Old 09-20-2019, 07:54 PM   #1
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2005 ION-3 Sedan
Default 2007 Vue remote self programmable?
Half the sites I see say that you can self program the key fob, and half say you can't.
I tried 3 different versions, and none of them worked.
I suspect there is a mixup on which year of Vue is being logged on the sites.
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Old 09-21-2019, 05:19 PM   #2
Default Re: 2007 Vue remote self programmable?
Check your owner's manual. If you have Passlock, dealer only or licensed locksmith use GMs Tech II scantool to program remotes. If you have Passkey/PK3 (rfid chip in the key) owners manual should have programming info or reliable remote sellers can provide programming info.
Old 09-21-2019, 05:58 PM   #3
SL2 Ride
2005 ION-3 Sedan
I don't have the manual, but I know the key does not have rfid.
Old 09-21-2019, 06:03 PM   #4
Ok then yours is Passlock and a dealer/licensed locksmith procedure requiring GMs Tech II scantool to connect to the OBD II port to program remotes. If you decide to do this, bring all remotes as they get programmed, one at a time, up to four remotes.
Old 09-21-2019, 07:38 PM   #5
SL2 Ride
2005 ION-3 Sedan
thanks for the info. the old saturn dealer near me still handles saturn stuff, so i'll give them a call.
Old 09-24-2019, 12:19 AM   #6
pillagenburn
pillagenburn is on a distinguished road
Question on this topic, but will aftermarket tools work to reprogram key FOB's ? Like a vcx Nano?
2005 Vue (150k on body):
2.2L L61 from 2006 Monte Carlo (43k mi)
5-speed (150k)
Add to pillagenburn's Reputation
Rate the quality of this post and help pillagenburn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pillagenburn is offline   Reply With Quote
Old 09-24-2019, 09:24 AM   #7
ScotSHO
ScotSHO is on a distinguished road
Yes, I just went thru this on a 2007 Vue. I needed a scanner to read the PCM codes (bad downstream O2 sensor) and also needed to program two new key fobs. The VCX Nano killed two birds with one stone. It worked well once the software was installed on a laptop.
It is quite dumb that you need the GM Tech2 interface to program a new key fob. Cars older than the mid 2000s just needed a jumper wire, and cars later than that just need a few clicks of a dash interface. It seems security (or maybe self made dealer money generators) was all the rage in 00s.
Add to ScotSHO's Reputation
Rate the quality of this post and help ScotSHO reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ScotSHO is offline   Reply With Quote
Old 09-24-2019, 10:17 AM   #8
SL2 Ride
2005 ION-3 Sedan
man I wish i'd seen this yesterday. I went to GM to get it done.
and of course they said "around 40 dollars" on the phone, but with the dealer fee it wound up being $72.
Old 09-24-2019, 12:51 PM   #9
RobertGary1
1996 SC2
I think the VCX Nano is just a different version of what I have. Its just a MDI interface and you run Tech2Win on your PC, which is exactly what the dealers do. Not sure too many dealers still have the old Tech II's.
-Robert
Old 09-25-2019, 08:06 AM   #10
ScotSHO
Ouch, the VCX Nano w/ software sells for around $120.
Old 09-25-2019, 10:01 AM   #11
pillagenburn
I've seen the VCX as low as $110 and if the difference is only $35 I'd just as soon get the VCX so I can do other cars if necessary.
I'd think it'd be worth $35
5-speed (150k)
Old 09-26-2019, 07:45 AM   #12
SL2 Ride
2005 ION-3 Sedan
Well if this key fob ever fails, that's the route i'll take.
It's a new ACDelco, so hopefully it will last.
pcm reset affect programmable options? jafrancisco3 S-Series Tech 14 01-21-2015 10:44 PM
Adding new keyless remote to 2007 Vue guting Vue Tech 6 11-15-2009 08:18 PM
2007 Aura XR - unresponsive remote audiofx Aura General 12 04-22-2009 11:03 PM
2007 Amp Not powering with Radio Remote Wire Surovich Vue Mods 4 06-29-2007 03:39 PM
Are the intermittent wipers programmable? winthrop Ion General 2 11-21-2003 12:54 AM
