Old 09-21-2019, 11:52 AM   #1
510man
510man is a splendid one to behold510man is a splendid one to behold510man is a splendid one to behold510man is a splendid one to behold510man is a splendid one to behold510man is a splendid one to behold510man is a splendid one to behold
Default Hand Brake Release Repair
I searched the forum for this problem and didn't find it. My parking brake release button had discharged from the handle (see pic). Anybody have a fix for this before I dig into it or search for a used JY part?
Thanks for any help.
Add to 510man's Reputation
Rate the quality of this post and help 510man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
510man is offline   Reply With Quote
Old 09-21-2019, 01:09 PM   #2
focusofheart
Default Re: Hand Brake Release Repair
Richpin video
https://www.youtube.com/watch?v=cCbsYlUoZE4
image in posters pdf -
Old 09-22-2019, 05:26 PM   #3
510man
Thanks. That's an S-series. The L-series doesn't work like that.
I took the hand brake assembly out. A plastic piece broke. Imagine that. I'll have to drill out some rivots to get to the mechanicals and see what I can fabricate. The plastic fatigues with age so a junkyard part would likely do the same.
Old 09-22-2019, 06:57 PM   #4
floridasl22002
The Saturn L series is based on the Opel Vectra B model produced in Europe. In the UK it was sold as the Vauxhall Vectra. Whilst sales in the US were small of the L series, the Vectra was the staple of the business fleet, so as a consequence there is a flourishing aftermarket parts supply not seen in the US for the L series. The L series also has a cousin in the Saab 9-5 which also was based on the Vectra B.
i just did a quick google for handbrake parts for Vectra B and click on the link to see what you can get. There are compete handbrake assembly for just dollars (you need to do the exchange rate as they are quoted in Euros I have purchased new handbrake cables and other suspension bushings for my lads 2003 L300 from Europe without problems.
Hope this helps. In any search make sure you use the designation Vectra B, emphasis on the B.
https://www.ebay.ie/sch/Car-Parts/60...ra+b+handbrake
Old 09-23-2019, 09:00 AM   #5
rfisher
rfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the rough
hi floridas- good pickup on the different construction of the brake in the L100 than on the s model. surmise the brake button ejecting itself from the s model brake is more common than on the L. actually in my discussions with other L owners and there aren't too many left this brake problem hasn't come up. maybe they improved the design on the L. it gets plenty of use in mine since for safety in parking I always put the trans in 1st and pull up the brake. using the park brake regularly reduces the incidence of the cable rusting and sticking. had that happen a few times with fords and dodges back in the day when I would secure the parking by putting the trans in first only. didn't help living in nj either which is the rust capital of the world. thanks tons bob f
Add to rfisher's Reputation
Rate the quality of this post and help rfisher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-23-2019, 12:05 PM   #6
02 LW300
02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all
02 LW300's Avatar
I would bet a used parking brake assy from an automatic car would give many years of service. The parking brake is seldom used on flat ground in an automatic car.
Add to 02 LW300's Reputation
Old 09-23-2019, 03:27 PM   #7
rfisher
hi sages- good points all. can anyone walk us through the steps to fix, remove, take apart the hand brake in an L model since it is different than the s model.thanks tons bob f.
Old 09-23-2019, 09:55 PM   #8
focusofheart
Thanks for pointing that out to me. I will be more cautious in the future.
Old 09-23-2019, 10:48 PM   #9
02 LW300
02 LW300's Avatar
The factory service manual does not discuss repairing a parking brake handle. It gives replacement instructions of the assembly and that is all.
Old 09-24-2019, 09:39 PM   #10
510man
Originally Posted by floridasl22002 View Post
Hope this helps. In any search make sure you use the designation Vectra B.
Thanks. That helped a great deal. This is the part. 10 Euros. SMH...
https://m.ebay.ie/itm/2000-VAUXHALL-...AAAOSwcwhVQRph
Old 09-24-2019, 09:42 PM   #11
510man
Mine is automatic and we use it all the time. :-) Hence, why I need to fix it.
Old 09-24-2019, 09:47 PM   #12
510man
I'm doing it. I took my L-series apart this evening. A plastic piece broke side. I'll fix it with some JB Weld and post some pictures later. If that doesn't work, all either fabricate something from metal or I'll order a replacement from the UK as suggested above.
Old 09-29-2019, 12:20 AM   #13
510man
The JB Weld did not adhere to the plastic used in this application. I had to fabricate. I used a bicycle chain master link. It's reinstalled in the vehicle and works great. Total cost of repair was about $5.
Pics are here. Hope it helps the next guy.
https://www.flickr.com/photos/234393...57711110070528
P.S.: Couldn't load pics to Saturnfans. The file sizes are far too limiting.
Old 09-29-2019, 12:10 PM   #14
02 LW300
02 LW300's Avatar
Well done, nice write up.
Thank you for sharing.
Old 09-29-2019, 03:15 PM   #15
Genius level creativity.
how to fix a hand brake boot? jacek_p Ion General 13 06-03-2016 02:27 PM
Hood Release Cable Repair Question Jax_1995_SL1 S-Series General 9 03-19-2012 10:26 AM
adjusting the hand brake sheldonpardy S-Series Tech 2 01-08-2010 02:37 PM
hand brake will not release hayden13 L-Series Tech 0 06-04-2009 02:31 AM
04 VUE hand brake TXVue04 Vue General 19 05-08-2004 01:36 AM
