM   #3
TXVue04
TXVue04's Avatar
Default
Yes, definitely did, I'm pretty paranoid about hand braking. I have also noticed that when I pull up on it, don't feel the tightness that my old SC2 had. In the SC2 I sometimes had to use both hands to pull it up to the top position, on this one a 3 year old could do it.
TXVue04 is offline
Old 04-24-2004, 01:49 PM   #4
Dante
Dante is on a distinguished road
Dante's Avatar
2004 VUE Red Line
Default
My hand brake is pretty tight. I have parked on a pretty steep hill with it on, and it didn't budge. I have to yank pretty hard to get it all the way up, and it goes almost vertical. The first 1/2 of the pull is easy, after that it gets *much* harder.
Tupperware cars FTW!!!
Add to Dante's Reputation
Rate the quality of this post and help Dante reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dante is offline
Old 04-24-2004, 02:27 PM   #5
bk63
bk63 is on a distinguished road
Default
Mine have always been solid on any Saturn I have owned. Perhaps yours needs adjustment. It seems that mine will hold a house.
Add to bk63's Reputation
Rate the quality of this post and help bk63 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bk63 is offline
Old 04-24-2004, 05:46 PM   #6
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
You really shouldn't be pulling it up all of the way....
Saturn specs are 13 to 15 clicks or something like that.
~D.J.~
OhioVueBoy is offline
Old 04-24-2004, 05:50 PM   #7
CaliVW78
CaliVW78 is on a distinguished road
Default
We use ours everytime. Park, Apply hand brake, then release brake pedal. Ours is tight and has never slipped or release easily.
Add to CaliVW78's Reputation
Rate the quality of this post and help CaliVW78 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CaliVW78 is offline
Old 04-24-2004, 06:27 PM   #8
silvervoo
silvervoo is on a distinguished road
silvervoo's Avatar
2003 VUE 2.2L
Default
I also use mine all the time-- never had any problems. It always holds fine, and I don't pull the crap out of the lever. I've used it to hold the vue and a trailer w/sailboat on an incline, again no problem.
●● If it doesn't have a clutch, I'm not interested ●● Vive la bote manuelle ●●
Add to silvervoo's Reputation
Rate the quality of this post and help silvervoo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silvervoo is offline
Old 04-24-2004, 08:26 PM   #9
Ken Baker
Ken Baker is on a distinguished road
Default
I use mine all the time and the handle doesn't come anywhere near vertical. I applied the break this morning on a slope. I pulled it up until it would go no further using only light force. I assume I could have gone another notch if I had tried. The vehicle did not roll back even after I had let off about three notches of pressure.
Add to Ken Baker's Reputation
Rate the quality of this post and help Ken Baker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ken Baker is offline
Old 04-24-2004, 08:38 PM   #10
HfxVue
HfxVue is on a distinguished road
HfxVue's Avatar
Default
I attempted to drive off some time back while the hand brake was on (I don't use it that often, so didn't remember that I'd set it), and got a warning chime. Not sure what set the warning off, whether it was being in gear with the brake on, or stressing the powertrain.
Add to HfxVue's Reputation
Rate the quality of this post and help HfxVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HfxVue is offline
Old 04-24-2004, 11:22 PM   #11
TXVue04
TXVue04's Avatar
Default
~D.J.~
Ok this statement is making me think I need to take her in for a hand brake inspection. My SC2 made Clicks when I pulled it into position, and Ohio is correct, it was usually 15 clicks for the best position. My Redline make no clicks at all. Could someone with a 2004 VUE let me know if their brakes make clicks as they pull it up.. if so I'm taking it in. thanks.
TXVue04 is offline
Old 04-25-2004, 06:34 AM   #12
Ken Baker
Default
Mine is an 04, 4 cyl and the hand break clicks as you pull it up. It will not click if you depress the release button and pull though.
Old 04-25-2004, 12:50 PM   #13
TXVue04
TXVue04's Avatar
Default
ok, I do press the release button and pull
TXVue04 is offline
Old 04-25-2004, 12:56 PM   #14
jaiello2000
jaiello2000 is on a distinguished road
Thumbs Up
My '04 hand/parking brake works perfectly.
Add to jaiello2000's Reputation
Rate the quality of this post and help jaiello2000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jaiello2000 is offline
Old 04-25-2004, 12:58 PM   #15
TXVue04
TXVue04's Avatar
Default
Jaiello2000, do you hear clicks? Do you push the button and pull or just pull?
TXVue04 is offline
Old 04-25-2004, 06:25 PM   #16
Ken Baker
Default
Just pull the lever up. Don't touch the release button. Use the release button only to release the parking break. By the way my handle is at a 45 degree angle when break is applied.
Old 04-25-2004, 09:13 PM   #17
jaiello2000
Default
I do not push the button. Just pull the lever. It travels 1/3 of the way silently. I can only go 8 or 9 clicks. The parking brake is solid at that point. I cannot back up at all with it on.
I had a few problems with the hand brake on my 2000 LW2. I took it in for adjustment a couple times. The dealer did not like stuff coming back twice with me. They did some magic and I never had a problem again.
BTW. Complain to Saturn Corp. if the dealer is not solving a problem. I had to do that once, but it was remarkable the service after that!
Old 04-27-2004, 03:54 AM   #18
TXVue04
TXVue04's Avatar
Default
Thanks for all of your help!
TXVue04 is offline
Old 05-06-2004, 03:38 PM   #19
robert_vue
robert_vue is on a distinguished road
robert_vue's Avatar
Default
That chime is on a sensor on the e-brake. While driving if I pull it up a little it chimes right away.
Robert R.
03 VUE: Oct 15, 2002 - Dec 5, 2004 R.I.P.
Add to robert_vue's Reputation
Rate the quality of this post and help robert_vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
robert_vue is offline
Old 05-08-2004, 01:36 AM   #20
bswarm
bswarm is on a distinguished road
bswarm's Avatar
2003 VUE 2.4L
2003 ION-1 Sedan
Default
If it takes any more than about 3 or 4 clicks, then the rear brakes may need to be adjusted tighter. Pulling it too hard is only going to put stress on the cables, shoes, etc.
Mine works fine and I have even used it as a cutting brake (Not recommended for most drivers) in the dirt a few times.
Retired wrench bender
Add to bswarm's Reputation
Rate the quality of this post and help bswarm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bswarm is offline
adjusting the hand brake sheldonpardy S-Series Tech 2 01-08-2010 02:37 PM
Right Hand Drive Saturndude82 S-Series Mods 14 10-15-2009 10:16 AM
hand brake will not release hayden13 L-Series Tech 0 06-04-2009 02:31 AM
My hand brake exploded (sort of) RalliArt16 S-Series Tech 13 08-18-2006 03:52 AM
Right Hand Drive POWDER General Saturn Discussion 13 06-23-2003 01:57 AM
